1977 Trillium Fuse Plug Holder - Fiberglass RV
Old 07-10-2017, 02:50 PM   #1
Got a problem when I lost my fuse plug holder which plugs a 15A fuse into my power converter. I now have no power. Does anyone have one of these or know where I can get one. They are square in shape and have a long 15A fuse that springs into it.
agreco is offline   Reply With Quote
Old 07-11-2017, 06:39 AM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
most of these can be replaced by a standard fuse holder, or a mini breaker which are available at radio shack, or any electronics part store, just make sure it's rated for the appropriate voltages and currents
Joe
Old 07-11-2017, 07:13 AM   #3
Fuse plug holder
Thanks for your reply Joe I managed to pick up a standard 250 V 15 amp fuse holder at Princess auto. I'm not sure if it has to be re-wired or not.
Have you ever done one of these? Can anyone provide some insight on this?
Old 07-12-2017, 02:24 AM   #4
The leads may be soldered on, or may be n quick tabs, either way, there will only be two wires, the placement n the fuseholder doesn't matter. If they have to be soldered, heat the tab first until elder will melt n it, then the same with the lead you are going to put n. Make sure the solder is sucked right into the wire. Then heat the tab again until the solder melts, push the wire through the hole, add a bit more elder, then let it cool
Joe
Old 07-12-2017, 05:35 AM   #5
Existing fuse holder
Thanks Joe for all the tips given. How does the current fuse lock in place
It pushes in springs back out and just sits loose.
Shouldn't it lock in the hole instead of sitting loose
Tony
Old 07-12-2017, 06:12 AM   #6
likeair2me's Avatar
Trailer: SCAMP
Missouri
Push the fuse down in the holder and twist the cap to lock.
likeair2me is offline   Reply With Quote
Old 07-12-2017, 02:42 PM   #7
Fuse plug holder 77 Trillium
You can push it in and it is square so it cannot be twisted. Im not sure how or if they are supposed to lock in place or just sit there loose.
Any ideas folks. It is blue in colour.
Old 07-12-2017, 03:11 PM   #8
Borrego Dave's Avatar
Sounds like it's time for a pic or two .
Old 07-13-2017, 10:57 AM   #9
likeair2me's Avatar
Trailer: SCAMP
Missouri
See if this is what you are looking for.
https://www.bing.com/videos/search?q...B1F2C&FORM=VRD
See current question from member mszabo who has a progressive dynamics system out of a Trillium.
Old 07-13-2017, 11:04 AM   #10
mszabo's Avatar
Trailer: U-Haul VT16
I guess someone missed it was missing when I got it and
mszabo is offline   Reply With Quote
Old 07-13-2017, 12:06 PM   #11
likeair2me's Avatar
Trailer: SCAMP
Missouri
I am hoping AGRECO can show us a picture of what he is dealing with. It may be the same evil fuse issue.
Old 07-13-2017, 12:23 PM   #12
its probably something like this:
when you push on the front where it says fuse, it will release, when you re-insert there is a little tab on the front that will catch and hold it in place
Joe
Old 07-13-2017, 12:33 PM   #13
here's a link from a PD converter manual, you can see it's the same style fuse holder:
http://www.progressivedyn.com/pdfs/pd69xx%202.pdf
joe
Old 07-13-2017, 01:27 PM   #14
mszabo's Avatar
Looks like that's the one! You the man Joe.
Thank you much.
trillium
Magazine holder for 1977 Trillium BarbieB Problem Solving | Owners Helping Owners 4 06-09-2016 08:01 PM
7 way plug to 4 way plug back to 7 way plug immrbill Problem Solving | Owners Helping Owners 3 08-10-2015 11:08 AM
PD 6911 Fuse Holder Dennis_S Electrical | Charging, Systems, Solar and Generators 3 05-31-2015 10:25 PM
1977 Trillium - Wiring to a 4 Plug gblacketor Problem Solving | Owners Helping Owners 13 04-09-2012 04:48 PM
Trillium Door Holder Keith Boddy Problem Solving | Owners Helping Owners 10 08-23-2009 07:36 AM
