Parkliner fixed! - Page 2 - Fiberglass RV
Old 09-22-2014, 07:59 AM   #21
deryk's Avatar
New Jersey
Roger, its real marine plywood with several coats of varnish to seal it.
deryk
Old 09-22-2014, 08:52 AM   #22
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Even marine plywood should be sealed with something like 3M 5200. Better safe than sorry, and it does not cost much.
Frank
2012 ParkLiner #006
Old 09-22-2014, 09:59 AM   #23
Originally Posted by Sid View Post
I tried to decider that one from my vin number a while back. All I can tell you is that I have the 14 vin number issued in March of 2014. My bet guess it that it is somewhere between #60-#70.
If anyone could help me narrow it down I would be intrested but it isn't killing me.
Sid
Sid, I don't believe the sequential build number is stamped on the trailer. I think the only way to get that information is to ask the factory. Since you are the original owner, it shouldn't take them a minute to check their build schedule, find your name, cross reference to the build number, and tell you what your build number was. I think. If nothing else, it's kind of cool just knowing it.... Dale
War Eagle is offline   Reply With Quote
Old 09-22-2014, 10:03 AM   #24
frank_a's Avatar
Ask the factory all you want folks, but it appears they did NOT keep records. At least that was what I was told. They have no idea what # any of these trailers are, no records. Amazing isn't it?
On the other hand, after dealing with them, I don't doubt they would tell you a number just to keep you happy!
Frank
2012 ParkLiner #006
Old 09-24-2014, 10:11 AM   #25
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Parkliner fixed!
looks great, nice simple mod. I'm thinking of going a similar way just cuz our van now has such nice ground clearance (lifted a bit last spring)...and also...i just like the more "Off Road" capable look of a lifted rig (van/truck) and trailer to match. My one gripe on the PL design was there was no "Off Road" option to lift it from the factory...The stock PL's look quite nice in a low-rider parade
Happy (higher) Trails!
Thom
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Old 09-24-2014, 10:35 AM   #26
Is the area circled welded? I was trying to figure out if the axle drops straight down, or slides out sideways with square tubing nested inside square tubing?
Ken C is offline   Reply With Quote
Old 09-24-2014, 02:26 PM   #27
Raz
Raz's Avatar
Trailer: Trillium 2010
That's the mounting flange on the axle. It's bolted to an L shaped flange welded to the frame. The frame flange has a cut out to accommodate the axle tube. I have the same arrangement on my Trillium.
Looking at that picture, one thing I would recommend is some sort of water proofing on those brake wire crimp connectors. They won't take long to corrode with the ends exposed. Raz
Old 09-24-2014, 02:48 PM   #28
frank_a's Avatar
Ya gotta love ParkLiner. The owner (Chandler) told me not too worry about those unprotected crimped on connectors under the trailer. I did a double dose of Liquid Electrical Tape on all I could find once I got my trailer back from the factory. There's a bunch of unprotected crimped connectors under the trailer, 2 on the right and a bunch on the left. Raz is exactly correct - unprotected, they will corrode quickly if the trailer is used much. Shoddy workmanship in my book.
Frank
2012 ParkLiner #006
Old 09-24-2014, 05:51 PM   #29
Sid
Sid's Avatar
Trailer: Parkliner 2014
Wisconsin
Thanks Raz for the waterproofing suggestion. I went out tonight and did every one that I could find. Better safe than sorry!
Sid
Sid is offline   Reply With Quote
Old 09-24-2014, 06:13 PM   #30
accrete's Avatar
Astoria Oregon
i'm heading to HD tomorrow to pick up a bottle of liquid eTape and have a go at those twisted wires i see under there. good idea!
Old 09-24-2014, 06:29 PM   #31
frank_a's Avatar
You can be sloppy with that stuff too Thom, though after years of use, I'm pretty good now!
I usually do two coats. You'll find it naturally wicks into openings (i.e., the ends of the crimped connections) the first time. I do two coats just because of my compulsive nature.
Frank
2012 ParkLiner #006
Old 09-24-2014, 06:33 PM   #32
On a used trailer do you think maybe corrosion has already started. I would have cut off those connectors and replaced them with new ones that have heat shrink on them
Old 09-24-2014, 06:40 PM   #33
accrete's Avatar
Astoria Oregon
Parkliner fixed!
Frank...i used a similar product to waterproof all the electronics on our RC Rock Crawlers, i just didn't think of doing the same on the PL. Thanks for the polite Whack on the side of my head to do a good thing for the TT.
Old 09-25-2014, 06:21 AM   #34
frank_a's Avatar
No problem Thom. It was one of the first things I looked at. I has asked ParkLiner to do something with them when it was down for the battery movement (and a number of other things that did not get done), but Chandler was not concerned with it at all.
Also, I have found over time that heat shrink tubing will dry out and allow moisture in. I've been using liquid e tape for maybe 20 years, and it does not degrade like heat shrink tubing will. I started using it on my boat restorations years ago, and now use it all the time on about any 12V connections.
Frank
2012 ParkLiner #006
Old 09-28-2014, 06:12 AM   #35
Trailer: Parkliner
Frank, I know you told me about this earlier, do you recommend a particular brand of e tape or are they all just about the same?
Pat
Pat in Michigan is offline   Reply With Quote
Old 09-28-2014, 06:29 AM   #36
frank_a's Avatar
The first one I ever used was Star Brite Pat, but my experience is that they are all about the same. I look for Star Brite when I run out, but can't always find it. Amazon carries it: http://www.amazon.com/Star-brite-Liq.../dp/B0000AXNOD
Take care and give those pups a scratch on the head for me would ya?
Frank
2012 ParkLiner #006
Old 09-28-2014, 06:40 AM   #37
Trailer: Parkliner
Thanks Frank, I will order some today and get myself under that trailer and get that done before winter. I will give all the 4-legged kids a scratch from you……..
Old 09-28-2014, 06:42 AM   #38
frank_a's Avatar
Sounds good Pat. At least with mine, there were two on the right side and 5 or 6 maybe on the left. They're not particularly easy to get to. It helps if the wheels are off when you're doing it.
I hope you and those 4 legged kids are doing great!
Frank
2012 ParkLiner #006
parkliner
ParkLiner Fixed tire rubbing and Battery box!! Gretchen Modifications, Alterations and Updates 5 11-10-2013 11:16 PM
Boler was rear ended - can it be fixed? Brenda M Problem Solving | Owners Helping Owners 19 07-19-2009 12:40 PM
My '82 Burro needs floor fixed or replaced, I need advise MikeCM Modifications, Alterations and Updates 5 03-11-2009 04:28 PM
I FIXED MY HEATER!!!!!!!!!! Flygal Modifications, Alterations and Updates 10 05-24-2008 10:05 PM
74 BOLER: I fixed the door gap. Jayson Wall Modifications, Alterations and Updates 3 05-18-2007 04:26 PM
