u-Haul solar panels - Fiberglass RV
Old 04-05-2017, 08:14 AM   #1
u-Haul solar panels
Have to replace the solar panel on the roof of my U-Haul. Has anyone done this and how. Any help at all would be appreciated.
Thank You
Phil
Philmay1 is offline   Reply With Quote
Old 04-05-2017, 08:18 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Phil, if you post pictures that would definitely help in addressing this question.
Old 04-05-2017, 08:59 AM   #3
If you can get the old panel off without disturbing the original brackets, then you can adapt the new panel to those brackets. The original wire comes up through a grommet in the roof. I couldn't get our panel out of the brackets after removing the attaching screws, so had to pull down the inside ceiling carpet, remove the screws to only one of the brackets, get the panel off, put bracket back on. I did not install a new solar panel, only removed the old one to fix a seam leak under it. The original panels were only intended to keep the battery up while the trailers sat on the rental lot. I did not reinstall the original panel.
Old 05-18-2017, 05:23 PM   #4
Trailer: 1996 16' Casita SD
Louisiana
I replaced mine with a new 40 watt. There are 6 bolts that hold it on. I had to cut off a few of mine because....rust.
Here's a link to my thread. Its shows a little about it. you may need to go back a page.
http://www.fiberglassrv.com/forums/f...d-77917-3.html
itlives is offline   Reply With Quote
Old 07-25-2017, 08:26 AM   #5
solar
Thank you all very much for the input. Installed a 50wat and now thinking of another in front of the fan vent. Also installed two 6 volt golf cart batteries and a cobra inverter. So far runs everything except my microwave. Thanks again.
solar, solar panel, u-haul
Mounting Solar Panels to Roof ? Dean & Mary Modifications, Alterations and Updates 11 06-28-2016 09:45 AM
Solar Charger and Panels Frederick L. Simson Modifications, Alterations and Updates 109 08-11-2008 10:41 PM
Solar Panels Barbara Gardin Electrical | Charging, Systems, Solar and Generators 7 06-02-2007 09:30 PM
Canadians Who Bought the 54 Watt Solar Panels at Cosco Paddy Morris Electrical | Charging, Systems, Solar and Generators 5 05-26-2006 03:14 PM
Solar Panels Legacy Posts Electrical | Charging, Systems, Solar and Generators 13 04-24-2003 09:09 AM
