Door rebuild, 1980 Trillium 5500 - Fiberglass RV
Old 06-05-2017, 04:11 PM   #1
Trailer: Trillium
I'm in the process of rebuilding the door on my Trillium, With the rotten wood inner frame the door came apart quite easily. I noticed a long metal rod in- bedded in the wood, on the door lock side with a nut on each end. Anyone know what this is for? Does it need to go back when I rebuild? I'm planning to replace all wood and then reinstall with wood screws instead of big staples.
Scott
Scott Inglis is offline   Reply With Quote
Old 06-06-2017, 07:56 AM   #2
Carl V's Avatar
Hi Scott
Please post pictures of your door job if you can.
I will follow this thread with great interest.
I took the entire door & frame assembly off mine last month to fix rotten wood on the floor and entry step support.
I haven't touched the door itself, but I'll probably have to replace the lock, and maybe the aluminium sheet on the outside that has some scratches and dimples and doesn't look too good.
That metal rod wit a nut a each end, this sound like a stiffening rod.
trillium
Qu (Canada) - Trillium 5500 - 1980 - $5500 David Tilston Referrals: Molded Fiberglass Trailers 1 11-12-2015 09:44 PM
BC (Canada) - Trillium 5500 - 1981 - $5500 David Tilston Referrals: Molded Fiberglass Trailers 0 06-23-2015 11:07 AM
On (Canada) - 1981 - Trillium 5500 - $5500 David Tilston Referrals: Molded Fiberglass Trailers 4 10-13-2014 11:09 AM
WA Trillium 5500 $5500 kootenaigirl Referrals: Molded Fiberglass Trailers 6 09-05-2014 09:59 AM
1976 13' Trillium and 1980 Trillium 5500 18' Jenn Classified Archives 10 05-19-2010 02:36 PM
