surfside fiberglass fix - Fiberglass RV
Old 03-10-2016, 06:18 PM   #1
Trailer: surfside
alberta
Hey there all
I have a surfside that my father had thats now mine that im restoring o need some help on fixxing the fiberglass roof and other patches ilany info will help thanks
Colton
colton is offline   Reply With Quote
Old 03-11-2016, 01:15 PM   #2
Trailer: Still Looking
Alabama
What are you wanting to know? Any pictures of the area to be repaired?
Bullington is offline   Reply With Quote
Old 03-12-2016, 02:09 PM   #3
Trailer: surfside
alberta
pictures
Some outside body wear
Old 03-12-2016, 02:09 PM   #4
Trailer: surfside
alberta
I uploaded some pictures
Old 03-12-2016, 07:41 PM   #5
Alabama
It appears to me to only be gel-cote degradation. If it were me I would sand the bad areas and use a high-build 2 part primer on them. You can put it on with a brush a mop or anyway you want to, just get the repair "full" of primer. This sands very easily, maybe use 120 then 180 then 220 with a random orbital sander. On the compound areas, like the corners, only sand by hand with a sponge backer. Then paint the areas or better yet sand the whole camper and paint with a two part polyurethane paint. Some just roll and have a helper tip with a good fine brush. If you can, spray it for best results. Good luck.
Old 03-13-2016, 10:52 AM   #6
Trailer: surfside
alberta
Would this stuff work short strand bondo?
Old 03-13-2016, 12:17 PM   #7
Alabama
From what I see, bondo is not what I would use.
surfside
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
How to Fix Fiberglass from the Front? morbank Problem Solving | Owners Helping Owners 24 06-24-2012 10:04 PM
When is fiberglass too far gone to fix? CeliaL Problem Solving | Owners Helping Owners 7 07-15-2011 06:43 PM
Cracked and Broken Fiberglass Fix it Yourself Highway68 Care and Feeding of Molded Fiberglass Trailers 16 03-20-2010 09:46 AM
How do you fix Fiberglass cracks SharonNDean Problem Solving | Owners Helping Owners 12 02-12-2008 09:46 PM
