Ventura fix-up - Fiberglass RV
Old 11-07-2017, 11:50 AM   #1
MurrayC's Avatar
Trailer: Ventura
British Columbia (BC)
Ventura fix-up
I've attached a few oics.
The floor was soaking wet.
The plywood was bonded to the fibreglass when built so I could not just rip it off, I had to separate the wood from the fibreglass. I cut some foot long wedges and taped them between the plywood and fibreglass. When enough had separated I cut this off and kept going.
Having compromised the fiberglass floor shell I installed another layer of fiberglass. Then installed new plywood floor. I was going to put the plywood into the wet resin for bonding but decided this was trying to do to much all at once. I then bonded the plywood down with Sikaflex 291. Seems to be a good job.
Also added some ceiling supports. Cut strips 1/8", glued up to 3/4" with a 3/4" arc. This helped out quit a bit.
One reason for doing this was that someone installed the solar panel on the roof.
This trailer does not have enough support for this.
Thats all for now. More later
MurrayC is offline   Reply With Quote
Old 11-19-2017, 11:46 AM   #2
philtripp's Avatar
Trailer: Ventura
Manitoba
Looks great! Wish my ceiling framing looked like that! I’m currently rebuilding it all from scratch.
When you put the mat down on the floor did you just lay out the mat and pour the resin over top spreading it around? I’m going to be doing the same thing to the roof of mine after it is framed because of the number of holes present.
philtripp is offline   Reply With Quote
Old 11-19-2017, 12:38 PM   #3
MurrayC's Avatar
Trailer: Ventura
fiberglass
Phil
I used chop strand mat on the floor.
I built 2 canoes which I used woven strand fiberglass.
With the woven strand you can pour the resin on and squeegee it around.
The chop strand tends to pile up if you sqeegee.
I used a paint brush. I would recommend buying not the cheapest of cheap brushes but a step up tp the amber coloured bristle ones.
You should also get a fiberglass roller to roll out the bubbles.
I ma not a techy when it comes to type of fiberglass to use other than I was told that when strength is needed you should put on one chop strane and one woven. Ask your supplier.
Watch also how much catalyst you use. There is a fine line using a little extra for faster curring which also makes the end product a little more brittle.
Good luck
Old 11-19-2017, 01:40 PM   #4
Missouri
nice job
murray your are doing a great job! I never heard of a fiberglass roller learn something new every day it seems!!
bob
ventura
Stuipid Ventura door . strikes. Me agine .. Need a quick fix Cheyanna83 Problem Solving | Owners Helping Owners 12 07-05-2017 01:37 PM
1976 Ventura Monarch Fix-Up BolerBee Modifications, Alterations and Updates 5 05-24-2017 10:27 PM
Ventura window leak found..ideas how to fix? Cheyanna83 Problem Solving | Owners Helping Owners 3 07-23-2016 10:06 AM
Ventura door leaking top left corner- baffled how to fix Cheyanna83 Problem Solving | Owners Helping Owners 5 05-23-2015 05:00 PM
website fix Lew King General Chat 1 11-17-2005 01:10 PM
