trillium 4500 door hinge - Fiberglass RV
Old 05-27-2019, 06:38 PM   #1
Name: Bill and Kate
Trailer: Trillium
We have a 1978 Trillium 4500. The front door hinge has a screw that is rusted. To remove the top screw the hinge pin head is in the way-can The hinge pin be tapped out so we can remove the screw
billandkate is offline   Reply With Quote
Old 05-27-2019, 08:32 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
It is possible to tap out the pin, but you run the risk of cracking to cast metal hinge. The method I've used for removing the top screw is to remove all of the other screws first, then back out the top screw together with the entire hinge. Once you've pulled the hinge away from the trailer body, you should be able to angle out the top screw.
Old 05-27-2019, 09:09 PM   #3
Name: Bill and Kate
Trailer: Trillium
hinge screws
thanks John
I hate to remove all the screws when only the top one needs replacement-I previously replaced the other two and hate to break the tight fit I got from using an epoxy putty
Bill
Old 05-28-2019, 03:26 AM   #4
Raz
Raz's Avatar
Trailer: Trillium 2010
The hinge pin is splined just below the head. Some penetrating oil might help. Just in case, the hinge is a Kason 139 freezer hinge with a 3/8" offset. McMaster Carr sold them at one time. Part no. 1276A52
trillium
Trillium Door Hinge Assembly JBjunior Problem Solving | Owners Helping Owners 9 02-23-2016 07:57 AM
Trillium door hinge fix, need inside patch Colleeno Problem Solving | Owners Helping Owners 4 10-10-2014 12:22 PM
Sticky door hinge on Trillium mzuzel Problem Solving | Owners Helping Owners 3 11-20-2013 03:29 PM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Trillium Door Hinge in rotted wood Lise S Problem Solving | Owners Helping Owners 6 10-25-2010 06:32 PM
