Does a 2019 Casita need the fast grey tank modification - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Modifications, Alterations and Updates
Old 02-07-2019, 04:25 PM   #1
Does a 2019 Casita Spirit deluxe need the fast drain modification that Little House Customs offers or has the Casita factory taken care of this issue on the newer models? I've read where this modification can speed up the dump time of the grey water rather significantly. How long does it take for a non modified 2018 model to dump it's grey water tank?
Art
ae6black is offline   Reply With Quote
Old 02-07-2019, 09:09 PM   #2
Borrego Dave's Avatar
Use your trailer a few times to see if the empty time is OK with you before ordering the kit. Hopefully Casita made a change for it to drain better. The mod is easy to install if you decide to add it.
Old 02-07-2019, 09:26 PM   #3
All the many Little House Custom modifications are the result of many years of user field experience and well worth having. Contact the factory and ask them which modifications they are now including. Verify their answer with Orbital Machine Works.
Stephen_Albers is offline   Reply With Quote
Old 02-08-2019, 08:52 PM   #4
MK Evenson's Avatar
Trailer: ,Retro by Riverside RV
Larry told.me.that our 2017 did not need the mod as Casita already made it. I.assume the later.years also do not need it.
Mark
MK Evenson is offline   Reply With Quote
casita
SD | 2019, Aug 25-Sep 1: Inyan 2019 – A South Dakota Rally Hidalga Rallies, Get-togethers, Molded Meets (Archive) 20 09-16-2019 07:27 PM
WA | 2019, May 17-19: Maryhill in May 2019 paulw Rallies, Get-togethers, Molded Meets (Archive) 31 05-21-2019 10:48 AM
AZ | 2019, Feb 4-10: Quartzsite Gathering 2019 Greg A Rallies, Get-togethers, Molded Meets (Archive) 137 05-15-2019 06:26 PM
Draining black tank into grey tank..... Joe & Cherie General Chat 63 04-19-2017 06:35 PM
Hi: I need fast answer on cost of black tank/line freeze damage repair Janine Plumbing | Systems and Fixtures 5 10-14-2007 07:47 PM
