MA SOLD: 2006 - 17' Casita Spirit Deluxe - Fiberglass RV
Old 08-27-2017, 09:24 AM   #1
Massachusetts
2006 - 17’ Casita fiberglass Spirit Deluxe camper - $14,500
In really great shape – in and out. Never in an accident and low mileage. Probably less than 2,000 miles overall. This has most all of the factory options plus many after market options that make this great trailer even better than when it came off the factory floor. I am an engineer and I spent a great deal of time and effort to make this a very reliable and efficient trailer for dry camping or in a campground. High energy solar panels or 120VAC with a deep cycle AGM battery make this a breeze to use.
I’ve tried to list everything but I’m sure I’ve left something out. This is ready to go. We just took our last camping trip this month to Maine and thoroughly enjoyed it. The Casita performed flawlessly.
Spirit Deluxe is designed for 2 to 3 people who enjoy exceptional comfort. Casita Travel Trailers makes it easy to convert the two sleeping areas into dinette tables. Dinette positioning options create even greater enjoyment during meals: you can leave the rear dinette in the double bed position permanently and use the side dinette for eating. Roomy bath and shower too.
Also has a custom full time double size mattress for the rear area (shown in photos). This is a very comfortable way to use this camper. It has the original dinette and cushions as well.
Easy to use with full hookups in a campground or…
Easy and efficient for multiple day dry camping without hookups.
Simple sleep/dine converting options
Spacious bath and shower
Running gear/chassis
15” Tires & Wheels
High Lift Axle – 3” lift with Dexter Torflex lift kit
(from Orbital Machine Works – much greater ground clearance)
Spare Tire w/cover
Electric brakes
Safety chains
Stabilizer jacks
Manual tongue jack – new
Friction anti-sway control with anti sway adjustable ball mount & ball (for a 2” Receiver)
Lug wrench
Outside
2 piece – no leak custom marine grade fiberglass body
Locking outside storage compartments
Exterior door light
2 – 20lb gas bottles & cover
Automatic changeover gas regulator
License plate holder with light
LED running/tail/stop/backup lights
City water connection
30 amp service cord with many other adapters
Outside marine grade electric service connection upgrade
Locking power cord/solar cord hatch
Locking portable water tank hatch
New AGM 12V deep cycle no fill battery
120 V exterior outlet
Bubble levels
new Sunbrella fabric whole trailer cover
Inside
Wrap around overhead storage
Plush carpet lined storage
12V LED lighting – high efficiency – warm white
12 V outlet
2 – USB outlets for charging
1 – Pure Sine wave high efficiency AC outlet
(inverter supplied from 12V)
Vinyl flooring
Opening screened windows
Mini blinds
Wardrobe chest with removable shelves/bins
Fantastic power fan roof vent with thermostat
Upgraded proper AC to 12V DC converter and battery charger
High efficiency portable solar panels with charger built into system
Voltage & current monitoring readout to monitor battery status
(Designed to properly charge and float charge AGM batteries and others.)
Deluxe insulation
Screen door
Locking main door
Bathroom & plumbing
Marine grade fiberglass bathroom shower
Lavatory – with upgraded faucet and controls
Handheld or wall mounted upgraded shower head
Toilet
Opening, screened bath window w/ privacy glass
Opening 12V vent with fan
15 gallon black water tank
25 gallon gray water tank
16 gallon fresh water tank
new gas water heater with upgraded switch and electronic ignition.
Water heater bypass valve
12V demand water pump
new sewer hose – high end
sewer hose storage in rear bumper
Kitchen & Appliance
Power Range with hood, fan & light – vents to the outside
Range cover
Sink cover
Two burner propane cooktop
Silverware drawer
Microwave oven –or- remove or for extra storage
3 way refrigerator (AC,DC, propane) – upgraded to high efficiency – works very well
roof mounted A/C with heater
16,000 BTU propane furnace
TV antenna wiring and outside jack
Shelf
Water hose
Blow out connection
Hot water tank cleanout wand
Upgraded high quality cabinet latches
Wasp guard on furnace vent
3 way switch for outside door light – turn on/off inside or outside
Safety
smoke/CO detector
propane detector
safety egress window
fire extinguisher
safety breakaway switch
safety chains
dead bolt door lock
GFI electrical circuit
Other – not installed
Max air vent cover
Little House Customs – double step kit
Outside shower kit
Lots of spare parts and miscellaneous camping gear – negotiable
jeffreym is offline
Old 08-28-2017, 09:52 AM   #2
Trailer: Scamp/Casita Shopping
Vermont
Hi
Can you advise where in MA? And if you have manuals (I'm a newbie)? I'm also curious about the weight and what you have used to tow.
Best,
Kim
kkjones is offline
Old 08-28-2017, 09:55 AM   #3
Massachusetts
I have all the manuals for the trailer and appliances. It's very easy to get your hands around. I am on Cape Cod - West Barnstable to be specific.
jeffreym is offline
Old 08-28-2017, 09:58 AM   #4
Massachusetts
I forgot. I have towed it with a Toyota Tacoma, a Toyota Tundra and a Chevrolet Silverado. The trailer is light - about 2,500 lbs. The tongue weight is about 300 lbs. I have a brake controller installed in all the trucks that I used to haul it. The brakes in the trailer are very good.
jeffreym is offline
Old 09-09-2017, 03:23 PM   #5
Trailer: currently shopping
New Hampshire
Hi Jeff, is the camper still available. If so can you email me at peter.faletra@gmail.com
peterf is offline
Old 09-09-2017, 03:43 PM   #6
Borrego Dave's Avatar
Jeff, if you run it across a scale you'll find out the 17s come in at 3200-3300#s with roughly 400#s on the tongue. The posted dry weights from the builders are before anything is added to the rolling shell .
Moderator note: The Casita Weight Discussion has been moved to a new thread in General Chat.
Borrego Dave is offline
Old 09-12-2017, 05:06 PM   #7
Trailer: 1975 trillium 13ft
Saskatchewan
Is this still available?
The Enns is offline
Old 09-23-2017, 08:13 AM   #8
Massachusetts
SOLD
Casita is sold
jeffreym is offline
casita
IN | SOLD: 2006 Casita Spirit Deluxe $11700 Rich Law Classified Archives 2 04-25-2017 09:56 AM
TX | SOLD: 2006 17' Casita Spirit Deluxe $12,500 obo Kenny L Classified Archives 1 02-17-2016 07:37 AM
CA | SOLD: 2006 17' Casita Spirit Deluxe $13,900 Lee S. Classified Archives 17 07-07-2015 07:13 AM
SOLD - 2006 Casita Spirit Deluxe 17' L Schmidt Classified Archives 1 02-18-2009 04:18 PM
SOLD - 2006 16' Spirit Deluxe Casita, $6,000 DougD Classified Archives 4 11-12-2008 12:45 PM
