Does shore power charge my batteries? - '80 Fiber Stream - Fiberglass RV
Old 05-28-2015, 10:10 AM   #1
KSM
Trailer: 1980 Fiber Stream
Hi,
I recently bought a 1980 Fiberstream that was rebuilt, pretty much from the ground up, by the previous owner. When I first viewed the trailer, the guy gave me a quick explanation of the systems but when I picked it up I forgot to go over everything with him. I'm trying to gain a better understanding of the electrical system.
Trailer has 2 x 6v golf cart batteries in series. I don't see any charger or converter (or whatever I should be looking for). How can I figure out if shore power charges the batteries? Thanks.
KSM is offline   Reply With Quote
Old 05-28-2015, 10:15 AM   #2
Steve L.'s Avatar
You could put a voltmeter to the batteries and then plug the trailer into an outlet. If the voltage goes from 12 something vDC (unplugged) to 13 or 14vDC something (plugged in), there's a charging system in there somewhere. If it doesn't change from unplugged to plugged I doubt there is a charger.
Without adult supervision...
Quando omni flunkus, moritati.
Also,
I'm a man, but I can change, if I have to, I guess.
Steve L. is offline   Reply With Quote
Old 05-28-2015, 10:20 AM   #3
KSM
Great suggestion Steve. Thanks.
Old 05-28-2015, 11:46 AM   #4
Steve L.'s Avatar
I suppose there might be a charger hidden in there somewhere but not hooked up, or with a blown fuse. This is sort of one of those logic excercises. We can prove you have a charger there but we can't prove there isn't a "dead" one there somewhere. It's sort of a half-good suggestion.
Also,
Old 07-20-2015, 04:27 PM   #5
Trailer: what
Mexico
You could add a solar panel and charge the batteries without shore power involved, I did.
milliejohn is offline   Reply With Quote
Old 07-20-2015, 04:58 PM   #6
Bob Miller's Avatar
Trailer: Class A Motorhome
If the p.o. rebuilt it "from the ground up", hopefully they installed a new power center such as my favorite, the Progressive Dynamisc PD-4045. But there are others, both newer and what might look (and smell) like surplus units from Noah's Ark.
Anyway, in modern power centers the battery charger is built into the power chassis along with all of the dc fuses, converter and circuit breakers for the AC power distribution. Look around for that box and tell us what you found. There is usually an exposed panel you can access without taking anything apart. If possible attach a pic.
Old 07-20-2015, 05:42 PM   #7
KSM
Hi all,
I posted the original question back in May when I had first purchased the trailer and not really figured out the various systems. We've since had it out numerous times. It does have a converter/charger. It looks like it might be the original but functions fine. Also bought a 2000w inverter generator which we pack around although I'm starting to look at solar panels as well.
Old 07-20-2015, 06:40 PM   #8
Bob Miller's Avatar
What is the Brand and Model of the converter? You may want to update that before spending $$$ else where.
Old 07-20-2015, 07:18 PM   #9
KSM
@Bob Miller it's a Progressive Dynamics and looks like model PD721Q01RNT
Old 07-20-2015, 07:42 PM   #10
Bob Miller's Avatar
Hi Kyle,
That number doesn't translate to a know PD item. Can you double check. The first 4 numbers after PD- are the most telling.
I'm trying to find a manual for it for your use.
Old 07-20-2015, 08:57 PM   #11
Bob Miller's Avatar
Kyle
Your post and pc didn't come up, can you resubmit?
Old 07-20-2015, 09:10 PM   #12
KSM
Trying this again...
Old 07-20-2015, 09:20 PM   #13
KSM
See the attached (I hope).
Old 07-24-2015, 03:33 PM   #14
Victor Benz's Avatar
Kyle;
That is the original Fiber Stream Progressive Dynamics system. It is not a smart charger, but should charge your batteries id properly wired. I replaced mine with a new smart charger Progressive Dynamics 4045 and have never looked back. I junked the old one.
Vic
Victor Benz is offline   Reply With Quote
Old 07-24-2015, 04:51 PM   #15
Byron Kinnaman's Avatar
Sounds like you might need one of these....
http://www.amazon.com/Generator-Emer...ower+generator
Old 07-24-2015, 05:19 PM   #16
Bob Miller's Avatar
I'm with Victor. That's a 35 y.o. converter... it's time to think about updating and getting rid of problems, as well as adding smart-charging ability. You and your Fiberstream will be a lot happier.
In case you haven't noticed before, I also recommend and use the Progressive Dynamics PD-4045
fiber stream
Question: Charge Controller to Batteries Huck Electrical | Charging, Systems, Solar and Generators 3 07-30-2014 02:49 PM
does power converter charge battery? ampline Electrical | Charging, Systems, Solar and Generators 15 08-11-2012 02:42 AM
76' Surfside - Does the battey charge when shore power is plugged in? dannis Problem Solving | Owners Helping Owners 2 05-26-2012 07:36 AM
How much does a 16' fiber stream weigh? Janine Problem Solving | Owners Helping Owners 4 08-31-2007 01:14 PM
What does my Fiber Stream Weigh? Frederick L. Simson General Chat 31 03-29-2006 08:23 PM
