My 76 Boler Rebuild - Fiberglass RV
Old 09-09-2016, 09:05 AM   #1
Lercs's Avatar
My 76 Boler Rebuild
I want to start this thread with a little background on how I ended up with a Boler. I have been camping with my wife for a few years and we have always used tents. Earlier this year we were camping at the Grand-Prix of Trois-Rivieres and it started to rain. Usually not to big of an issue as we had a decent tent, but this time I woke up in the middle of the night with rain drops falling on my head. I was also considering getting a new air mattress as ours lost air overnight and made things much less comfortable. I figured instead of spending a few hundred dollars on new tent/mattress I would start looking for a trailer (I was also fed up with sleeping on the ground)
I first started my search looking for a pop-up trailer as I wanted to use my wife's 2000 BMW 323i touring as the TV. Although not rated in the US for towing, it is rated in Europe to tow up to 1500 lbs un-braked and 4000 lbs with brakes. That being said, there was only a class I hitch available on this side of the pond, so I limited myself to trailers around 1000 lbs dry. I started doing my research on kijiji and instead of putting keywords like pop-up or tent trailer, I just did a general search of all trailers in my price range. I saw some nice little pop-ups but nothing jumped out and said "buy me!" This is when I noticed my first Boler. After hours and hours of research on the web (including the Boler buyers guide) I settled on one about an hour outside of Ottawa. It was in the right price range (probably because it needed some/lots of TLC) so I went down to look at it. Attached are some of the pics from the kijiji add.
Lercs is offline   Reply With Quote
Old 09-09-2016, 09:16 AM   #2
Lercs's Avatar
So I went to go check it out in person. The electrical was a mess, the tires were extremely old, the propane was still set up for the old style (so I couldn't hook it up to test it) the axel looked weak, the flooring was laminate and had clearly been water damaged and it didn't have cushions. That being said, I checked out the frame, which looked not bent and had been repaired in some sports by the current owner (who is a welder by trade). He had bought a bunch of new parts for it, including new window cranks, table support, new pump tap, among others. It had the front rock guard and an awning (even though it was attached very poorly) and things looked pretty good.
The excitement got the best of me (I didn't even tick a single thing on the checklist) and I ended up making an offer that was accepted. I backed up my car, hooked up the lights and of course nothing turned on. The owner had ripped all of the wiring out of the Boler and had just twisted things together to try and get it to work. After fiddling around for about an hour we finally got brake/turn signals and running lights to work and I was on my way.
Here is a pic of us on the way home that night.
Old 09-09-2016, 09:31 AM   #3
Lercs's Avatar
Once I got the trailer home, I started to tackle the trailer wiring. Not much to show on that, but I did run new wires from the front to the back of the trailer and now everything is hooked up properly.
I also decided to tackle the AC system. There was a circuit breaker box but it was just hanging loose. There was also an uncovered junction box and some connections just twisted outside of a box. The previous owner had installed a new under-cabinet mounted LED light, but I wanted to run things off of DC so I took that out (It was also poorly wired as seen in the original pics). I ripped out everything I didn't want an simplified the wiring. It is now mounted on the wall (and yes the on and off are upside down), but I have yet to finish it (not grounded). There is also one slot open that I will use for a converter at some point in the future.
I also decided to refinish the stove-top. It was pretty nasty looking and had lots of rust. I spent a few hours sanding and trying to get it to look nice. However, it appeared to be nickel plated steel and the rusty spots looked like they lost their plating. I had some high heat aluminum paint laying around from another project and decided to give it a spray. In my opinion it turned out amazingly! We don't plan on using the stove unless it is a rainy day as we have a grill/stove that I like to use that we usually put on a table outside. That being said, I like things to look nice if we do intent on using them. While I had the stove-top out I also cleaned up the rest of the stove and found a dime, a penny and an earing. Sadly it wasn't diamond or gold so it just went to the trash!
