1998 Burro Front Window - Fiberglass RV
Old 01-18-2019, 07:49 PM   #1
Trailer: 1998 14' Burro WB
Illinois
I am just finishing my 1998 Wide Body Burro rebuild. In fact I am down to putting the trim on for covering the screws on the front window.
The problem I have is I can't find anywhere to buy a new cover. I thought it was the same as the door but is does not fit. I bought a flexible vinyl for the door trim and it seems to work fine on the door but not the window. I will know better after towing it down the road at 60 mph.
Does any one know where to find the trim piece to cover the screws for the front window. I remember it being a hard plastic strip. Mine came out in pieces. Hard to believe aft 4 years of working on this is it coming down to this trim piece to get it outside.
Jim
Do not go where the path may lead, go instead where there is no path and leave a trail - Emerson
jetalkington is offline   Reply With Quote
Old 01-19-2019, 06:07 AM   #2
SteveV's Avatar
Trailer: Amerigo FG-16
They do make different widths in the vinyl trim inserts. A search on ebay should lead you to the size you need. Here are a few 1/2" ones: https://www.ebay.com/sch/i.html?_fro...LH_TitleDesc=0
SteveV is offline   Reply With Quote
Old 01-19-2019, 08:54 AM   #3
Illinois
The top one is the one I have for around the door and it works fine there. The front window has a deeper channel and the screw heads interfere with the shallow molding. The pan heads are tall enough to not allow the molding to settle firmly in the groove.
The door and the window are both 1/2 inch. I found a short piece of the old hard plastic trim molding and it is more u shaped with ribs on the outside of the legs and they grip the inside of the channel. I am looking for more of that type molding.
I have to work today but when I get home I will try to get a picture of the channel profile and the old trim molding piece.
Thanks for taking the time to look those up o n ebay.
Jim
burro
Burro Front Window Green Frog Problem Solving | Owners Helping Owners 12 10-15-2011 08:46 PM
Front window u-haul 13' and Burro 13' daman4799 Problem Solving | Owners Helping Owners 3 05-03-2011 09:10 AM
windows and front coverfor 1998 bigfoot ken h Classified Archives 1 03-18-2011 09:55 PM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
Burro Front Window Awning & Rock Shield Legacy Posts Problem Solving | Owners Helping Owners 3 07-25-2003 05:38 PM
