Fiber Stream Axles - Fiberglass RV
Old 03-31-2010, 05:16 PM   #1
Trailer: 79 13 ft Scamp and 74 Compact II
Does anyone have any information on the brand or axle rating for the fibert Sream trailers? I am trying to find out the actuall brand name or actual brochure info on the axles.
I would appreciate any info that you may have.
Cindy Ross is offline   Reply With Quote
Old 04-19-2010, 12:21 PM   #2
Cindy,
I just finished "flipping" the axles and refurbishing everything related on my '79 Fiber Stream. I could find no evidence of make, so was watching this thread in hopes someone would respond who had the info. The good news is I took the hubs and brakes to the local RV parts house and everything I needed was readily available.
Good luck,
Mike
Mike Reynolds is offline   Reply With Quote
Old 04-21-2010, 07:52 PM   #3
Roger H's Avatar
They could have been from any one of a number of manufacturers, but the odds are good that they were probably Dexter, expecially if Mike was able to find replacement parts off-the-shelf... even if the axle wasn't a Dexter itself, the manufacturer likely used Dexter hubs and parts.
You might try looking at the Dexter site for info...
Roger
Old 04-23-2010, 03:39 PM   #4
Trailer: 84 16 ft Scamp
If all else fails, pull the hubs and get the bearing part numbers. A bearing supplier should be able to tell you from that the axle rating, or at least get awfully close.
Good luck!
Loren G. Hedahl is offline   Reply With Quote
Old 05-30-2016, 09:45 AM   #5
Victor Benz's Avatar
Exclamation New Fiber Stream axle needed!
I know this is an old thread, but I need help with a Fiber Stream axle replacement. I blew the trailing axle (non-brake axle) wheel bearing on the trailer door side. I believe the axle will need to be replaced. The trailer is at a shop 300 km from home. The shop foreman is unsure that he can find a replacement axle, since it is such a light one (2000 lb rating, 4 bolts on 4 inch hub pattern).
Does anyone have a supplier and/or part number for this axle (e.g. Dexter)?
Failing that, does anyone have the important measurements to order the axle ( hub-to hub length, springs center-to-center, overall axle length)?
Thanks in advance for any help you can give me.
Victor
Victor Benz is offline   Reply With Quote
Old 05-30-2016, 09:49 AM   #6
Be patient Victor. It's the first long weekend (Memorial Day) of the summer. Lots of people who could help may be out camping.
Old 05-30-2016, 11:08 PM   #7
Thanks Donna, Just a photo showing us leaving the campground...
fiber stream
16 ft Fiber Strream dual axles - $5,600 Benita Classified Archives 2 07-18-2009 03:17 PM
Fiber Stream Tom Bernardino Problem Solving | Owners Helping Owners 8 10-12-2008 05:59 PM
79' Fiber Stream Robert N. General Chat 2 09-11-2008 07:23 AM
13' Fiber Stream Roddy D Care and Feeding of Molded Fiberglass Trailers 6 06-05-2008 10:56 PM
79' Fiber Stream Robert N. Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
