1978 Beachcomber B15 in Nova Scotia - Page 3 - Fiberglass RV
Old 06-14-2018, 04:47 AM   #41
rambit's Avatar
Trailer: Beachcomber
Nova Scotia
After a few years I finally got a new axle for the trailer. Custom 2600 lb dexter torflex 10deg up. I went with the different angle to gain some ground clearance. I have a tendency to wander off the beaten paths.
Cutting the old axle off was not easy. Had to take a zip cut to the cast swing arms on the axle (or whatever they’re called). Then use a recip saw to cut through the flanges that are welded. After that I cleaned up the frame and lined up the new axle.
ID:	120488Click image for larger version
ID:	120489Click image for larger version
Now to weld it on, and figure out how to fit two children on one bed. Hmmm....
rambit is offline   Reply With Quote
Old 07-15-2018, 07:06 PM   #42
rambit's Avatar
Nova Scotia
So here’s the new axle. In total about 2” more ground clearance. Top image is after, bottom image is before.
Also finished the bunk beds for the kids.
Also figured out how to replace the pesky Bargman L400
Old 08-06-2018, 05:06 AM   #43
rambit's Avatar
Nova Scotia
So, I always wanted to go off grid, but was afraid to take the plunge.
About a month ago, I bought a 300w solar kit to run our mini fridge.
I wasn’t really sure how much battery or inverter I would need, but did as much googling as possible and settled on an 800w inverter ( to handle the startup of the fridge) and 2 group 31 deep cycle batteries.
Got it all hooked up and got out with it twice now. It appears to work great, about enough battery to go a full day and a half with no sun, and when it’s sunny it fully charged in a few hrs. Overall, I’m quite pleased and now we’re not tied to our extension cord anymore.
ID:	123031Click image for larger version
ID:	123032Click image for larger version
Old 08-29-2018, 10:30 AM   #44
rambit's Avatar
Nova Scotia
In PEI again.
Old 08-30-2018, 07:30 PM   #45
rambit's Avatar
Nova Scotia
Another PEI shot
Old 09-06-2019, 08:52 PM   #46
rambit's Avatar
Nova Scotia
This year was good too. Click image for larger version
Old 09-13-2019, 08:56 PM   #47
rambit's Avatar
Nova Scotia
Put decals on the trailer this year. Click image for larger version
Old 11-10-2019, 07:59 PM   #48
rambit's Avatar
Nova Scotia
The season is over. Click image for larger version
Old 07-20-2020, 04:45 AM   #49
rambit's Avatar
Nova Scotia
Welcome to 2020
Old 07-23-2020, 09:07 PM   #50
BC
This looks awesome. Great job. Sorry if I missed it but where did you find the window seal? Do you have a part number? I sent Vintage trailer supply some pics of what I have and he said they don't have anything.
ysreeps is offline   Reply With Quote
Old 07-30-2020, 04:46 AM   #51
rambit's Avatar
Nova Scotia
Which seal were you looking for? There’s a few of them. I used butyl tape to seal the window to the trailer (available at most hardware stores). There’s a rubber track that the sliding windows sit in (I cleaned mine and put them back in). And on the front and rear there’s a rubber wedge type seal that holds the windows in (I reused the old one but made sure the gaps were on the top of the window to prevent leaks).
Old 07-30-2020, 08:34 AM   #52
BC
I need the wedge type seal, mine have hardened and are disintegrating in areas. I've replaced all the butyl already. Fortunately I have no leaks as of now but they look horrible and have shrunk and pulled short of the corners.Click image for larger version
Old 07-31-2020, 03:54 AM   #53
rambit's Avatar
Nova Scotia
https://www.centralrubberextrusions.com/wedge-gaskets/
A quick search this morning. You may be looking for a wedge type glazing seal. The webpage I posted above makes a few different versions. There’s lots of gasket manufacturers. You may have to order a few samples. I have a bucket full of samples when I was trying to replace the seal on my door.
I’d suggest taking measurements and getting some samples from a few vendors. Maybe even send them a photo. You may find an exact match, but likely it’ll be one that’s similar and works.
Old 08-01-2020, 11:55 AM   #54
BC
Thank you for the link. I'll check it out. I do have one sample on its way from California. Hopefully it works. I was just hoping someone here would have a source already as it seems to be a common problem.
Old 08-06-2020, 09:34 PM   #55
BC
The season is over. Attachment 132227
One more question if you don't mind. Our rig is decal free and we would like the back and front decals at least. Do you have a file that you made one from? Or a clean photo of yours with some measurements? Hard to find a clean photo of one on here unless I missed it.
Old 08-07-2020, 03:23 PM   #56
rambit's Avatar
Nova Scotia
I am camping right now, but as soon as we’re home I’ll send you the vector image for our decal.
beachcomber
1978 beachcomber b15 cathielee Problem Solving | Owners Helping Owners 9 08-09-2017 02:01 PM
Hi All from Nova Scotia Turfit Hi, I am.... 3 09-02-2011 04:15 PM
Hello from Nova Scotia Harvey9 Hi, I am.... 4 07-17-2011 06:03 PM
SOLD - 1978 13 Foot Trillium Trailer for Sale in Nova Scotia Lenna F Classified Archives 1 08-21-2008 10:24 AM
Trip to Nova Scotia Barbara Gardin General Chat 7 08-08-2006 07:12 PM
