Brake lights for my 75 Trillium 1300 - Fiberglass RV
Old 07-13-2017, 01:04 PM   #1
Trailer: Trillium
I'm guessing this is common problem but haven't found a thread that helps.
Just bought a 75 Trillium 1300 in really good shape. Replaced the marker lights with new LEDs.
The problem I'm having is that the brake/tail light lenses are in pretty bad shape. Would like to find replacements but can't find any lights that will cover the the spot where the old ones are.
The trailer was painted recently and the lights were not removed so it's pretty ugly under them. Two lights per side would be fine if I can get the right size.
Lights need to be 3 1/2 x 13
Thanks for reading.
4suresure is offline   Reply With Quote
Old 07-13-2017, 09:02 PM   #2
stefman's Avatar
Trailer: 76 Trillium 1300
Waterloo, Ontario
Thanks for reading.
Try contacting Paul Neumeister and see if he still has some rear lamp assemblies left.
Fibreglass RV Parts, Repairs, and Service by Paul Neumeister
Good luck.
Stef
stefman is offline   Reply With Quote
Old 07-14-2017, 09:02 AM   #3
Trailer: Trillium
Looking for LED brake lights
Thanks Stefman, talked to Paul yesterday and he doesn't know where to get the lenses I need.
Now I'm trying to find LEDs that cover the same space.
13 3/16 x 3 5/8" up to 14 x 4"
Old 07-14-2017, 09:14 AM   #4
stefman's Avatar
Waterloo, Ontario
For my trailer I used the typical led rectangular submersible ones that you can buy just about anywhere and then I put pieces of the red reflective safety tape on either side to hide the holes. From a few feet back it looks good. I haven't seen the larger ones for quite some time.
Stef
Old 07-14-2017, 12:37 PM   #5
Trailer: Trillium
I think that may be the way to go. If I can figure out how to post a picture I will do so when I'm done.
Old 07-14-2017, 02:45 PM   #6
ChrisDunbar's Avatar
Trailer: Trillium 1300
Nova Scotia
https://trilliumrv.wordpress.com/parts/
At the bottom there is a note about LED replacement lights at the bottom. I may update mine as well since I currently have them off.
I'm emailing about the decals. I'll ask about the lights as well.
EDIT:
Tail lights:
After being in inventory for 1 year, that last set of lights was sold 3 days ago - sorry.
There is little call for them, so I won't re-order.
However, you can order from your local RV dealer.
This is the part you need.
http://www.bargman.com/products/taillights/taillight-led/led-single-taillights-86-series/lt69J2z68b9Cp!n8AzeNxEUpjlPpIpvP1ORRWbYGjOY="
ChrisDunbar is offline   Reply With Quote
Old 07-30-2018, 07:28 PM   #7
Trailer: Trillium
This is my solution, replaced the tail lights.
Old 08-01-2018, 10:22 AM   #8
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
check ebay UK for trailer or caravan lights, i found LED ones that size, and regular ones which fit, and I just used LED bulbs
light, lights, trillium
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
Brake Controllers on cars that might brake automatically boley Towing, Hitching, Axles and Running Gear 40 09-06-2013 07:47 PM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
Brake pedal switch - Brake controler Dave Mac Problem Solving | Owners Helping Owners 13 07-19-2007 07:49 AM
Electric Brake or Surge Brake? Bonnie Barge Problem Solving | Owners Helping Owners 28 08-28-2006 01:44 PM
» Trailer Showcase
Miss Daisy
Dolores
Big Ei
Lora
