Boler Door Lock - Fiberglass RV
Old 07-04-2017, 04:02 PM   #1
bkboler's Avatar
Trailer: 1975 boler
Manitoba
Boler Door Lock
Can anyone out there in FGRV land tell me if the locking T handle from Vintage Trailer will work on a boler. I would like to order the Canned Ham Door Latch with the Locking L handle but they are out of stock and have been for a while (L Handle). Also, where are the mounting screws located for the T Handle? Under a cover for the piece that would rest against the door? Did I explain that properly?
bkboler is offline   Reply With Quote
Old 07-05-2017, 09:16 PM   #2
Roy in TO's Avatar
Not sure what door handles are on your boler. Early ones had the same as Scamp.
Have a look at this page:
https://www.scamptrailers.com/parts-...lts,16-15.html
Old 07-05-2017, 11:02 PM   #3
Jan Dyke's Avatar
Trailer: boler
T handle wouldn't work on my 73 boler. I got a locking L handle at Crappy Tire. I had to cut down the length of the square rod that fits into the inside lock assy
Jan
Jan Dyke is offline   Reply With Quote
Old 07-06-2017, 05:18 AM   #4
bkboler's Avatar
Trailer: 1975 boler
Manitoba
Right now I have the L handle with something similar to the canned ham latch. I wasn't sure if the hollow portion of the door was wide enough to accommodate the shaft of the T handle.
Old 07-06-2017, 05:21 AM   #5
bkboler's Avatar
Trailer: 1975 boler
Manitoba
Jan
Thanks Jan. I never even thought of checking out Canadian Tire. I guess I thought that if Vintage Trailer sold it then I wouldn't find it anywhere else.
Old 07-06-2017, 05:35 AM   #6
Honestly, the square shaft door handle like Scamp uses (and some other brands) is nothing more than a garage door handle. Check your local hardware or big box hardware stores. You may be pleasantly surprised and save yourself S&H. You'd need to cut the shaft to fit, but that's easy peasy... ask me how I know
Old 07-06-2017, 09:17 AM   #7
Roy in TO's Avatar
That looks like a retrofit. Your trailer may have originally had a Bargman latch. Bargman L400 Door Latch
You'll have to take the metal plate off to see what is underneath. My guess is there is an opening that fits the L400. I may have a spare one that I'm not sure I want to part with just yet.
Old 07-06-2017, 03:03 PM   #8
bkboler's Avatar
Trailer: 1975 boler
Manitoba
Thanks Donna. Found one today at McMunn and Yates. Now all I need is the inside piece.
Old 07-06-2017, 03:07 PM   #9
bkboler's Avatar
Trailer: 1975 boler
Manitoba
Thanks Roy. I will probably take off that metal plate at some point but I'm going to stick with replacing the lock with what's already there.
Old 07-07-2017, 12:04 AM   #10
Jan Dyke's Avatar
Trailer: boler
my inside latch looks similar, just bigger. I had lots of room inside the door for it to work
Jan
Old 07-07-2017, 01:57 PM   #11
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
Your existing L handle and inside latch assembly is a match to the setup on my 74 Boler (without the aluminium patches).
Looks like someone retrofitted the earlier setup in place of the Bargman L400 your trailer likely came with.
FYI, the round hole on the top left of your inside latch assembly is for the lock pin. A 2" long 3/16" diameter pin is used (just insert the pin into the hole when you are inside the trailer to lock the door).
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
Old 07-07-2017, 04:36 PM   #12
I don't know what, if anything, is wrong with the inside portion of the lockset, but Paul can help you: Fibreglass RV Parts, Repairs, and Service by Paul Neumeister and he's in Ontario.
Old 07-08-2017, 10:36 AM   #13
Jan Dyke's Avatar
Trailer: boler
on my long trip last week the rivets nearly pulled all the way out on my inside door mechanism, so I will make a nice outside cover plate and rebuild it. Will post pictures
Jan
Old 07-12-2017, 04:51 PM   #14
bkboler's Avatar
Trailer: 1975 boler
Manitoba
Yea, I didn't have the pin so I have been using a 3 inch nail.
Thanks Donna, I'll check out that link.
The outside handle seems to be worn out and it has a lot of play. The handle will lower on its own and I'll find the door open. Plus the latch doesn't seem to come out all the way anymore
Old 07-12-2017, 11:41 PM   #15
Jan Dyke's Avatar
Trailer: boler
Those inside latches are on Ian Giles site. Here is my repair
Old 07-27-2017, 05:04 PM   #16
bkboler's Avatar
Trailer: 1975 boler
Manitoba
That looks nice, Thanks Jan
boler
1980 Boler Door Lock immrbill Problem Solving | Owners Helping Owners 9 08-11-2017 09:16 PM
Boler door lock. B-Rock Modifications, Alterations and Updates 0 06-23-2013 06:38 PM
1982 Boler Door Lock Replacement bondgirl1020 Problem Solving | Owners Helping Owners 6 05-24-2013 09:40 AM
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 07:11 AM
73 BOLER DOOR LOCK NOT WORKING John Young Problem Solving | Owners Helping Owners 5 06-07-2007 07:16 AM
