78 Surfside Re-build - Page 4 - Fiberglass RV
Old 04-06-2014, 12:17 AM   #61
jrocmagoo's Avatar
Trailer: 1978 Tripple E Surfside
Also new tow vehicle 2014 Ford Escape
jrocmagoo is offline   Reply With Quote
Old 04-11-2014, 04:25 PM   #62
jrocmagoo's Avatar
Talking
here are a few better pics and also got a new Hitch mount on the trailer, super safe for towing now!
Old 06-01-2014, 06:11 PM   #63
Trailer: Escape 5.0 TA
fridge on gas
Hi Jeremy. Nice rig! I had some thoughts on your fridge. If it works well on 110 volts but not on gas, I suspect it is not getting enough gas. So'....the orifice is partly clogged(consider using some carb cleaner on it) or the gas PRESSURE is low. Get some help measuring the pressure using a manometer. I think the regulator is adjustable also maybe the gas valve.
Steve
starbrightsteve is offline   Reply With Quote
Old 06-05-2014, 09:55 PM   #64
jrocmagoo's Avatar
I was messing around with it and i think its the thermostat valve, if i move it back from max to about 8-9 it gets ice cold in an hour from room temp
Old 07-28-2014, 09:15 PM   #65
Trailer: 1977 Triple E
Greetings to all
I have a 1977 TM-14 with original interior.
In 2012, travelled to Vancouver from Hamilton Ontario, tow vehicle was a 2001 Volvo Cross Country (5 cylinder).
No problem pulling through the Rockies, once I remembered to use the manual gears!!
Camper has electric brakes.
Cheers
Bill
William Urie is offline   Reply With Quote
Old 08-02-2014, 04:56 PM   #66
jrocmagoo's Avatar
Originally Posted by William Urie View Post
Greetings to all
Cheers
Bill
ill be climbing the connector towards Merrit next week with it loaded up so i guess ill find out real quick how it tows over a mountain!
Old 08-02-2014, 04:58 PM   #67
jrocmagoo's Avatar
Did a bit more work, finally hooked up the 12V lines to the fridge (also noticed alot of my new wires were touching the back of the furnace so i fixed all that and covered/atached them to the cabnet walls) next on the list- fix the front rock guard as the scerws are stripped out and split my propane somehow so i can hook up my bbq without unhooking my fridge
Old 08-19-2014, 09:53 PM   #68
jrocmagoo's Avatar
New water tank
next upgrade done!! brand new water tank!! all for $125
care of Alcaro Plastics-
Suite 4-920 Leathead Rd, Kelowna, BC
this is the tank design for the Escape trailers (they supply them) and "almost" a direct replacement, i had to space out the braces 1/2 due to the deeper pan (4" to bevel) and the hoses are a bit snug as it is 2 inches wider but a bit of creative routing i needed no new holes
awesome guys to deal with!
Old 04-11-2015, 11:43 PM   #69
jrocmagoo's Avatar
been hard at work again! planning a few big trips this year so lots of prep-
new LED lights and all new trailer light wiring, stabilizer hitch (wind trips) new fuse boxes and distribution panels, upgraded to a 12v water system, no more hand pump!
also scored a 8 foot bag awning and rail on clearance new in box for $160!- pic of that will follow install!
Old 07-17-2015, 10:51 PM   #70
jrocmagoo's Avatar
More updates!
Well been hard at it every chance i get, already made it out on a nice week long trip to the kooteneys then in two weeks hauling it off to Saskatchewan for 2 WEEKS! gonna visit/camp and let it see its home province again lol
here some more progress pictures- been picking away at the body work and adding the proper mounts for the Awning and working on the battery box ect..
the grey is not the final paint - just rock guard for now, thinking Gun metal on the bottom and matte/satin white for the top
Old 06-11-2016, 03:28 PM   #71
jrocmagoo's Avatar
sorry for the delays in posts but here is a small update...
NEW WINDOWS!!!!!!! customer made in Summand BC by Sunveiw Industries
Also new paint, top and bottom!, and I re-did the counter tops again in a more neutral color, ill add more pics soon!
surfside
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Snow build-up on fiberglass roofs General Chat 5 02-14-2014 06:43 PM
The "Silkstone" build Ian S. General Chat 13 07-02-2008 11:52 AM
Microwave build in and laminate floor Karen K. Modifications, Alterations and Updates 9 01-20-2008 03:42 PM
What would you build? Legacy Posts General Chat 11 06-01-2003 02:01 AM
