Scamp Brake Drums Not Centered? - Fiberglass RV
Old 07-15-2014, 06:31 PM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
Hi,
I'm hoping there's some really smart axle and brake people here tonight to help with this question. I have a 2012 scamp 13er with electric brakes. I've noticed that what I believe is the drum does not have equal spacing/distance all the way around the wheel. It is more "bowed out" near the bottom of the tire and sits more flush as you head your eyes up the wheel near the top. This is exactly the same phenomenon for both drums, both wheels.
Bearings and spindle were both recently inspected and were perfect. Trailer brakes normally, plenty of "fist clearance" between tire and wheel well, trailer tows normally and doesn't dog-leg. No drag or funny noises. Is this a normal thing?
Pic is hard to see I admit but it's 830 at night and best I could get. As I said, same on both sides.
Would somebody enlighten me please?
Wendy
Old 07-15-2014, 06:34 PM   #2
CampyTime's Avatar
Forgot pic...Click image for larger version
Name:	ImageUploadedByFiberglass RV1405470841.354960.jpg
ID:	73703Click image for larger version
Name:	ImageUploadedByFiberglass RV1405470858.193519.jpg
ID:	73704. I know they're dark but I'm hoping a skilled eye can see what I mean!
Old 07-15-2014, 07:18 PM   #3
Paul O.'s Avatar
She is really paying attention to details...
The first pic seems to show the lighter gray part that has the ridges in the direction parallel with the axle. That is the drum itself as far as I can tell. The other parts are the backplate that is stationary and it supports the axle, the bearings, brake shoes, the electromagnet, etc, etc. The design of the stationary parts does not have, nor does it need, much of axial symmetry. The rotating parts should be symmetrical, or at least well balanced. It is good that both sides are identical, and they should be symmetric, left hand right hand. Looking at both sides and comparing them is always a good idea when figuring things out! I would say you have good brakes. By the way the ridges on the drum are there for strength, increased surface area and turbulent airflow for better cooling.
BTW, I try to use the brakes as little as possible when towing on dry roads, downshift whenever practicable.
Paul O. is online now   Reply With Quote
Old 07-15-2014, 08:08 PM   #4
CampyTime's Avatar
Thank you Paul. I feel SO much better after reading your post! I would like to ask you to refer to my first picture, if you would. You mentioned a backing plate. I don't think that this is near the upper part of the drum (I wanna say that what I see there is the aperature for the trailering arm?). I suspect what you mean the backing plate is IS THE PART I've been worried about...The part that is rather "bowed out" on the bottom of my pic, near where the brake electric wires are?
Anywho, what I gather from your post (and I am definitely not a mechanic, just a curious person) is that having axial symmetry for the stationary parts (part I'm worried about) is not as important as having symmetry or balance for moving parts (e.g. drums). Do I understand that correctly?
Been a nervous wreck, let me tell ya. I'm a single gal and nowhere near as smart as some of the ladies on this forum who blow me away with the stuff they know. At any rate, bless you and thank you for your care and help!
Old 07-16-2014, 09:48 AM   #5
Paul O.'s Avatar
I might be going out on the limb, but I would not expect any failures in the area of the trailing arm, e.i. bending in some way. If that happened, the left and right would be quite different, and something else would be damaged as well, in a big way.
The wheel rim and the brake drum pretty much have to be designed with axial symmetry, the back plate and the stationary parts do not. I would defer to the guys who checked the brakes and bearings for you, that should give you peace of mind. Enjoy the travels.
Old 07-16-2014, 10:27 AM   #6
Roy in TO's Avatar
I lightened up one picture. Looks like the backing plate is what the OP is concerned with.
(hint flashes help in dark spots)
Old 07-16-2014, 10:51 AM   #7
CampyTime's Avatar
Thank you Roy. I never thought to do that. I sort if figured it wasn't the drum but didn't know what else to call it.
So you both can see there how the bottom of the backing plate "sticks out" more than the top for want if a better way to out it. More flush and "centered" as your eye heads up toward top of drum.
