Rivets or bolts - Fiberglass RV
Old 09-08-2017, 01:38 PM   #1
mensie's Avatar
Rivets or bolts
I have gutted my boler and removed the shell off its frame as she is going to get a complete new undercarriage.
So when I removed some items they were screwed on to the shell with small machine screws.
Were all cupboards , kitchen counter screwed on with these screws originally or were they riveted to the body.
if riveted what kind of rivets would you use so it is water tight.
Old 09-09-2017, 05:23 PM   #2
I replaced nearly all of my rivets with stainless bolts. For the exterior washers, I bought a box of screws used to install metal roofing. They come pre painted with a metal washer with a rubber gasket attached. Just remove the washer from the screw. As long as you can live with the limited colour selection, they work great. I went with black on my bright yellow exterior. Been 3-4 months and so far no leaks at all. Up here it rains way more days than not, so it's been a good test.
Bootsy is offline   Reply With Quote
Old 09-10-2017, 11:46 AM   #3
Trailer: Trail Cruiser
Screws, rivets or bolts will depend on what you need to achieve. Screws are fast and easy to use but have limited holding power. Rivets are stronger, harder to use and harder to remove if you have to at a later date. Nuts and bolts are the strongest, usually more expensive but can be removed easily.
I use all three, depending on the application.
Mike_L is offline   Reply With Quote
Old 09-10-2017, 06:49 PM   #4
Borden's Avatar
Name: Borden and Carole
rivets hold very well and can be water proof
I am replacing all rivets with closed end marine rivets; got them from Spaenaur in Kitchener Ontario; aluminum same size as original rivets.
https://spaenaur.com/products.asp also purchase some other parts from them for our boler
Will have to go to a scales to see how much weight i have added so far to the trailer with my rebuild. Have make some items stronger as a carpenter can not help myself lol
Our postage stamp in heaven.
Borden is offline   Reply With Quote
Old 09-12-2017, 09:56 AM   #5
bullfrogeh's Avatar
Thanks for the lead to Spaenaur in Kitchener. I've been agonizing over what to replace my rivets with. This Ontario lead is appreciated by my Earlton '73 Boler.
Find yourself; and then others will find you.
bullfrogeh is offline   Reply With Quote
Old 01-09-2018, 08:45 AM   #6
mensie's Avatar
Anyone know what size rivets were used for the windows?
Old 01-09-2018, 11:13 PM   #7
Trailer: Casita 16 ft
The main reason given for using pop rivets with fiberglass is they will break away when they need to. If there is undue strain on a particular fastner, it is better to have a rivet pop than to tear a hole in the fiberglass.
If using screws, be sure to use washers or some other method to avoid high stress in a small area and spread the strain to more than one fastener.
An air operated rivet gun makes the application a lot easier.
For vent covers, etc. that need to be removed occasionally, install the little inserts that look like a cocklebur and have internal threads. Look up "Nut inserts for wood". Put some epoxy on them before inserting. Use stainless steel screws.
Friz is offline   Reply With Quote
boler
Bolts (screws) vs. rivets in Scamp repair? Timber Wolf Modifications, Alterations and Updates 31 12-14-2019 05:05 PM
Rivets Bolts and Other Fasteners jdconnel Problem Solving | Owners Helping Owners 2 03-24-2016 10:38 AM
Nuts n' bolts instead of rivets? dylanear Modifications, Alterations and Updates 20 05-31-2012 01:57 PM
bolts breaking April Wilcox Towing, Hitching, Axles and Running Gear 11 11-18-2008 04:12 PM
Nuts - Bolts % Other HDW Darwin Maring Problem Solving | Owners Helping Owners 1 05-09-2007 06:03 PM
