Trillium Jubilee 79' - Page 2 - Fiberglass RV
Old 06-29-2017, 03:40 AM   #21
Trailer: Trillium Jubilee '79
Newfoundland
The original latches for the Trillium, I believe, are called Positive Latches and they are a challenge to source. Interested myself to see what alternatives are out there.
Terranovafox is offline   Reply With Quote
Old 06-29-2017, 03:48 AM   #22
Carl V's Avatar
You can find similar positive latches on Amazon (or at many RV dealer parts department) but they are not exact replacements, they are not as nice, they are built cheaper, and I don't know if the screw spacing and dimensions are compatible with the original ones.
Old 07-03-2017, 06:16 PM   #23
Marrisa09's Avatar
Trailer: Trillium Jubilee 79?
Originally Posted by Pat Thomson View Post
what catches did you use on the cupboards? all the original catches on our Jubilee are failing and I cant find what to replace them with.
I bought some of these catches and then putting regular door handles on them.
Thanks in Advance,
Marrisa
Marrisa09 is offline   Reply With Quote
Old 07-03-2017, 06:25 PM   #24
Marrisa09's Avatar
So I went out to my grandpas today in the sweltering heat. I scraped some more of the ensolite out and primed the ceiling (Kept the ensolite on the roof) it already looks so much better. My grandpa learned that the counter base cabinets we crooked so he levelled them so the counter doesn't lean back again. He also re enforce the door so it wouldn't bend more cause of how flimsy it was and it would hit the corner behind! I also tsped the whole dang thing. Found out that we have to take the front window out cause one of the boards is rotten. Ugh. I hope I can get her in tip top shape so I can use her on the trip I already booked.
Here are some most recent pics Click image for larger version
ID:	108243Click image for larger version
ID:	108244Click image for larger version
ID:	108245Click image for larger version
Thanks in Advance,
Marrisa
Old 07-05-2017, 08:30 PM   #25
Marrisa09's Avatar
Got a bit more work done today. Mainly scraping off the stupid foam. We also took the front window off since the manufactures only used double sided tape and regular screws to keep it in place. So we pulled it out and put it in with putty tape and stainless steal skewed so they won't rust in half like the originals. We also had to move the propane holder shelf thing so that the new bigger battery would fit.
Here is before
Here is After
Here are a few pictures of the inside all scraped and also cleaned.
Oh and I forgot we filled the dent out in the trailer with foam so that when we put the foam on the walls it will be more even. Click image for larger version
ID:	108333Click image for larger version
ID:	108334Click image for larger version
ID:	108335Click image for larger version
Thanks in Advance,
Marrisa
Old 07-05-2017, 08:33 PM   #26
likeair2me's Avatar
Trailer: SCAMP
Missouri
Great progress! I can't wait to see what you finally bring to life.
likeair2me is offline   Reply With Quote
Old 07-09-2017, 10:26 AM   #27
Marrisa09's Avatar
So yesterday, we put up 3/4 of the foam. Such a big job . Click image for larger version
Thanks in Advance,
Marrisa
Old 07-09-2017, 10:55 AM   #28
likeair2me's Avatar
Trailer: SCAMP
Missouri
WOW! It is really coming together!
Old 07-09-2017, 07:44 PM   #29
Marrisa09's Avatar
Today we did just a little more work. Finished putting that crazy foam in that back corner and then caulked the seems so hopefully you won't see them that great when I paint them. My grandpa also installed the sink into the counter top and also the taps, all the mean while I painted some cupboards the wrong color (oops). I also varnished a few of the cupboards. Click image for larger version
ID:	108492Click image for larger version
Thanks in Advance,
Marrisa
Old 07-12-2017, 11:31 PM   #30
Marrisa09's Avatar
So, my mom and I cut and pinned the curtains for the trailer last night. (So easy to find good help around here Lol) They will look so much better than the blue floral uneven ones that were in there before, mind you they are not perfect! I sewed all the edges tonight, okay I sewed four out of the five windows worth cause I ran out of thread.
