We are selling our 1979 17'
Bigfoot Camper Trailer. It pulls great (I have an SUV with only a 5.7L V6) and has all the conveniences of a regular RV (Stove/Toilet/Shower/etc...). This trailer is in great condition with almost all the original parts intact and we still have stored most of the original parts that have been replaced. Behind Bryan Adams and poutine, this might be Canada's greatest export.
The specs:
-Has clean
title
-Original 4-burner gas range with oven
-3 cu. ft. 3-way
fridge (propane, 12-V, 110-V)
-6 gal.
propane hot water heater (not tried)
-12,000 BTU
propane furnace (not tried)
-1 40lb
propane tank
-Wet bath (toilet/shower)
-28 gal. fresh water tank
-17 gal. gray water tank
-8 1/2 gal. black water tank (Comes with a sewer hose)
-Power distribution center w/battery charger
-300 watt inverter
-Marine deep cycle
battery
-110-V AC outlet
-Fire extinguisher
-Front dinette converts to bed (44" X 79")
-Sofa converts to bed (44" X 75")
-Bunk over sofa converts to bed (35" X 72")
-Interior headroom: 6' 6"
-Overall exterior dimensions: 16' long, 8' 6" high, 7' 10" wide
-Trailer
weight: less than 1,500 lbs (GVW 1,875)
-4 stabilizer jacks
-Spring over
axle modification, with oversize
tires and wheels (comes with 2 chocks)
-Spare tire
-Friction sway bars
-Bargman breakaway system (emergency brake in event of unhitching during transit)
-Water pump may need to be replaced if you want to boondock, but otherwise city water works great
-New roof vents
-Some warping on two of the ceiling panels from a past leak. The new vent (mentioned above) fixed that leak
-New fresh water plumbing
-Small
fiberglass shell repair on driver's side (see last image)
-This trailer has been used very little and is in good condition
Asking $9,000
Email for additional pictures. Located near Seattle
