2014 trillium sidekick 1300 water tank removal - Fiberglass RV
Old 06-20-2017, 04:31 PM   #1
Helene's Avatar
Trailer: Sidekick (Trillium
Hi,
I bought a new sidekick 1300 by Trillium and have an ongoing love hate relationship with this thing. Newest issue is water in the tub, I suspect it's from the fresh-water tank being cracked but I need to remove it to determine that for sure. Anyone ever removed a fresh-water from the newer trilliums.
Helene is offline   Reply With Quote
Old 06-20-2017, 06:47 PM   #2
Raz
Raz's Avatar
Trailer: Trillium 2010
HI Helena and welcome to the forum. I have a 2010 and they may be similar. To get to the tank I remove the carpet and the plywood cover. The tank sits in a molded well below the plywood. Facing the rear of the trailer, the connections, two as I recall are on the right. One is the breather and the second is the drain. A tee in the drain line goes to the water pump. Tight quarters and fiberglass splinters make working on it difficult . Be aware that the tank is made of HDPE (milk jug plastic) and is difficult if not impossible repair. There is a chance the drain line fitting is loose. I had trouble with mine. Hope that helps. Raz
trillium
Sidekick 1500B Model "Legend Package" $19,400. stude Referrals: Molded Fiberglass Trailers 1 03-15-2016 02:57 AM
Casita 16' and Trillium/Sidekick 15' to look at in New England/Eastern NY? coastsignal Hi, I am.... 22 11-29-2014 05:09 PM
Black Water Tank Removal Ray1919 Plumbing | Systems and Fixtures 3 08-10-2013 02:40 PM
Black Water Tank Removal on 5th Wheel Scamp Steve Hung Plumbing | Systems and Fixtures 5 08-20-2010 07:35 PM
