ParkLiner & Ford Escape - Fiberglass RV
Old 09-10-2014, 05:12 PM   #1
frank_a's Avatar
Trailer: 2012 ParkLiner #006
I'm getting to the point that I wish I had not bought either!
Anybody familiar with my ParkLiner problems will understand how I feel.
Today, after once again bringing our 2013 Escape to the Ford garage for a check engine light, I came home for one final whirl at the 7 pin wiring that I have not been able to get to recognize the trailer brakes. To make a long story short, it still does not recognize the trailer brakes. I wish at this point I had bought a vehicle with a factory 7 pin. Sheesh!
The same controller (a Tekonsha P3) works fine with my F150. I have spent countless hours checking continuity, voltage, and amps with the Escape. I changed both the controller plug and the 7 pin. There is no reason it shouldn't work, other than it's an Escape I guess. Tomorrow I will check on some RV places around, and maybe spend some $ to see if somebody else can figure this out.
If I hadn't spent so much money on the ParkLiner already, especially travel down and back from the plant in NC, this wouldn't be so bad. The ParkLiner "bang for the buck" has not been good.
So, off again with the F150 & ParkLiner this weekend, this time to visit friends in MD. The F150 does a great job, but man o man, it's a gas hog!
I hope all you folks are doing better than me!
Frank
2012 ParkLiner #006
Old 09-10-2014, 07:15 PM   #2
emers382's Avatar
Trailer: 2016 Escape 5.0TA
Manitoba
Sorry to hear Frank about the ongoing issue with the Ford Escape. Those considering buying one to tow a trailer needing brakes should take note. Our original thought was to get an Escape with tow package and an Escape 17b trailer but ended up with the 5.0. I didn't even know when we were considering it that the Escape only came with 4 pin wiring.
Hope you at least get good weather on your trip to MD
Adrian
emers382 is offline   Reply With Quote
Old 09-10-2014, 08:09 PM   #3
Ice-breaker's Avatar
Trailer: Escape 19 and Escape 15B
This solution is probably too late for your particular circumstances, but it could help others with a similar issue. My Toyota did not come pre wired from the factory for plug and play brake controller hookup. I called around and local hitch shops wanted $500 for supplying and wiring in a brake controller. Instead I bought a $300 wireless brake controller that was super easy to install and required no wiring changes other than addition of a 12v charge wire to the 7 pin. I bought the Tekonsha Prodigy RF. It mounts on your trailer and plugs into your 7-pin, and has a controller you keep in your vehicle which plugs into your cigarette lighter. Have used for two years now and is super reliable.
Dave W - 2013 Escape 19', 2013 Escape 15B and 2011 Toyota FJ Cruiser
"You've got to be very careful if you don't know where you are going, because you might not get there." - Yogi Berra
Ice-breaker is offline   Reply With Quote
Old 09-10-2014, 08:45 PM   #4
Bob Miller's Avatar
Trailer: Class A Motorhome
Hmmmm... What am I missing???
You usually have to run one wire from the battery, through a circuit breaker, to the controller, and one wire from the controller to the correct terminal on the 7 pin connector. Is there some interface needed with the vehicles braking system?
Old 09-10-2014, 08:51 PM   #5
Bob Miller's Avatar
Ooops, forgot you also need a connection via the brake light switch.... and I'll bet your brake lite switch is set up to be ground seeking to turn on the lights.
Old 09-11-2014, 01:05 AM   #6
Borrego Dave's Avatar
Frank, relax man, it's only 'chinery and can be fixed. You may want to go to Etrailer and check out their videos of controller installs. They have one for most all TVs. I went with a new P2 I bought on Ebay, got the wiring/breakers from Etrailer and the install was easy....other than the 100+ degree heat going on then . A couple ckt breakers, wires and zip ties and kept the install $ in my pocket. My '02 Ranger was not prewired for a plug in controller. I use a round 6 pin for all the other trailers I have but didn't want to try to get the SDs brakes to work off of that one so wired in the dedicated 7 pin. I did pick a flat 4 off of it just in case I use someone elses trailer. Check Etrailer out, pop a cold one and think about bypassing the factory wiring setup. Good luck to you
Old 09-11-2014, 06:19 AM   #7
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Missouri
Frank,
Although I have not yet hooked up the electric brake controller, I have been towing my Scamp13 with a 2014 Ford Escape FWD 2.0L.