I sort if thought this might be a normal phenomenon and with my pea brain attributed to do something with torsion axle, camber I've read about, etc. but I made that solution up in my head.
My trailer was in a roadside front accident with original owner. FG repaired at Scamp factory. I guess I always assumed they would have checked all systems but I have no clue. With both sides the same EXACTLY, I couldn't quite make my brain accept it was accident damage. I would have noticed something less symmetrical or not quite right.
I guess! Keep those thoughts coming cuz this gal loves learning!
Cheers,
Wendy
Old 07-17-2014, 09:37 AM   #8
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
I really don't think you have anything to worry about Wendy. Most of the modern electric brakes have a stationary backing plate that is somewhat 'sculpted' when cast or formed, to have recesses for different parts of the braking system (magnets, springs, etc) mounted on them. These parts interact with the rotating drum to provide the braking power you need. I've attached a pic of the 'brand new' drum/backing plate of the new Dexter 2K axle I installed on my '84 Scamp 13. I was able to get a pretty good 'shot' but at certain angles it does appear to be 'bulged' or 'uneven' with the drum. Pretty sure it's just a matter of perspective or angle of view. Some mfgr's may even add a plate or cover of some kind to protect the holes that the wires for electrical power to the brakes come thru. Appears to me that may be what you're seeing or the backing plate may actually be 'offset' a little from 'square' with the drum...
Harvey is offline   Reply With Quote
Old 07-17-2014, 10:57 AM   #9
CampyTime's Avatar
Just looked at your pic and your backing plate appears squared with the drum quite nicely, as compared to mine.
I'm going to take to my mechanic Monday anyway. After trying to adjust my brakes with a friend, they are now too touchy and I barely had the brake controller increase thumb wheel turned one full turn. Unless they were way off before.
Jacked trailer, turned adjuster wheel till tight and backed off 5 clicks till a teeny bit of drag was felt. I just wNt him to check the work. I guess I won't worry about plate but do you want me to try another shot? It's broad sunny daylight now.
Old 07-17-2014, 11:26 AM   #10
Arkansas
Wendy, a good, clear pic of the backing plate & drum relationship would be helpful but, in looking at Roy's 'lightened' pic again, it does appear that the backing plate & drum in your pic are not in alignment. If the brake is making just light contact throughout a complete drum rotation you probably don't have any worry. If it is only making contact in one area of the rotation, something is definitely wrong. Least troublesome thing I can think of is the hub/drums are not tightened correctly on the bearings/spindles. If that is done right, the only other thing I can think of would be the backing plate attachment is out of 'square' with the spindles, or the spindles have been bent enough to cause the hub/drum to rotate 'off-center' with the backing plate??
If, in good light, you can see some of the internals visible between the backing plate & the drum, something is definitely out of alignment. In my pic you can see the outer 'rim' of the backing plate & part of the 'raised' inner surface, but none of the internal parts except a tiny part of the adjuster mechanism near the bottom. That should be normal. If it were mine I'd definitely have a professional look at it, or disassemble it myself & find whatever is 'out of kilter'...
Old 07-17-2014, 12:31 PM   #11
CampyTime's Avatar
Ok I'll check that out Nd update you with more pics. Fishing with my son right now
Old 07-17-2014, 02:17 PM   #12
CampyTime's Avatar
Had to bring my son home from camp but I thought I'd report that I phoned Scamp and the man I talked to said he really couldn't help me without a picture and that they are more into manufacturing and couldn't align things if needed anyway as not proper equipment on hand. So I'll take better photos and send to him too. But trailer " trailers nicely" as I said before. No dog legging or other weird stuff as if axle/spindles had trouble. My friend who checked spindles and bearings said they were perfect. But I'm mad at myself cuz I bought a scamp in an accident and I hope to God I didn't make a huge money mistake. Leave it to Beaver!
