broken door lock on Perris Pacer 1985 - Fiberglass RV
Old 10-22-2016, 11:44 AM   #1
Trailer: Perris Pacer 1985
The tumbler on the front door pulled right out the other day when I was trying to pull the key out. How do I fix this?
plant_sandwich is offline   Reply With Quote
Old 10-22-2016, 03:02 PM   #2
There should be a little tab on the side of that lock cylinder, at the inner end, that has a spring under it to push it out a little. That is what holds the cylinder in to the handle. Either that is damaged, or stuck in, or what it hooks into inside is broke. Look for that little tab and see if it can be pushed in and pops back out. If it's stuck, lube it. You'll have to push it in, then insert the cylinder back in the door in the correct position and see if it stays in.
perris pacer
Replacing the Gasket around the door of my Perris Pacer 1985 plant_sandwich Problem Solving | Owners Helping Owners 8 10-17-2016 04:23 PM
New 1985 Perris Pacer Owner! plant_sandwich Hi, I am.... 3 08-04-2016 07:27 PM
AZ | 1985 Perris Pacer for Sale $3400 Maggie U Classified Archives 14 09-30-2012 05:16 PM
SOLD ~ 1985 Perris Pacer Ken J Classified Archives 3 12-09-2008 07:36 AM
13' Perris Pacer (1985) needs brakes rudock1 Towing, Hitching, Axles and Running Gear 11 12-14-2007 07:08 AM
» Trailer Showcase
Sage
ICW
Rita
Rita the Casita
