17ft Bigfoot Front bed easy mod - Fiberglass RV
Old 06-24-2017, 04:54 PM   #1
Trailer: Coleman and Bigfoot
Here's a dead simple front bed mod for the Goucho floor plan big foot.
My wife and I never use the dinette, so we wanted a permanent front bed.
First I removed the hinges from the under seat storage.
Then I took a standard sheet of plywood cut it to 80 inches long, it was already the correct width at 48 inches.
I then put 3 notchs in the 48x80 inch board. Notch one is for the fridge due to the over hang it's 18x 6inchs. I zipped the corner off as well should be able to see it in the picture to allow the fridge to open. One note on this. It makes the freezer hard to get into.
The second notch is at the door corner it's 7x 3 inches.
The third cut is the corner opposite the door corner I took it off at an angle, measurements unknown.
In the end I have a permanent double bed. I bought a $350 6" foam mattress online and cut the notches I needed into it with an electric knife (google it ) it's a dead simple way to do custom foam stuff.
markjeff is offline   Reply With Quote
Old 06-26-2017, 10:47 PM   #2
Trailer: 2017 Escape 19
Nice mod. If you don't need the dinette, this really improves the front bed and since it looks like the plywood platform is not actually attached to anything the next owner can always convert it back to the original convertible dinette if they want to.
Evergreengirl is offline   Reply With Quote
bigfoot
Hi, New member TerryJan Info making Larger bed in 17ft Bigfoot terryjan Modifications, Alterations and Updates 13 04-11-2021 06:50 AM
Converting 16' Scamp front bathroom to easy access storage chuyler1 Modifications, Alterations and Updates 10 05-20-2015 02:10 PM
Comparing 17ft Bigfoot to 17ft Casita LD Swasson General Chat 41 03-20-2013 11:00 PM
Back Bed or Front Bed? Ed Harris General Chat 15 07-26-2011 08:09 PM
Easy bed/dinette mod: Trailswest Campster Bobbie Mayer Modifications, Alterations and Updates 4 09-17-2007 11:28 AM
