It Started as a Kitchen Reno- Project Boler - Fiberglass RV
Old 04-09-2012, 09:09 AM   #1
Ian G.'s Avatar
This is the story of how simply buying a 1974 Boler trailer has turned into an obsession, and like many renovation projects has grown far beyond the initial plan.
Let me start with some background.
We live in Calgary Alberta, our back yard is the Canadian Rocky Mountains which has some of the best scenery and camping in the world. As a family we have enjoyed camping trips throughout the summer months, sitting around the campfire, hiking the many trails and sleeping in a tent. As my wife and I get older the idea of packing and unpacking the car, setting up the tent, crawling around on the ground and the hardest part, getting up off the ground in the morning it was time to get something a little more comfortable.
Like many I have always noticed the unique look of the Boler trailer and in January of 2011 I found a 1974 Boler 1300 in reasonable shape.
No sure how the Boler was maintained so I gave it a once over before our first trip, replacing & repacking wheel bearings, new tires on aluminum rims, replaced all the propane hoses, regulator and tank. I also added 12 volt power with a water pump and LED interior lights. My wife was busy with the decorating adding the new curtains. We were ready for our first outing on the May long weekend, the trailer worked great we were comfortable and warm but … we quickly realized that a kitchen with about 8 inches of counter space was a challenge and as we left the campground one of the rear lights stopped working, so the modifications began.
Old 04-09-2012, 09:10 AM   #2
Ian G.'s Avatar
As soon as I got home from that trip I rewired the entire trailer and replaced all the exterior lights with LED units, no more lighting troubles. The next challenge was the lack of counter space. Since our children are older we only needed the Boler to sleep two people, the decision was to remove the front couch and install a counter and larger sink in that location.
I banged together a quick plywood counter and installed it as a trial, for the rest of the summer it worked great although it was almost too much counter space now.
With summer ending I brought the Boler in to prepare it for the long winter, but I got carried away. Before I knew it the entire interior was stripped, not a cabinet, cupboard or bench was left. I had drawn up some new floor plans, now for the rest of the winter I had to build all new cabinets, structural support for the roof and cushions.
Old 04-09-2012, 09:15 AM   #3
Ian G.'s Avatar
Adding to the work I noticed that something just didn’t look quite right with the frame so why not take the fibreglass egg off the frame to inspect it a bit closer, am I ever glad I did.
The original frame was not in good shape, from the Boler factory most of the cross members were only welded on the sides not the top or bottoms,
the remaining welds were very poor quality. The light metal of the frame had broken at one time and had a reinforced repair, the main left frame rail was bent and cracked at the axle and all of the mounting bolts and screws were either pulled out or loose.
Old 04-09-2012, 09:20 AM   #4
Ian G.'s Avatar
A new frame had to be built, reading many of the posts on this site I decided to make the frame considerably stronger and install a new FlexiRide axle with brakes in a trailing arm configuration. The design of the new frame is radically different than anything I have seen on the internet, being as the frame needs a dropped section which means cutting the right frame rail I wanted to ensure strength was not compromised. The new frame consists of custom bent 2”x6” “C” channel made from 1/8” or 0.125” steel, the original frame was 1.5”x3” 0.0625” or 16 ga rectangular tube.
Cross members in the new frame are 2”x3”x0.125” rectangular tube with boxing added to the frame in critical areas. Now I know many of you are thinking “how much does this frame weigh?” The original Boler frame with axle (no brakes) and tires weighed 300 pounds, the new frame with a 2000 pound axle with brakes, and the same tires weights 395 pounds. The brakes alone account for about half the additional weight and the strength of the new frame is considerably more.
The pictorial journey:
New frame rails set on original frame
Close up of 2"x6"x1/8" frame rail
Welding frame
Sandblasing new frame
Old 04-09-2012, 09:22 AM   #5
fidgetboy's Avatar
Trailer: Boler 13' 1973
Looking good keep the the photos coming.
fidgetboy is offline   Reply With Quote
Old 04-09-2012, 09:26 AM   #6
Ian G.'s Avatar
Now the new frame is ready for painting.
