Bigfoot 25RQ Bathroom Light Bulbs - Fiberglass RV
Old 12-04-2017, 12:15 AM   #1
Today I noticed that one of my bathroom lights above the mirror was loose, so I attempted to twist it back into place and the base broke off. Luckily, it did not break off completely and I was able to remove it.
The sticker on the light fixture says to use a 9019 bulb. I believe the light fixture is made by Gustafson. It looks like this:
https://www.etrailer.com/RV-Lighting...77-000319.html
I found this replacement bulb on etrailer.com:
https://www.etrailer.com/p-277-000320.html
It's not as fancy looking as the light bulb that I broke, but I'm not too worried about that as I can just buy three new ones so they all match.
But now I am wondering if the bulbs that came with the Bigfoot 25RQ were LED. If they are not LED, has anyone with this light fixture found an LED replacement bulb for this light fixture? Well, even if they were LED, has anyone found a replacement? I have not been able to find an exact match online.
Would any of these work?
https://www.amazon.com/LongLife-9090.../dp/B006FINVQ6
https://www.amazon.com/dp/B00BT0LZ0O..._t1_B006FINVQ6
LED Bulb for 20-99 vanity or decorative light replacement - Diamond 52615 - Light Bulbs - Camping World
Karen
karencalifornian is offline   Reply With Quote
Old 12-04-2017, 09:15 AM   #2
rbryan's Avatar
Arkansas
Any bulb with a 20-99 or 1156 base will work on the Gustafson fixture.
The oem bulbs supppied with the Gustafson fixture are not LED. Be aware that the light color with LEDs will be slightly different than the incandescent bulbs, and depending on the LED type, probably brighter. But, you'll use far less power, and the LED bulbs will be cooler to the touch.
Old 12-04-2017, 12:55 PM   #3
Thanks so much for the info, Robert. That’s good news!
Old 12-04-2017, 03:19 PM   #4
Name: Josh & Sonya
Trailer: '97 Casita SD 17; 03 Bigfoot 25RQ
Bulbs for Bigfoot 25RQ bathroom
Hi Karen,
We have the same trailer. One of the original bulbs burned out, and since we are in the process of switching over to all LED's, we put in one "standard" LED (can't remember the exact specs) and removed the two remaining original bulbs.
As Robert mentioned, the color is brighter white, though you can get "warmer" bulbs. My wife likes things as bright as possible (she wants to go 350-450 lumen bulbs everywhere! kind of blinding for me). However, the single LED bulb (which I think is 250 lumens, daylight) gives more than enough light for the bathroom, with way less energy draw than three of the originals.
Josh
Karen
Josh and Sonya W is offline   Reply With Quote
Old 12-04-2017, 04:12 PM   #5
Josh, that’s a good idea, to just keep one bulb installed. We boondock a lot and every little amp counts!
Karen
bigfoot, light
1988 Bigfoot Trailer Light Bulbs V'sGlassSleeper Problem Solving | Owners Helping Owners 9 07-19-2020 01:24 AM
2005 Bigfoot 25RQ - Portland, OR - $19900 Camilla Referrals: Molded Fiberglass Trailers 0 06-28-2012 07:24 PM
FL | 2006 bigfoot 25rq earthfirst Classified Archives 1 11-06-2011 08:19 PM
Bigfoot 25B-25RQ General Chat 0 01-01-1970 12:00 AM