Up next will be handles for the cabinets.
Old 09-09-2016, 09:39 AM   #4
Lercs's Avatar
The previous owner had installed some brass latches that didn't have the proper offset catches (you can see them in the original pics). I don't personally like brass and I don't like when things need a piece of plywood as a spacer to make them work. So I started doing some research to find out what to use that would look nice and not break the bank. The original handles would have been nice to find but they just weren't in my price range. I did a bunch of research on here and the rest of the net and finally found something I thought would look nice. (and they are cheap at only 8.99 a piece)
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
I installed them and they work perfect. I still have some holes that need filing and I plan on painting the cabinets and the doors, just need to finalize the colour scheme.
Old 09-09-2016, 09:45 AM   #5
Lercs's Avatar
I also decided that I needed to take a real good look at the awning. When I checked it out before buying it we just rolled it out and then rolled it back up. I didn't get a good chance to see if it was in good condition.
After setting it up I saw that I needed a good cleaning. One picture below shows the front half cleaned. I don't know what others use as a cleaning product but my favourite for just about everything is Mr. Clean magic erasers. It worked great and it looks almost new again.
And as you can see in the other pic it opens up nicely and I am very excited to use it camping one day.
You may also notice that I have a problem with collecting BMWs. For those that are interested the convertible is a 1986 325i imported from Germany and the one in the garage is a 2007 335xi.
Old 09-10-2016, 12:24 PM   #6
bullfrogeh's Avatar
Welcome to the FGRV Forums, Lercs, from yet another Ontarioan. I've documented 180 of 'active' ON's so far; all in various stages of repair/renewal/restoration, etc.; or, otherwise "on-the-road'. Keep in touch. I know you'll find local help for almost any FGRV issues right here. We're currently working on our Boler - about 2 or 3 hours directly west of Ottawa.
Find yourself; and then others will find you.
bullfrogeh is offline   Reply With Quote
Old 09-10-2016, 12:32 PM   #7
Lercs's Avatar
Thanks BullFrog, I have learned a lot from this site already Hopeing to get out once this year before winter sets in, but there is still lots of work to do! (And money to spend)
Old 09-10-2016, 07:16 PM   #8
Trailer: Trillium
Hi. Welcome to the forum! Just a couple of points you may want to consider.
We bought a 76 Trillium which fortunately was in better shape but still had some of the failings of an old trailer. So:
Our stove top was pitted, not so bad as yours. Someone had already painted it with (?). I stripped this off and was going to paint with hi-temp until both of the major manufacturers told me they didn't recommend it as it is not food safe if food were to come in contact (they do feel it is safe for bbq bodies though, go figure!). I was able to hide most of the pits by using foil inserts for the cups. Have your gas guy evaluate your appliances as well to see if the design is still considered safe.
Have a gas-qualified guy check the stove and any other appliances as well as the line and regulator. If the old owner tinkered with wiring he didn't understand, he may well have tried his hand at gas.
Most of these old trailers have badly rusted connecting bolts/screws between the body and frame. Check 'em out and replace as necessary. One of mine was missing all together!
Randy J. is offline   Reply With Quote
Old 09-10-2016, 07:30 PM   #9
Lercs's Avatar
Thanks, I did read the comments about it not being food safe, but I am not painting my cooking products (ie frying pan) so I think it will be just fine. If food falls out of the pan onto the stove top, I'll just throw it out. I honestly don't expect to use for more than making coffee in the morning anyways, as I have an outdoor grill/stove that I use.
I doubt the propane got used much over the years as it still had the original regulator and pig tail (which has now been replaced) and I plan on leak testing everything before using it (soap and water test). I have checked out all the lines and everything is in good shape.
I do plan on replacing the connecting bolts, it's next on the list of things to do
Old 09-11-2016, 06:35 AM   #10
Lercs's Avatar
up next I wanted to reattach the stone guard. The PO had taken it off and apparently the original hardware was thrown away, but he had bought some scamp hardware to replace it. I also noticed that the PPO (previous, previous owner) had modified the rock guard to work as an awing, but it needed some work to look nicer.
