Scamp Bunk Bed Backing - Fiberglass RV
Old 08-22-2016, 07:00 PM   #1
Trailer: Scamp 13
Connecticut
I just purchased a 1980 Scamp 13 and it has the couch/bunk bed cushions, but they are not attached to the trailer to prop up and make the bunk beds. The couch back is supposed to be the upper bunk, but how does it attach to the wall and what is inside the upholstery cover to make it into a hard flat bed - plywood?
Any photos would help. Thanks!
Robin112 is offline   Reply With Quote
Old 08-22-2016, 09:38 PM   #2
Gilda's Avatar
Trailer: 2011 Scamp 13'
Sorry, I don't have photos of my bunk and my Scamp is stored 1 hour from my home. This posting on FGRV may help. I found it by seaching on this forum with the "Search" button at the top of the screen. Click and hold on the Seach button for a drop down menu. Go to the bottom to "Search Site/Google" and write in the words "Scamp bunk". You will find lots of posts there.
http://www.fiberglassrv.com/forums/f...nts-66409.html
The Gleeful Glamper
Gilda (Jill-da)
"Here we go again on another amazing adventure"
Gilda is offline   Reply With Quote
Old 08-23-2016, 07:02 AM   #3
Jon in AZ's Avatar
Robin, post #4 in this thread has details and pictures of the upper bunk:
http://www.fiberglassrv.com/forums/f...ons-72253.html
The plywood platform you'll have to make yourself. The trick is making a cardboard template first. Tape it to the ledge and swing it up and down. In the down position it should rest on the fiberglass base at a slight angle (i.e., it stands out from the front wall about 3-4 inches). The wings fold slightly to accommodate the curved corners of the shell. In the raised position, it should fit the curve of the shell. Mine has perhaps a finger width gap all the way around. Remember that the fabric cover will increase its dimensions slightly.
The offset hinges are available from any hardware store. The support posts, if you don't have them, can be ordered from Scamp, or you can make them from readily available materials using the measurements in the linked thread (or have them made- Scamp's design requires some welding). The rings on the bottom bunk can also ordered from Scamp, but I believe they are standard shower curtain rod trim rings.
Before you do anything, make sure the mounting ledge under the front window is solid. If there has ever been a leak in the front window, it's possible the wood inside that fiberglass-encased, rat-fur covered ledge may be rotten, and then you have a bigger project on your hands.
Best wishes!
new scamp owner... what are the wires on the backing plate of axle? ampline Problem Solving | Owners Helping Owners 13 08-09-2012 10:11 PM
Backing rgrugg Towing, Hitching, Axles and Running Gear 41 07-09-2011 12:00 PM
Backing up a trailer Kevin K General Chat 29 03-12-2009 11:19 AM
Backing Trailers Pete Dumbleton General Chat 6 07-17-2007 03:10 PM
Backing in to hook up Legacy Posts Problem Solving | Owners Helping Owners 13 06-22-2003 01:42 PM