I used a Hopkins Multi-Tow 4-pin to 7-pin adapter and adapted the Escape's 4-pin without cutting into any of the vehicle wiring. I also ran a 12v wire from the engine compartment to the "charge line" on the 7-pin plug. So far, everything works fine.
Rather than using the Curt Tri-flex proportional controller, that we have installed in another vehicle, I too have considered the Prodigy RF controller solution. I would be interested in more details of user experience with that controller.
The Ford Escape has lots of power and, with just over 2000 miles on the vehicle, gives 20+mpg towing in rolling hills at 60mph.
My Scamp13 was configured for minimum weight and I was told that I might not even need the electric brakes, but I did have them installed at the factory anyway.
Have you disconnected your brake controller (or simply pulled the fuse?) for a low speed "around the block" test of the system? If you still have the original Ford 4-pin, you could maybe try the Hopkins Multi-Tow (or other) without a brake controller and then add the controller functionality after the basic system works? Just a thought ... (Maybe you've already tried that?)
Once you get it all working, I'm guessing that you will like the towing experience with the Escape.
Best of luck! :-)
Ray
rdickens is offline   Reply With Quote
Old 09-11-2014, 07:19 AM   #8
deryk's Avatar
New Jersey
Have you considered taking it to a trailer place and let them get it working? On my pt cruiser and rav4 I installed the 4 prong connector but when I was going for my ParkLiner I paid to have the 7 pin installed. Fortunatly my frontier came wired for 7 pin.
deryk
Old 09-11-2014, 07:53 AM   #9
NW Wisconsin
On many of the newer vehicles the factory brake controller is integrated with the vehicle's on board computer . I am looking at purchasing a 2014 Ram truck . Ram states on their website that after market brake controllers can not be added to the truck. The dealer says they can be added but they will need to reprogram the on board computer. Adding an aftermarket brake controller ends up costing more than the factory install ?? Maybe your vehicle needs a computer update in order to recognize the brake controller and supply the necessary imputs and outputs.
Old 09-11-2014, 09:30 AM   #10
Timber Wolf's Avatar
North Florida
That be the Ghost of Henry Ford telling you he wants you to tow with the rig he intended, the F-150.
As an aside, my "ex" just traded in "our" Honda Odyssey on a new Ford Edge. The Honda needed maybe a $1,000 worth of work but maybe considerably less and I had her all set up with my guys (great and honest mechanics) to perform the work. It was all small stuff you would expect in a 9 year old rig and nothing major. Stuff like brakes, CV boots & seals, small leak in power steering, certainly nothing to trade a nice vehicle over.
Anyway, her parents, ardent Ford fans, convinced her that the van would blow up any day and it was time to trade. Her brand new Edge has intermittent complete A/C outages that only happen when it is REALLY hot (when you need A/C the most) and the Ford place cannot find a problem. Did I mention it is August in Florida? Did I mention that despite my best efforts to take care of any issues with the van (out of the kindness of my heart) she decided to trade without mentioning it to me before hand? Did I mention she now calls and comes by and cries to me about the A/C not working in her new payment-book Edge and that the Ford people are mean to her?
Thus far I have resisted the urge to tell her to call her Daddy any time she wants to discuss the issues with her new Ford but I don’t know how long I can hold out. Rant off, we now return you to the topic at hand.
Old 09-11-2014, 10:00 AM   #11
I still have a couple of the old controllers that tapped into the hydraulic system using a "T" fitting at the master cylinder. What's wrong with using one of those. They also have a nice lever for manual operation. Outdated technology???
Tim, we just last fall spent $3000 on our Honda CRV for a starter and a bunch of other issues that were just common for the age of the vehicle. What else could we get for that money, and why get rid of a well maintained and cared for vehicle for something unknown. Time for you to succumb to that urge.