I started by removing the paint and polishing the brass hinges that are used to hold the guard up, then reattached the guard using a combination of new and old parts that I had. For any old parts I have also cleaned them up and repainted them (silver to match the scamp parts)
Below you can see how the awning style works. It seems pretty sturdy. If anyone wants more specific details on how this works, let me know and I can take some detailed pics. I have no clue where to find hinges like this, but I like the fact that they are permanently attached (so I can't loose them). I also used the zip-tie trick to hold them at the top.
Old 09-11-2016, 06:54 AM   #11
Lercs's Avatar
As it seems I have an ADD approach to fixing things, I decided now would be a good time to replace the lights on the upper cabinet and the same time as putting up the peel and stick backsplash.
The lights are IKEA Dioder puck style LED lights. They can either be used on AC or if you cut the cord (after the transformer) you can wire them directly to DC. As I don't want to be dependent on having AC, I will be wiring these to DC. They give off a decent amount of light and they attach with either small screws of double sided tape (both come in the package). For 30 dollars I don't think you could find anything better.
The backsplash is peel and stick from Home Depot. They are sold in 8 sheet packs and my rough measurement said 8 sheets work work just fine... of course I am 1/3rd of a sheet short.. I plan on putting something (maybe some hooks for cooking utensils) in the space that is bare. I put up the first sheet and seemed to be sticking just fine (as I was worried about it due to the ensolite). I continued on and put up the rest.... Once I was done, I sat down to admire my work and that's when the backsplash started to peel off the wall... I quickly went on the search through my home for some glue I could use to get a better adhesion and all I could find is some "quick dry" craft glue. It said it dried clear (which is nice in case my gluing skills were lacking) and it stayed flexible. I peeled back the edges and put some glue down and then held them in place (with small boards to apply even pressure) and it seems to be doing the trick. I will report back after a bit to let you all know if it worked out. If anyone is planning on doing this, I have two suggestions. 1. get a piece of plywood (or acrylic, metal,etc) and cut it to the same size as the wall. Then use the peel and stick on this sheet and then attach the sheet to the wall.. it will likely stick much better. 2. Use some glue in the first place. (even if attaching it to the sheet noted above as it didn't seem that sticky)
The piece of birch between the counter and the cabinet is there to hide the wires. I am not sure if it is the permanent solution, but it works for now. I may replace it with a tube so it looks more original. I'd love to hear your thoughts.
Old 09-11-2016, 07:54 AM   #12
emij's Avatar
Trailer: 2005 Scamp 16
Welcome! I am enjoying reading about your new camper and seeing your restoration!
emij is offline   Reply With Quote
Old 09-11-2016, 07:54 AM   #13
Jay H's Avatar
Trailer: Boler 1300
Grant,
Welcome to FGRV. Looks like you are having a great time working on your Boler. Keep the posts coming, and post lots of pics too!
Lots of info and ideas on this great site and if you have any questions you will get lots of answers.
Jay
Old 09-11-2016, 04:11 PM   #14
Lercs's Avatar
Thanks emij and Jay!
Today it was out with the old and in with the new... Screws that is.
Most came out ok, and some seemed to be quite loose, so I traveled back to home depot and got some #12 screws as well.
I also spent some time re-gluing the backsplash where it peeled up. I am feeling confident that I got the last of it
Tonight will be cutting the mattress time. On the trip to IKEA I also picked up a queen size 4 and 3/4 inch foam mattress. Will be more than enough for the back bed, but unfortunately not enough to do the front as well. For this year I plan on just making some simple covers from left over fabric and next year when the colour scheme is worked out (we are thinking orange?) we will make some nice covers.
