UHaul rims - Fiberglass RV
Old 12-21-2017, 10:05 PM   #1
Borrego Dave's Avatar
UHaul rims
With all the comments I've read about uniqueness and limited availability of UHaul rims, I've often wondered why folks wouldn't be changing out the hubs or axle, when it needs it, to one that accepts a common sourced rim.
Old 12-21-2017, 10:58 PM   #2
floyd's Avatar
They used hubs from a 1980 Chevy Citation, never had to repack and you can still buy them at your local parts store. Not sure but I think they used the rims too.
If I recall they were only a few mm positive offset, narrow rims, probably a common GM rim throughout the eighties.
Old 12-22-2017, 04:56 AM   #3
Trailer: UHaul CT13
Iowa
Dave,
Good point. Floyd is right--there was a Chevy hub that was a bolt-on replacement for the U-Haul .
And, some have replaced the whole axle with a new one [Dexter, maybe?], that then gives more options. [though wheel offset still is a fussy point]
Hubs don't often fail on the U-Hauls, apparently.
And U-Haul is now making new wheels available, on eBay I think, though they're not always available..... some folks have had to wait a while before the next batch comes along.
My $.02's worth..........
Gary
Old 12-22-2017, 07:15 AM   #4
I think it was certain years Camaro or maybe Lumina hubs, depending if you want the original 5 on 4 3/4 bolt pattern or the more common 5 on 4 1/2 pattern. Only one or two known hub failures but it's a good idea to periodically inspect the sealed hub for any play or roughness when rotating the wheel. No brake option on the original CT axle unless it is converted to the Uhaul surge brake system. Otherwise the whole axle has to be changed
Old 12-22-2017, 08:15 AM   #5
Missouri
interesting you learn the darndest things here!!
bob
Old 12-23-2017, 05:48 AM   #6
Trailer: UHaul CT13
Iowa
Tom Griebe just posted this over on the Facebook forum:
https://www.ebay.com/itm/23516006-U-...item28344d9e6b
I believe they were about $69 each, with another $8 for s/h.........
uhaul
Need rims for Uhaul CT13 Higginra Towing, Hitching, Axles and Running Gear 29 12-03-2012 08:46 PM
Replacing my tires & rims... do they have to be trailer tires? David Scott Towing, Hitching, Axles and Running Gear 20 10-16-2012 07:25 PM
tires n rims Tom Stewart Care and Feeding of Molded Fiberglass Trailers 45 11-06-2006 03:01 PM
Has anyone tried 15X7 rims on an egg? AndyW Towing, Hitching, Axles and Running Gear 3 10-05-2006 09:41 PM
13" Tires on Rims Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 11-03-2002 04:03 PM
