replacing old vent in 13 77 trillium - Fiberglass RV
Old 09-16-2017, 09:27 AM   #1
Trailer: Trillium
South Carolina
Our vent is leaking and needs to be replaced. The size does not not appear to be available. A fan is not necessary just a new vent. What have others done to replace. The Trillium does not have roof support as some other eggs do.
Dennis77 is offline   Reply With Quote
Old 09-16-2017, 10:53 AM   #2
What size do you need? This is a replacement for the older smaller Scamps.
Heng's - 9" x 9" Mini Roof Vent with Garnish | eBay
Old 09-17-2017, 09:37 AM   #3
Larry C Hanson's Avatar
Trailer: 78 Trillium 13 ft / 2003 F150
Vent
Hi,
That is the one I replaced the old with in my '78 1300.
However, I had to put in a 3/4 inch spacer to have enough
headroom to clear the knob/crank when standing at the cooktop.
Larry H
Larry C Hanson is offline   Reply With Quote
Old 09-17-2017, 03:29 PM   #4
Trailer: 1976 Trillium 1300
New Brunswick
replacing old vent in 1377 trillium
Hi I used the same vent on my 1976 Trillium It fit without any modification to the opening but I did use epoxy to fill any existing holes as they do not line up with the new vent flange holes. Be sure to place the hinge side to the front of your opening. If you place it backwards the wind will catch it if you leave it open by accident while traveling on the roads. I am 6' tall and I have no issues with the crank at all. Good luck ,Duane
getaway1 is offline   Reply With Quote
Old 09-17-2017, 03:33 PM   #5
Trailer: Former 1978 Trillium 4500 owner (now 2010 R-pod)
I was able to refurbish our metal roof vent in our 77 Trillium with new seals. I used a roll of foam truck cap tape on the base and lid. Then polished the whole thing. Much more durable than a new plastic one. It was installed on a bed on butyl tape, riveted in place and then a bead of self levelling dicor on the rivets
77 Trillium 4500
Phil 4500 is offline   Reply With Quote
Old 09-17-2017, 03:36 PM   #6
Trailer: Trillium
I replaced mine with a larger vent.
On the roof I added some wood blocking, with epoxy, matte and cloth, to make a raised area. Kind of like the way a skylight is on the roof of a house.
I wanted to do it this way so that there is no chance of water/snow pooling around the vent while open.
Trill136 is offline   Reply With Quote
Old 09-18-2017, 02:39 AM   #7
vent
I was told that vent was common on tent trailers when i got mine from arrkan trailers in Edmonton Alberta.
Old 09-22-2017, 12:30 AM   #8
Jan Dyke's Avatar
Trailer: boler
I have a 13 ft boler and replaced the small vent with a 14 inch. It sure helps with ventilation
Jan
Jan Dyke is offline   Reply With Quote
trillium
Replacing ~9" roof vent in Boler Raya Care and Feeding of Molded Fiberglass Trailers 34 12-16-2008 08:01 PM
Replacing the Roof Vent DanMurphy Care and Feeding of Molded Fiberglass Trailers 8 06-03-2008 02:04 PM
12"x12" Celing Vent needs replacing Bob H Problem Solving | Owners Helping Owners 1 05-20-2008 08:32 PM
Replacing Scamp Ceiling Vent With Fan Parker Buckley Modifications, Alterations and Updates 6 02-29-2008 03:08 PM
Replacing -----------Roof vent cover Kevin K Problem Solving | Owners Helping Owners 11 02-04-2008 09:57 PM