A coat of epoxy primer is followed by 2 coats of 2 part polyurethane
The FlexiRide 2000 pound axle is also installed
Old 04-09-2012, 09:30 AM   #7
Ian G.'s Avatar
Finally the fiberglass egg is mounted back on the frame.
I bought small 8" wheels and tire that easily allow the trailer to be put into the garage. these tire are NOT used on the road at all.
Old 04-09-2012, 09:42 AM   #8
Raz
Raz's Avatar
Trailer: Trillium 2010
Funny how one thing just leads to another. Very nice job. Thanks for sharing. Raz
Old 04-09-2012, 10:18 AM   #9
Robin G's Avatar
Trailer: 2007 Casita
Ummmm, I realize this started as a "kitchen" reno, but lead to other issues. but I gotta ask, no interior pics?
Oh and it's such a cute trailer, glad you are taking the time to do a full blown reno.
Robin G is offline   Reply With Quote
Old 04-09-2012, 10:18 AM   #10
Thomas G.'s Avatar
Nice work. You have done an amazing amount of rebuilding and replacing.
Old 04-09-2012, 10:22 AM   #11
Ian G.'s Avatar
Originally Posted by Robin G View Post
Ummmm, I realize this started as a "kitchen" reno but so lead to other issues, but I gotta ask, no interior pics?
Interior pictures are coming, I will be keeping this thread updated regularly.
The kitchen cabinets are all built, installation and pictures will be within the next few weeks
Thanks, my wife thinks I am crazy. The only part of the Boler which will remain original is the fiberglass shell, everything else will be new or replaced.
Old 04-09-2012, 10:26 AM   #12
Ian G.'s Avatar
As a tease here is an idea of the floorplan.
Bed will be a true double at 54" wide
Old 04-09-2012, 10:29 AM   #13
Robin G's Avatar
Old 04-09-2012, 11:06 AM   #14
David Tilston's Avatar
That is quite a frame. You obviously have some skills. What axle capacity did you select?
Old 04-09-2012, 11:08 AM   #15
jen b's Avatar
Trailer: 1980 13 ft. burro
Nice work! That floor plan inside is pretty cool, too. Looking forward to more!
jen b is offline   Reply With Quote
Old 04-09-2012, 11:12 AM   #16
Ian G.'s Avatar
It is a 2000 lb Flexi-Ride axle with the trailing arms set at 10 deg up.
The Boler rides just over 1" higher than the original frame sitting on the original worn out Ingersole Rub-R-Ride axle
Old 04-09-2012, 01:23 PM   #17
Thomas G.'s Avatar
That is quite a frame. You obviously have some skills. .........
Yea, from the vertical section, I'd say it is good for about 20,000 pounds.
Old 04-09-2012, 01:46 PM   #18
Ian G.'s Avatar
LOL yup that is what I thought too
Considering I needed a 6" drop in the floor to accomodate the step floorpan and axle location this design was the strongest, lightest and easiest to fabricate. I told my wife that if she ever wants a 32" trailer we have the frame for it.
Old 04-09-2012, 01:57 PM   #19
Trailer: 1978 Trillium 4500
Wow. Nice work. Extremely strong frame.
thanks for the detailed pictures.
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 04-09-2012, 02:01 PM   #20
You are preaching to the chior. I'm crazy too. I told my wife that I was going to replace every screw and rivet ( I thought I was exaggerating...turns out I wasn't)
Cheers
--Fred and Natalie
boler, cabinets, custom, frame, renovation
76 Boler Reno/Rework kgingeri Modifications, Alterations and Updates 102 11-23-2021 06:05 PM
Boler reno help needed randyl Modifications, Alterations and Updates 18 05-19-2012 10:09 AM
Boler Reno Don A Modifications, Alterations and Updates 1 03-25-2011 09:40 AM
Started gutting the 74 boler....pics! thenoob Problem Solving | Owners Helping Owners 21 10-13-2010 09:30 AM
Finally started on the Boler American CliveAlive Modifications, Alterations and Updates 5 10-18-2006 11:18 AM
