Ventura Renovation! - Page 2 - Fiberglass RV
Old 06-19-2016, 11:20 AM   #21
Patricia D.'s Avatar
Trailer: 1975 Ventura
Also gutting Ventura
Hi Sheepdog,
I bought a Ventura several weeks ago and am where you were about 3 months ago. I did not intend to gut the trailer but found many disturbing areas once I got it home and it quickly became evident that I had no choice.
I noticed that yours does not have a continuous step up across the front floor like mine does. Is that how it came or did you make a change? Is the raised part on the passenger side where the water tank is? Did you ever find and take it out? I am curious about the paneling you used and how you attached it.
Sorry for all the ques but any help would be appreciated.
Pat
Patricia D. is offline   Reply With Quote
Old 06-19-2016, 12:35 PM   #22
Trailer: Ventura
Manitoba
I'm not shire what you mean by thestep but I can tell you how I paneled mine..
I took one if the original staples to a hardwesr store. Got the closest match for size so I can staple the new up
I gently took panels off and is pnael 1 and marked on the beams where panel 1 was...the panels I took off ibhad my dad cutuseing as a pattern
For the panels I got vinyal wraped panels and then we out together like a puzzle and stapled on. Were I got panels they had marching trim for the gaps hope thstbhelos some
Cheyanna83 is offline   Reply With Quote
Old 06-19-2016, 12:47 PM   #23
Thanks, Kim
By step up, I meant the raised floor (about 5 inches) at the front of the trailer. Mine goes all the way across but on his pictures there is a flat section in the centre. I was wondering if he made a change or if there was two different original plans.
Where did you get your panels? I like the idea of not having any further finishing to do once they are up. I was thinking of birch plywood but it would have to be stained and varathaned.
Old 06-19-2016, 06:07 PM   #24
Dudley's Avatar
Trailer: 1998 Casita 17 SD
The front area on mine had the center area at floor level with a fiberglass tub for a portapotty. There was a door covering the tub.
The water tank was under the rear floor area behind the axle. It was covered by a steel plate. I think you will find the tank is rotten and broken and new tanks are no longer available (where made here in Edmonton and were the same tanks used in Boler 13')
Old 06-19-2016, 06:27 PM   #25
Boler 13 water tank
Posted by permission from Edmond D., information as found on Facebook, for a 13' Boler
D&M Plastics Inc.
Bldg 2, 4843 - 45A Street
Lacombe, Alberta T4L 2E1
Canada
info@DMPlastics.ca
Phone: 403-782-4606
Toll Free: 800-558-7476
Fax: 403-782-3281
Custom Rotational Moulding - D&M Plastics Inc.
Here is a drawing of the RFW1039 tank - http://www.dmplastics.ca/products/drawings/RFW1039.pdf
Old 06-19-2016, 07:38 PM   #26
Trailer: Monarch Ventura
sounds like everyone answered the questions! I also used staples and a pneumatic air gun. I can get the size of staples I used if you like. I also used some "No More Nail" in some of the corners or sections where I felt it needed more than just staples. For paneling I used a vinyl wrapped panel board. similar to what came out just a different color. As for the step at the front. That is how it came. I believe that is where the porta potty went. I am actually converting it into a small dinette/front couch area! hopefully that helped you some
Sheepdog is offline   Reply With Quote
Old 06-19-2016, 09:00 PM   #27
Ques for Dudley and thanks
Thanks everyone for your help. I am going into the city tomorrow to shop for
materials for the trailer. Nice to have more ideas.
Dudley, was it you who used the 3/4 inch metal to strengthen the ceiling framing? if so, do you recall where you bought it and how it was attached to the wooden ribs?
Old 06-19-2016, 09:25 PM   #28
Trailer: Trails West
D&M Plastics Inc.
Canada
info@DMPlastics.ca
Phone: 403-782-4606
Fax: 403-782-3281
That technical drawing is missing a number of the critical dimensions. I wonder why that is? Security clearance required?
Old 06-20-2016, 05:22 AM   #29
Call and ask?
Old 06-27-2016, 01:50 PM   #30
Quick update!
I finally had time to build the closet, seats, and kitchen. here are a couple pictures. hopefully you guys have some constructive criticism for me!
Old 06-27-2016, 02:04 PM   #31
No constructive criticism required
Old 06-27-2016, 02:07 PM   #32
Dudley's Avatar
Looking good Sheepdog! You going with paint or stain?
Patricia D , the stuff I used was 3/4 square aluminum and should be available at any large hardware store in the hardware section. Metal suppliers should also have it. I was given a few pieces.
Old 06-27-2016, 02:10 PM   #33
I guess it doesn't really show in the pictures but I used maple melamine, so it is an already finished product!
Old 06-27-2016, 05:16 PM   #34
Talking Well done
What a difference from the first pictures you posted. It looks so fresh and bright. I am still back where you were in the first pics and you give me hope!
Keep up the good work.
Old 06-28-2016, 11:19 AM   #35
Thanks! it has for sure been a lot of work! try and keep all your old pieces as it is very helpful! I ended up using the old seat frames which made things a little easier!
Do you happen to have any pictures of yours?
Old 06-28-2016, 01:21 PM   #36
I will post pics tonight after I finish for the day.
I am going to start a new thread in the Venture forum for renovation progress and post them there. I seem to be getting too many threads going and even I am getting confused.
ventura
Renovation/Fix-Up... Easier or Harder than you thought? Buck62 General Chat 33 10-09-2020 10:43 AM
Lite House Renovation Bill&Pat General Chat 13 08-25-2012 06:28 PM
Renovation of a Northern Lite truck camper Doug Payne Modifications, Alterations and Updates 4 04-03-2007 09:20 PM
1973 Compact Junior Renovation Barb Egeland Problem Solving | Owners Helping Owners 3 01-10-2006 04:25 PM
Closet Renovation Legacy Posts Modifications, Alterations and Updates 8 06-18-2003 03:14 PM
» Trailer Showcase
Nubbs
spue
Playpac
d.illinois