Old 09-11-2014, 10:03 AM   #12
rdickens's Avatar
Missouri
Dave (or a trailer place ... Like Croft?) can correct me if I am wrong but, with the Prodigy RF, the Escape will not even "see" the brake controller. It will see the brake light circuit energized, sense the amount of braking required, and apply the trailer brakes accordingly.
Croft Trailer, in the KC metro, suggested that would be a good solution for me. Unfortunately, they wanted about $100 more for the Prodigy RF than Amazon.com or thee trailer.com folks.
Since you bought your parts from them, I guess you could also call the toll-free number for trailer.com and talk to them. When I called them, they seemed very knowledgeable.
BTW - When not towing, my 2014 Escape FWD 2.0L I4 Ecoboost gets 30 - 32 mpg on the highway at ~60mph. Since it is my "everyday driver", the non-towing mpg is pretty important to me too. More miles not towing than towing right now. Of course, YMMV.
Ray
Old 09-11-2014, 10:05 AM   #13
rdickens's Avatar
Missouri
Make that etrailer.com .....
Old 09-11-2014, 10:11 AM   #14
Bob Miller's Avatar
Hydralic Brake Control
Splicing anything into a hydraulic circuit with modern anti-lock brakes may well lead to a whole raft of problems with vehicle as well as trailer brakes.
And I'd bet it would play havoc with any warranty claims about the very expensive anti-lock system controller. I'd look for a more modern solution, at least something from the 1980's LOL.....
Old 09-11-2014, 11:00 AM   #15
I agree. I just threw that in as a comment on how things used to be simple in the past, now more complicated by modern computer controlled systems. I think the last vehicle I actually tapped one of those controllers into was a '69.
Old 09-11-2014, 11:15 AM   #16
Bob Miller's Avatar
I had one on our 1973 Blazer and pulled an Airstream full time for a year and it was little better than marginal when compared to a modern (and even basic by todays standards) P2 controller.....
Old 09-11-2014, 11:47 AM   #17
Carol H's Avatar
When I had to install the seven pin and brake controller on the Subaru (it also only came with a 4 pin) I only tapped into the brake system via the brake light line just above the pedal to get the controller up and running, that is once the blue brake line was installed (that was a big pain).
I did later have issues with somedays some lights on the trailer worked fine and others not... turned out there was a faulty small electrical modular box which was part of the seven pin pigtail/plug set up.
Was also happy my Frontier came fully prewired and nothing more than a new harness for my old P2 controller was needed to get it up and running. Took more time to figure out where I want to mount the controller than it did to wire it up. Factory Plug and Play rocks!
Hope your able to get it sorted out Frank. As others have indicated it may be time to have a fresh set of eyes look over how its set up.
Old 09-11-2014, 12:15 PM   #18
Trailer: Scamp 13
I too use the Prodigy RF controller as I have a choice of 3 tugs to choose from. I have used it over a year now and it has worked flawlessly. You still have to have a functional 7 pin socket on your tug with a charge line but you don't have to deal with the nasty blue wire to your brake system.
Unfortunately I don't have a Ford Escape to do any testing.
Do the trailer brakes work when you hit the manual control on your controller?
When the unit is hooked up is the controller lit up and show its connected?
Old 09-11-2014, 12:23 PM   #19
Trailer: Scamp 13
Frank,
I don't know if you have seen this.
http://www.ford.com/resources/ford/g...&tt_escape.pdf
Old 09-11-2014, 12:23 PM   #20
Bob Miller's Avatar
What may be the case with a FORD is that they may still be using ground seeking circuits. That is, there is always 12 volts going to a load, like a tail light, and the tail light switch provides a ground to turn the light on, while the P2 and others are looking for 12VDC+ from the switch. Seems to be fairly common on a lot of vehicles with computer control of everything.
escape, parkliner
Ford Escape or Mazda Tribute? Ron Stewart Towing, Hitching, Axles and Running Gear 11 06-23-2009 05:53 PM
Ford Escape or Suburu Outback? Paul Kaplan Towing, Hitching, Axles and Running Gear 9 07-09-2008 05:28 PM
Ford Escape as a Tow Vehicle Booker B. Towing, Hitching, Axles and Running Gear 9 05-04-2008 10:42 PM