Old 09-12-2016, 07:36 PM   #15
Lercs's Avatar
So the bed cutting went well. Below are some of the in progress pics. As noted above, it is a foam mattress from IKEA. I took off the cover, measured, measured again, then cut it with my wife's bread knife.. I am sure she was really impressed... She ended up helping out, so I couldn't have offended her that much. It worked pretty easy, but you have to be very careful not to cut on an angle.
The corners were the hardest part. I marked out where the corners started on the foam (using the cushion template I found here: Cushion Template) Then using a cardboard box, I went out to the boler and cut until the corner fit right. I just kept cutting in small increments. I am sure there is a better way, but this way worked. Then I used the template to trace the corner on the foam. More cutting ensued and maybe a few too many beers, as noted by my foam beard
Also not pictured, but I did end up cutting all the different pieces. I just was testing to make sure all the foam would fit in place.
I also decided that I was going to go camping before the winter set in and booked a few nights at Sharbot Lake provincial park. That gives me the motivation to get things done. Tonight I put the cushions in the original cover in the Boler, just so we can use it this month. I don't plan on using the dinette unless it is raining (and the weather forecast looks good!) Later I will recover them in something nicer.
Old 09-16-2016, 06:51 AM   #16
Lercs's Avatar
Last night I tested two things. 1- waterproofness. I sat with a hose and sprayed down the trailer (also got some soap out, but it didn't seem to get much cleaner ) My wife stayed inside and we found 1 rivet that was leaking. I put some silicone on it for now and will be drilling it out at a later date. It was one of the rivets holding the upper cabinet. Not sure if I want to replace with rivets or screws just yet.
2 - Propane! I put a new regulator (pics below of old vs. new), new pigtail, checked all the lines and then turned on the gas. All looked good and I had my wife there to smell for leaks (as I don't have a sense of smell). I then turned on the stove, after about 10 seconds I could hear gas (or air) coming out and after 20 the burner lit. Very exciting!!
I then moved to the furnace. Put it on pilot, held it down for 30 seconds and tried to ignite.. nothing... I waited 30 more second and I got flame!!! Held the pilot for about a minute, let go and I now have a working furnace! This will make the wife happy as she is cold even when it is 25 degrees C outside.
Finally I moved to the fridge. turned it on, lit my bbq lighter and boom, working fridge as well!
Old 09-16-2016, 02:51 PM   #17
Trailer: Hunter Compact Jr.
USA
I would suggest not using silicone on your fiberglass. It's difficult to remove, and can cause issues with repairs later.
Talia is offline   Reply With Quote
Old 09-16-2016, 03:15 PM   #18
SanMart's Avatar
Trailer: Uhaul
Quebec
Hi, we're new to the forum just a notch away from Ontario in Gatineau. We are working on renovating our 1984 uhaul just purchased about 1 month ago. 4 hours a day. Electrical, floors, gasket around the door, paint, upholstery, ceiling runner....nice project and got plenty of pics
SanMart is offline   Reply With Quote
Old 09-16-2016, 03:36 PM   #19
Lercs's Avatar
How do you suggest sealing rivets?
Also, I have found silicone very easy to remove with the right product (i use goo gone)
Old 09-16-2016, 03:37 PM   #20
Lercs's Avatar
Sounds like fun!
boler
1978 Boler Complete Restoration / Rebuild slavandheather Modifications, Alterations and Updates 250 08-16-2020 12:40 PM
The 1972 Boler Rebuild bomni Modifications, Alterations and Updates 9 10-12-2013 10:13 PM
Newbie rebuild 74 Boler -13 Firesurfer30 Hi, I am.... 1 06-13-2012 06:43 PM
1974 Boler Rebuild KyleRuppel Modifications, Alterations and Updates 33 06-04-2012 09:17 AM
John & Jaci's Great Adventure (Vintage Boler rebuild) John and Jaci Modifications, Alterations and Updates 35 10-10-2011 08:52 PM
