Do you know this lock - Fiberglass RV
Old 01-10-2018, 07:16 PM   #1
I have been trying to find some of these locks but no luck. If you know the name of this lock or where I can get them can you let me know?
Igo96047 is offline   Reply With Quote
Old 01-10-2018, 07:28 PM   #2
mszabo's Avatar
Trailer: U-Haul VT16
Tractor supply
mszabo is offline   Reply With Quote
Old 01-10-2018, 07:39 PM   #3
Not at Tractor Supply
Looked on TS and didn't see it, happen to know the name?
Old 01-10-2018, 07:55 PM   #4
mszabo's Avatar
It looks like a twisting butterfly locking latch.
Found several, just not yours yet.
Old 01-10-2018, 08:06 PM   #5
Virginia
Is there no writing or numbers at all on it, both sides?
Neto is offline   Reply With Quote
Old 01-10-2018, 08:09 PM   #6
rbryan's Avatar
Arkansas
Looks like a keyed rotary butterfly draw latch. Similar to the one in the link below, although the one in the photo has the common CH751 lock which provides little to no security since all CH751s are keyed the same.
https://www.bikebag.com/product-p/bw-latch-lr.htm
Old 01-10-2018, 08:16 PM   #7
I only have the picture.
Old 01-10-2018, 08:21 PM   #8
rbryan's Avatar
Arkansas
My guess is the one I linked above would work. Very similar. They do have a measured drawing if you want to compare.Click image for larger version
Old 01-10-2018, 08:24 PM   #9
Thanks now that I know the name I can do a better search. Want to stack generators and I saw someone using these locks. I am checking these and other options.
Old 01-11-2018, 06:11 AM   #10
Trailer: Trails West
Type the words "keyed draw latch" into your browser and click on the choice for doing an image search. Image searches are often the fastest way to find things. They work a lot better than trying to search through a lot of text based descriptions.
Old 01-11-2018, 08:35 AM   #11
Thank you for all the help. It makes searching much easier when you know the name of what you're looking ofr.
Old 01-11-2018, 10:08 AM   #12
Trailer: 2013Escape 21
Iowa
What’s in a name
With a name like Corbin, I would put a lot of faith in this persons advice. We had a lot of Corbin locks on doors where I used to work and they were very dependable.
Iowa Dave
Iowa Dave is offline   Reply With Quote
Old 01-11-2018, 11:22 AM   #13
Thom Rowland's Avatar
Trailer: 16 ft Scamp
[QUOTE= the one in the photo has the common CH751 lock which provides little to no security since all CH751s are keyed the same.
[/QUOTE]
I have always believed locks are to keep honest people honest. Crooks are always able to get in if they want, either by picking the lock or destroying it.
Thom Rowland is offline   Reply With Quote
Old 01-11-2018, 01:22 PM   #14
True but even a bad lock will make someone take more time than no lock at all.
Old 01-11-2018, 01:27 PM   #15
rbryan's Avatar
Arkansas
Years in law enforcement taught me that. It also taught me how many thieves there are. But, there's a difference between reasonable security and a false sense of security. The CH751 doesn't have to be "picked" for example. You probably already have a key, as do hundreds of thousands, if not millions, of other people. Imagine if you will that your car was keyed exactly the same as hundreds of thousands of other cars. Not much good locking it.
Old 01-11-2018, 01:42 PM   #16
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
That happened to my Brother. He was at the grocery store, walked to what he thought was his Ford Escort (same color and style) and opened the door with his key. He only knew he didn't have the correct car because his key wouldn't turn the ignition!
bigfoot
You know you have too much stuff when.... Gina D. General Chat 26 10-03-2023 08:28 PM
You know you have spring fever If Taylor Kissinger General Chat 2 03-15-2006 07:10 PM
You Know You're a Programmer When ... Bigfoot Mike Jokes, Stories & Tall Tales 9 12-23-2005 12:54 PM
you know you love dogs when... Christi V. Jokes, Stories & Tall Tales 7 11-26-2005 04:30 PM
