1974 Boler Resto. Oops, I did it again... - Fiberglass RV
Old 05-06-2012, 06:17 PM   #1
Robert Johans's Avatar
Trailer: 1988 Scamp 13 ft and 1982 Perris Pacer 13 ft
Picked up this 74 Boler from a private party here in my town. The price was quite good, comparatively speaking. The PO had done a fair amount of work cleaning the inside out, which saves me a lot of work.
Robert Johans is offline   Reply With Quote
Old 05-06-2012, 06:19 PM   #2
After removing the FG cabinet components, I discovered that a FG strip covering the inside seam of the belly band looked funky, so I whipped out my handy Dremel MultiTool and dove in. Sure enough, there was plenty of evidence of leaks through the belly band. Outside, under the band, was a load of caulk/silicone squeezed in between the two shell components.
I had never seen a belly band seam failure before, but this very poor fix was not gonna fly.
Old 05-06-2012, 06:23 PM   #3
After removing the inside FG "patch" covering the seam all around, then working on removing the junk under the belly band from the outside, there wasn't much holding the two shell halves together.
So, here's a look at one of our trailers that I've never seen shown here on the FG Forums before!
Old 05-06-2012, 06:31 PM   #4
Hot tub! Oh wait, you'd have to fill all those holes. Are you building this for a customer Robert? What a great opportunity to make a taller Boler. This is going to be another GREAT build to follow.
Old 05-06-2012, 08:55 PM   #5
Cyndivg11's Avatar
Trailer: Trillium 1972
That is amazing work! Funny how our trailers motivate us in the strangest of ways.
Cyndivg11 is offline   Reply With Quote
Old 05-06-2012, 09:38 PM   #6
Trailer: 1978 Trillium 4500
Hot tub!
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 05-06-2012, 09:54 PM   #7
Trailer: ,Bigfoot 25 foot plus Surfside 14 foot
Yowzaa!
What an opportunity to make a complete new set of molds to be able to make any and all parts you may ever need - including entire new hulls!
BCDave is offline   Reply With Quote
Old 05-06-2012, 11:58 PM   #8
Trailer: 1981 Boler
Sarnia, Ontario
If I had the opportunity to have a boler in the state that one is currently in, I'd be making molds also.
would be amazing to start making them again in canada for a reasonable price.
idiotsniff is offline   Reply With Quote
Old 05-07-2012, 12:25 AM   #9
Trailer: 2010 Scamp 16
Wow talk about starting from the ground up! Neat picures, hope to see more as you make progress.
Old 05-07-2012, 06:38 AM   #10
Thomas G.'s Avatar
You need to quit nibbling around at the edges and really get into it.
Old 05-07-2012, 07:21 AM   #11
Night Sailor's Avatar
Trailer: Bigfoot 3000 & Barth "slide-in" truck camper
Connecticut
I was thinking about a carbon fiber Boler. Carbon is 1/3 the weight of fiberglass. What does all the fiberglass weigh?
Night Sailor is offline   Reply With Quote
Old 05-07-2012, 09:32 AM   #12
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Cracked open like a soft boiled egg! You must be Yoking!:
Spanke
Trilliums Rock!
Spanke is offline   Reply With Quote
Old 05-07-2012, 09:54 AM   #13
Trailer: Boler and U-Haul
I have also thought of carbon fiber, but wonder what it would cost.
Al
Alan Ursacki is offline   Reply With Quote
Old 05-07-2012, 01:52 PM   #14
Carol H's Avatar
Originally Posted by Alan Ursacki View Post
I have also thought of carbon fiber, but wonder what it would cost. Al
Well if the new bike I purchased last year that has only some carbon fiber frame parts on it is any indication I am not sure we really want to know the answer to that. Suspect it would make an Escape look like an even better deal than they do now... in fact I think you might actually be able to purchase one of each size of the Escapes for less than one carbon fiber trailer and you probable could buy a couple of new tugs to go with them
Old 05-07-2012, 03:03 PM   #15
Trailer: 1981 Boler
Sarnia, Ontario
I have been thinking the same thing for years. would be amazing. but expensive seems to be the trend on carbon fiber.
Old 06-16-2012, 09:52 AM   #16
I've been steadily, if slowly, making progress on the restoration of the fiberglass shell of this 74 Boler. When last we visited, the top half had been removed from the bottom. In the interim, I discovered that the seams holding the floor pan to the bottom shell were also in very bad shape. So, again, out came the Multi-tool and the two forms were separated.
Flipping the pan over revealed a lot of problems with the 38 year old floor construction. Weaknesses in the original FG had allowed some of the wood "stiffeners" to warp and rot over the years.
All the bad wood was cut out and replaced with new lumber. All vulnerable areas of the FG were reglassed.
Old 06-16-2012, 09:58 AM   #17
We've put the floor pan and the bottom shell back together and reglassed the entire inner seam. Then we flipped the unit back over to get to the underside again in order to reglass that same seam from underneath. Absolutely no chance of water infiltration, and tremendous shell strength integrity.
Old 06-16-2012, 10:06 AM   #18
I had a new frame built. A spare tire carrier is integrated onto the rear bumper. It will go to the powder-coater next week.
A new Dexter Tor-Flex axle with e-brakes has been mounted to the frame. Because I choose to run 15" wheels and tires, I have 10" (rather than standard 7") brakes for extra stopping power.
Old 06-16-2012, 10:14 AM   #19
I've discovered that one of the hardest issues to resolve with these restorations is getting a really good fit between the shell and entry door.
With the shell in separate pieces, we were able to lock the door and the bottom shell together, more or less forcing the two pieces to conform tightly, before any of the reglassing was done. When the new glass dried and hardened, the curve of the door and shell were as close as we could hope to get them.
Old 06-16-2012, 11:06 AM   #20
Trailer: 13 Trillium
cracked egg
Spanke
Good One! I needed that!
lhanna is offline   Reply With Quote
boler
new boler owner resto Siris Modifications, Alterations and Updates 72 08-18-2014 05:23 PM
73 Boler interior resto Burke R. Modifications, Alterations and Updates 41 03-24-2014 08:54 AM
AB | old boler resto project for sale $1000 Siris Classified Archives 3 08-16-2012 04:48 PM
Shower in 1974 Boler Resto David Konduc Modifications, Alterations and Updates 8 02-04-2012 03:15 PM
Our 75 Boler resto also Debbie H Modifications, Alterations and Updates 5 03-24-2008 01:41 PM
» Trailer Showcase
Ferris
AoifeNY
Beastie
BobB
