17 boler replacing black tank or repairing - Fiberglass RV
Old 11-11-2014, 10:06 PM   #1
Trailer: 17 boler
i need to replace or repair my black tank in my 17 boler.
i think its a LDPE tanks, does anyone know? its light grey and original
any suggestions on how to repairs a crack?
or is it best to replace, if so any idea on where to locate a tank?
thanks
Andrew
andrew78 is offline   Reply With Quote
Old 11-11-2014, 11:43 PM   #2
Borrego Dave's Avatar
Hi Andrew, it depends on the type of crack for ease of repair. A more less straight crack you want to drill a hole at each end to keep it from continuing on cracking. RV supply sites sell a two part epoxy for black and fresh water tanks. Not sure what the gray color means for a black water tank, maybe nothing. I've used the epoxy for repairs before and they worked fine and were easy to do.
Old 11-12-2014, 05:10 PM   #3
Trailer: Scamp 13
For LDPE you will have to weld it.
Plastic Welding Kit
If you use this unit you must follow the cool down cycle in the instructions or you will burn out the unit.
You will also have to purchase some LDPE welding rod. available online.
there are videos on u tube for plastic welding.
Nothing sticks for very long on Ldpe or Hdpe welding is the only viable solution.
Old 11-12-2014, 08:07 PM   #4
Trailer: 17 boler
thanks guys, i read about the welding but was hoping i had another option
Old 11-13-2014, 06:16 PM   #5
Dan Meyer's Avatar
Trailer: 2000 Scamp 16 ft Side Dinette
What are the external dimensions of your holding tank? Have you priced a replacement tank?
-- Dan Meyer
Dan Meyer is offline   Reply With Quote
Old 11-13-2014, 06:49 PM   #6
Trailer: 17 boler
i found a company in alberta from an old postRBW1531-2.pdf. new tank, same measurements and hole location as the old one (you specify where you want the holes).
it was $220 plus shipping.
i thought about fixing the old tank, but was worries since the tank is 30 years old and is inside the trailer and if it ever leak again it would cause more than $200 damage it was better to invest in a new one
i will let you know how it turns out, should be here in less than a week
boler
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 7 08-02-2020 08:44 AM
Replacing or Repairing Windows on 1985 U-Haul Britt Dean Problem Solving | Owners Helping Owners 9 11-13-2009 12:37 PM
17' Boler Black and Gray water tank size kevin61 Care and Feeding of Molded Fiberglass Trailers 1 08-30-2009 11:09 PM
17' Boler Black Water Tank Dwight Burditt Problem Solving | Owners Helping Owners 6 04-18-2008 09:16 PM
About repairing or replacing the floor or frame . . . peterh Problem Solving | Owners Helping Owners 8 03-24-2008 07:54 PM