♥️fun tip: if using a thick thread have the tension on your machine high and also use regular thread in the bobbin works wonders!
Thanks in Advance,
Marrisa
Old 07-14-2017, 02:32 PM   #31
Marrisa09's Avatar
Okay so today I went out to my grandparents and primed most of the inside including the foam. Looks pretty good
But man is it freaking got out[emoji274][emoji274][emoji274]Click image for larger version
Thanks in Advance,
Marrisa
Old 07-18-2017, 09:14 PM   #32
Marrisa09's Avatar
Well we have gotten a lot more done the past few days! I got all the inside painted and varnished! All the cupboards are painted and also varnished! We pulled up some of the flooring and cleaned out under the water tank and then found out I need to buy a new valve since the original was sooo sticky. Everything is just about ready to go in so excited! Click image for larger version
Oh yeah and I painted the fridge!
Thanks in Advance,
Marrisa
Old 07-18-2017, 10:30 PM   #33
Trailer: Trillium 1976 1300
Saskatchewan
So cool. Wood interior. What's a keep and what is going to be an upgrade?
Shaunamarie is offline   Reply With Quote
Old 07-19-2017, 02:07 PM   #34
Marrisa09's Avatar
So we have kept a lot of the same/original things in the trailer but, we have also replaced a few small things or just upgraded the old with paint.
The foam on the walls is all new 1/4inch closed cell foam that was primed and painted.
Cupboards have been refaced and will have new doors on them and new hinges and handles.
Floors will have a new click fake hard wood floors.
Table has been primed and will be painted.
The fridge has also been painted.
There is a new light fixture to be put in, and new lights.
Thanks in Advance,
Marrisa
Old 07-21-2017, 07:33 PM   #35
Marrisa09's Avatar
So it's been a few days and we got a lot done in the trill. We put up the cupboards, put cupboard doors on, hung curtains, put the fridge in, fix the front awning, maid sure all the wiring is working, braced a few things till they get permanent work and then finished painting and varnishing the table!
Thanks in Advance,
Marrisa
Old 07-21-2017, 07:35 PM   #36
Marrisa09's Avatar
The back with out the table up
The back with the table up
The fridge
The counter and cabinets
Thanks in Advance,
Marrisa
Old 08-01-2017, 10:25 PM   #37
Marrisa09's Avatar
Well I think I have desire on a name for the beauty.... One in a Trillium
Thanks in Advance,
Marrisa
Old 08-01-2017, 11:32 PM   #38
Trailer: Trillium
Quebec
Really good job on your cabinet, nice choice of color !!
daniel-42 is offline   Reply With Quote
Old 08-08-2017, 12:07 PM   #39
Marrisa09's Avatar
Thanks I did hours of searching on Pinterest lol to find the best fit
Thanks in Advance,
Marrisa
Old 08-16-2017, 02:50 PM   #40
Gilles's Avatar
Quebec
Congratulations Marrisa, you are doing a great beautiful renovation on your Trillium Jubilee.
But just for your information, it does not identify itself as a 12 'but as a 15', made between 79 and 81.
For the length of these trailers I was told that it was necessary to measure from the end of the bumper to the end of the hitch.
I have owned one for 7 years and found it very pleasant with all its windows which gives us a good light and allow us to see easily outwards.
Congratulations!
Gilles
Bigfoot 25B21RB.
Gilles is offline   Reply With Quote
trillium
SOLD - 1980 Jubilee by Trillium Rick Helgren Classified Archives 1 11-19-2007 04:23 PM
15ft Trillium Jubilee webber33 Classified Archives 4 08-17-2006 07:36 PM
Trillium Jubilee Bill F. General Chat 4 05-11-2006 08:15 AM
SOLD 1980 trillium jubilee heller372 Classified Archives 0 05-01-2006 02:14 PM
1980 Trillium Jubilee for sale General Chat 0 01-01-1970 12:00 AM
