Replacing captain Chairs - Fiberglass RV
Old 06-25-2018, 10:49 AM   #1
Trailer: Currently Shopping
How difficult is it to replace the captain chairs in a Casita with the bench chairs that create a single bed? Thanks so much.
JCallie is offline   Reply With Quote
Old 06-25-2018, 12:11 PM   #2
Trailer: 13 ft Scamp
While I’m sure many will chime in
You might also post this on the casita site
Old 06-25-2018, 12:21 PM   #3
Thanks I appreciate the suggestion.
Old 06-25-2018, 02:55 PM   #4
John in Santa Cruz's Avatar
Mid Left Coast
the dinette benches on the casita are molded fiberglass screwed to the riser under the table, and to angle brackets on the inside of the outside wall (not sure how said angle brackets are attached, as there's no rivets on the outside).
(note thats my Casita Spirit Deluxe 16... it might be slightly different on a Spirit 17, I dunno)
presumably on your Liberty(?) with buckets, the power converter and water heater switch are mounted somewhere else...
Old 06-26-2018, 10:59 AM   #5
Trailer: Big Foot
Georgia
Not difficult at all. Remove chairs from their base, add a wall brace across the back, Cut a 3/4" piece of plywood the length and width you want (we used 28") bolt and screw together. It is easily reversable.
dblcola is offline   Reply With Quote
Old 02-15-2023, 02:48 PM   #6
Trailer: Casita FD
bolt attachment?
I'm also looking to convert an FD by replacing the seating area with a storage cabinet. I started to remove one of the seats by unbolting from the floor, but noticed that as soon as the bolts were loosened they seemed to spin rather than lift.
Can someone clue me in as to how the chairs are secured? If I unbolt the chairs will nuts fall away such that I can't retrieve/reuse them? For now I retightened the bolts (although one of them was a chore and took some fast turns to get it to "bite").
Jeff in Oregon is offline   Reply With Quote
Old 03-11-2023, 11:22 AM   #7
Trailer: Currently shopping
I'm pretty sure they go all the way through to the underside, a friend of mine did it and he had to crawl under the casita to lock onto the bolts there. I did a complete conversion myself, what I did was left the swivel chair post in place and put the plywood directly on those posts and it worked out very well. So all I removed was the swivel seats from the post from the inside and then use the post to support the plywood and shimmed up a piece of plywood on the wheel. Well put a couple 2x2s and the corners as posts using double stick tape and it's easily convertible back and forth if I need it to be.
indysafe317 is offline   Reply With Quote
Old 03-12-2023, 10:42 AM   #8
Sitah's Avatar
Trailer: Minit 13 ft
When I redid my floor, I had to remove mine. Two-person job. One holding nut underneath, one loosening/tightening the bolt inside. I replaced mine with stainless, since the original hardware was quite rusted. Good luck!
Sitah is offline   Reply With Quote
captain
Casita Freedom Captain's Chairs and Table for Sale Ericka O Classified Archives 10 06-22-2007 08:04 AM
WANTED: swivel captains chairs Betty L. Classified Archives 3 06-30-2006 08:14 PM