Old 07-17-2014, 02:33 PM   #13
CampyTime's Avatar
Huge update! I just got off the horn with an engineer at dexter axle. He it'd me that this is normal and due to the metal stamping process when they are made which pulls on the backing plate a little more at the bottom than at the top. He also said that I adjusted my brakes properly and they'll be a bit more grabby until things settle in. Must have been really off before! He wasn't surprised that I could only get 3/4 to one thumb wheel turn in my brake controller now. Need to settle in. Woot woot!
Old 07-17-2014, 04:01 PM   #14
Paul O.'s Avatar
That sounds reasonable. If the brakes have not been used for some time, the drum surface could be rusty and behave differently. They may also act differently after you adjusted them. It is good to adjust the brake controller at the beginning of every trip. They say get to 25 mph (on dry pavement) and activate the trailer brakes. If they lock, back off, if not, increase the voltage until they do, then back off, to be just a little below. My mechanic says "you will feel when the trailer is pushing you, or doing all the work". I am not sure I can tell because of my limited experience, but I am trying to watch how the rig reacts to whatever I do with it. The key is to drive so you always have plenty of room to slow down gently anyway. It is safe and reduces wear and tear - a double benefit.
Old 07-17-2014, 04:21 PM   #15
CampyTime's Avatar
What Paul? I see my quote dear but no words from you?
Old 07-17-2014, 04:27 PM   #16
Carol H's Avatar
Wendy glad to hear you can now go back to enjoying camping and not worry! Girl you continue to amaze me as to how much you are wishing to learn and understand about your trailer. Don't be surprised if you get a PM from me in the future asking for help!!
Paul, I also adjust my brakes each time I go out. One I get the trailer out of the driveway and on a flat road with little traffic near my home I do a few fairly low speed stops. I set them up until I feel the trailer bunny hop then I adjust them down a little until all I feel is a bit of a tug from the trailer when the brake pedal is fully down. Once on the road and the brakes are well warmed up I may have to adjust them down a little again though - more often than not I need to adjust them down if I have been in lots of stop and go traffic on the freeway and using the brakes a lot.
Old 07-17-2014, 04:41 PM   #17
CampyTime's Avatar
HA ha! You are the smart lady I referred to in my earlier post on this thread Carol! I'm just detail oriented and curious. I don't stop till I understand. You're just smart: full stop! And by the way, I guess I do the same thing as you with checking my brakes each trip. I just thought I was dumb and often turn them down when I feel Scamper being too noisy or bunny hopping as you say. It's all learn by feel and observation to me as a teacher, I go by gut.
Anywho, it's just persistence you see. I try hard like Avis. You're the brains of the outfit girl. I like ya.
Old 07-17-2014, 06:37 PM   #18
Paul O.'s Avatar
Are you saying that the quote (pasted in italics) shows, but no other text?
Here are some words from me: You are doing great, looking after details and learning. I second what Carol just said. Soon you will be dispensing advise and help based on your experience!
Paul
Old 07-17-2014, 06:52 PM   #19
Paul O.'s Avatar
I should have added in my post that I assume that the brake controller setting could be altered inadvertently during regular use of the TV, that is when it says n.c. (not connected). Another thing to test out some day when hooking up for a trip.
Old 07-17-2014, 07:43 PM   #20
CampyTime's Avatar
Thank you Paul for your kind words. I use FGRV for mobile on my iPhone and yes: all I still see in your post is my quote in italics. Maybe it appears properly on regular computer internet?
I hope very much to help others as I learn and experience the Scamper. Bless you all!
Brake Controllers on cars that might brake automatically boley Towing, Hitching, Axles and Running Gear 40 09-06-2013 07:47 PM
Can I set my hubs/drums on wheel dollies? Bryan L. Care and Feeding of Molded Fiberglass Trailers 15 06-14-2010 09:07 AM
Brake pedal switch - Brake controler Dave Mac Problem Solving | Owners Helping Owners 13 07-19-2007 07:49 AM
Electric Brake or Surge Brake? Bonnie Barge Problem Solving | Owners Helping Owners 28 08-28-2006 01:44 PM
