New owner of a Uhaul ct13 - Fiberglass RV
Old 04-26-2019, 07:02 PM   #1
Trailer: UHaul ct13
Talking New owner of a Uhaul ct13
Hi Dan & Tracy here. Bought a UHaul Ct13 It will need some work before we takei it out. Hoping you all can help us with that
Trac is offline   Reply With Quote
Old 04-26-2019, 07:47 PM   #2
Trailer: Sold it
Northern VA
Welcome Dan and Tracy.
Good info here on projects. What do you need to do?
Sold the burro
Old 04-26-2019, 07:48 PM   #3
JBB
JBB's Avatar
Trailer: 2017 Lil Snoozy
South Carolina
Welcome to the forum Tracy! There is a wealth of knowledge here. Just ask your question and I'm sure there will be someone that can help!
JBB is offline   Reply With Quote
Old 04-26-2019, 07:53 PM   #4
Some good info here but many things are unique to the Uhauls. There is also a very good Uhaul Facebook group that has many members and plenty of information.
Old 04-26-2019, 09:31 PM   #5
Trailer: UHaul ct13
windows
Our first task is to take care of the leaks.
Wondering if the windows can be repaired or if there are replacements
Old 04-27-2019, 04:36 AM   #6
Trailer: UHaul CT13
Iowa
Tracy,
Welcome to the weird n wonderful world of U-Haul campers.
At the top of the page, in the "More" drop-down, is the "Document Center"... and toward the end of that page, under "Manufacturers", there's a guide you can download for a full rebuild of the U-Haul windows.
Fiberglass RV - Document Center - U-Haul Side Window Repair Information
A number of folks have used that guide to rebuild their windows. They're still a little fussy, even after that, but at least then all the materials are new, and the chances for eliminating any persistent leaks are good.
Some folks have just gotten windows custom made---Motion Windows is one source. [but several hundred dollars per window]
Some have made fillers for the opening, and installed the smaller Scamp windows.
I slightly enlarged the openings on our CT13, and put 20x24 horse-trailer sliders in the side windows [very affordable, but there's that having-to-modify the opening thing], and a Scamp rear window.
Best of luck, whatever way forward you choose...
Gary
Old 04-27-2019, 04:39 AM   #7
Trailer: UHaul CT13
Iowa
Here's a link to the last page of my long-winded CT thread... toward the bottom of the page I describe the windows install in ours.
http://www.fiberglassrv.com/forums/f...-66181-17.html
Old 04-27-2019, 01:36 PM   #8
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Always enjoy seeing another vintage egg being brought back to glory, especially a Uhaul.
Please post some pics, before and after.
Walt
Old 04-27-2019, 05:38 PM   #9
Trailer: UHaul ct13
Question solar panel on top original?
We just discovered that there is a small solar panel on the top of our UHaul. is this original/standard or an add on?
Old 04-27-2019, 06:35 PM   #10
The solar panel is original but was only to maintain the battery while the trailers sat on the rental lots. The controller is mounted on the side of the battery box. It may or may not still work. Ours did not. I disagree on the weatherstrip recommendation for use on the side windows but that's another story I'll avoid at this time. Look into replacing the body to frame bolts as they typically rust away where they pass through the floor. Everyone is using elevator bolts as replacements. Check frame for rust through, mainly in the tubular sections and also the whole thing for cracks. CT's did not have brakes and they use sealed bearing hubs that are not serviceable (can not be greased). Wheels are special and sometimes can be purchased through Uhaul's eBay store.
Old 05-04-2019, 10:43 AM   #11
JAB
Name: John & Joanne
Trailer: UHaul CT13
New Hampshire
Hi Dan and Tracy,
We bought a refurbished CT-13 two years ago and it's been great. I'll add one caution and one recommendation:
1. The well where the table pipe fits is a weak spot. Ours nearly broke through while traveling. So (a) disassemble the table when on the road and (b) if the well fitting is damaged it can be replaced with a better upgrade available at Camping World (I can get the part # if necessary).
2. We had the hinge for the front bunks but nothing else so I built a small upper bunk from plywood and supported it with removable rigid pvc tubing that includes a safety rail. Works great for our two grandkids. If you're intersted I'll get you photos.
The memebers here are very helpful. Welcome! John
JAB is offline   Reply With Quote
uhaul
New UHaul CT13 owner Thomas G. Hi, I am.... 42 04-14-2017 09:32 AM
Uhaul CT13 - New Door Lock Tumbler? foofght Problem Solving | Owners Helping Owners 3 03-15-2016 10:07 AM
how do I find an owner Uhaul CT13 Lynne VDK Modifications, Alterations and Updates 3 07-19-2012 06:22 PM
New CT13 owner keekers General Chat 14 05-12-2011 04:35 PM
New old owner, or old new owner? drews60 General Chat 7 11-17-2006 05:36 PM
