08-02-2017, 11:04 PM
#41
Trailer: 13' Boler
Have a look at these #doorcracks [emoji53]
09-10-2017, 08:38 PM
#42
Trailer: 13' Boler
Picked myself up this cute little vintage range / oven combo.
I look forward to the trials and tribulations of mounting it in!
It appears to be a 'coleman holiday' range.
09-11-2017, 10:32 AM
#43
Trailer: Playpac
OH
Awww
That is a cute range. My egg doesn't have room for one and it is the one compromise that will stay with us like salt. My better half would make muffins in our oven and it became a camping tradition for breakfast. I can smell them now... Because you can - Enjoy!
09-11-2017, 02:48 PM
#44
Trailer: 13' Boler
You have a wonderful trailer Buggeee!
We are going to have to move our sink over in order to accommodate room for sink, oven, stove and cooler. I have seen portable range/oven combos you can use outside of your camper if you crave fresh camping muffins
09-12-2017, 09:23 PM
#45
Trailer: boler
that little range/oven is so sweet. Did you find it locally?
Jan
09-12-2017, 10:34 PM
#46
Trailer: 13' Boler
Jan
Sure did!
Found it through the Okanagan Valley classifieds (castanet)
09-18-2017, 05:40 PM
#47
Trailer: 13' Boler
No more planned camping trips this summer allowing us to hollow out the inside and make beautiful with little 'Esmeralda'.
09-20-2017, 05:53 PM
#48
Trailer: 13' Boler
Some pre painting photos of the trailer gutted out. There has been some shorty wiring in the past and a random assortment of cables. It looks like the trailer was wired twice and the previous owners just left a nest of cables!
09-21-2017, 10:37 AM
#49
Trailer: Playpac
OH
Raiders of the Lost Arc
Reminds me of Indiana Jones and the snake pit! Are you going to try to sort through all that or just start from scratch?
09-23-2017, 03:07 AM
#50
Trailer: 13' Boler
Started from scratch.
The old wires were linked up to an AC fluorescent light above the stove and a shore power outlet. No longer needed.
09-23-2017, 03:14 AM
#51
Trailer: 13' Boler
First coat of primer applied to the ensolite.
I used rustoleum's Zinnser bullseye 1-2-3.
First time using this product. Tacks on really well. I plan to do 2 coats each of paint and primer.
For paint I will be using easy flow semi gloss latex paint from Canadian Tire. Advertised for high traffic areas, durable and scrubbable.
09-23-2017, 02:01 PM
#52
Trailer: Playpac
OH
Originally Posted by fofobraselio
Attachment 111852
I did 2 coats of Bullseye 123 as well and am very satisfied with the results. I let it cure fully for a week or more as I worked on other parts. It got good and tight, letting the texture of the ensolite show. Then I put on 2 coats of the topcoat.
11-14-2017, 01:05 PM
#53
Trailer: 13' Boler
Back to work, it may be November but the climate is still 'thankfully' warm enough to keep on keepin' on.
The interior ensolite is fully painted and I have removed the old loosey goosey black insulating material under the bed area and replaced it with tight, reflective insulation glued on with 3M super 77 spray adhesive and then cracks sealed with foil tape. The holes in the floor from the old frame have also been glassed in. The wiring to the signal lights have also been cleaned up.
Next stop, flooring and water tank.
11-14-2017, 02:28 PM
#54
Missouri
work
work work work too much work I would rather be deer hunting but you are doing a nice job!
bob
11-15-2017, 11:19 PM
#55
Trailer: boler
still at it. Not me I spent a couple of days at Golden Ears Park last week, Nice and quiet
Jan
11-16-2017, 09:43 AM
#56
Missouri
for the life of me I do not understand scamps idea of a 110 fl. fixture in the galley area!!
bob
11-18-2017, 09:22 AM
#57
Attachment 111852
What kind of roller did you use? long hair , small foam, brush? I too used that Zinnser bullsey but that stuff is like molasses, very think and doesn't cover well unless I thin it with water.
11-18-2017, 12:58 PM
#58
Trailer: 13' Boler
Hey Mensie,
I used a similar product to this. High density foam rollers.
01-28-2018, 09:07 PM
#59
Saskatchewan
Did you caulk the seams of the ensolite prior to priming/painting? A repaint is in my plans and I'm trying to plan it out.
Thanks, Rick
01-29-2018, 09:56 AM
#60
Trailer: 1979 Boler1700
Maple Ridge, B.C.
I used bullseye with a brush. Ensolite is a bit rough and I wanted to get the best coverage between the ridges. I also ran any extra wires before painting and caulked the seams. You can barely tell where the wiring runs.
