F-150 Short bed (5.5 ft) with Scamp 19 - Fiberglass RV
Old 12-12-2018, 02:21 PM   #1
Trailer: Shopping
Alabama
Is anyone pulling a scamp 19 with a 5.5ft short bed F-150?
If so does the geometry work out or will the camper hit the back of the truck when turning ?
dcs02d is offline   Reply With Quote
Old 12-12-2018, 02:40 PM   #2
Bruce H's Avatar
Probably would if you were backing and got it turned short enough. Get one of these installed and add 3 1/2 feet to the tongue:
https://www.etrailer.com/Folding-Ton...SABEgImT_D_BwE
It would accomplish four things: 1. Eliminate the possibility of cornering into your tow vehicle 2. Eliminate trailer sway for more stable towing without equalizer or sway bars 3. Allow the tailgate to be let down to access the bed of the truck 4. Make the trailer easier to back
Bruce H is offline   Reply With Quote
Old 12-12-2018, 03:03 PM   #3
Byron Kinnaman's Avatar
FYI Bruce
Scamp 19 is a 5th wheel, not a bumper pull trailer.
Old 12-12-2018, 06:20 PM   #4
5th Wheel's Avatar
Trailer: SCAMP
Illinois
just measured bed (haha)
Ok, so...
I have a 5 and a half foot bed. I thought I would need to put the 5th wheel hitch an inch or two behind the axel. As it turned out, my hitch is correctly installed over the axel.
I have no issues driving turning or backing. On a tight turn (very unusual) I have to watch out for the scamp hitting the cab. This gets close on backing in tight situations.
My 1988 5th wheel needed a new axel a few years ago, when I replaced it, I had the shop raise the scamp an extra few inches. To make up for the new vehicle bed height.
Hope this helps...
Also, fun project, I had the shop extend back bumper and add diamond screen.
For more storage space and NEW rear stabilizing supports.
5th Wheel is offline   Reply With Quote
Old 12-13-2018, 02:10 AM   #5
Trailer: scamp 19
Illinois
I have a supercab f150 with a 6.5' bed. The mount is really far back in the bed and the shorter bed should not be a problem. Here is a picture if my link works:
2018 Scamp 19
Ford F150 Lariat 3.5 ecoboost
My Travel Blog
BOGDOG is offline   Reply With Quote
Old 12-13-2018, 02:17 AM   #6
Trailer: scamp 19
Illinois
Here is drawing I did based on a tracing of a photograph - just imagine the cab being 1 foot farther back. There is plenty of room.
2018 Scamp 19
My Travel Blog
Old 12-13-2018, 07:14 AM   #7
Al and Cindy K's Avatar
Trailer: 2002 16 ft Scamp
We have a Toyota double cab with the short (60") bed and the hitch ball is maybe an inch behind the rear axle. No problems with contact between the cab and trailer nose or the landing legs frame and bumper even with the truck at a right angle to the trailer.
Edit to add - Hitch ball center is 24" from the back wall of the cab.
Al and Cindy K is offline   Reply With Quote
Old 12-13-2018, 10:09 AM   #8
Dennis mn's Avatar
Minnesota
With my Nissan, I mounted the ball in the center of the bed, thirty inches from the back of the cab. The ball was about 2” behind the axle. The Scamp pulled wonderfully.
2021 Nissan Pro 4X. 2020 Scamp 19’ Deluxe.
Dennis mn is offline   Reply With Quote
Old 12-13-2018, 02:12 PM   #9
GOB
Trailer: Scamp 19
Missouri
I believe Scamp says to mount the hitch no further forward than 60 inches from the corner of the bumper to allow for clearance when turning.
GOB is offline   Reply With Quote
Old 12-13-2018, 04:29 PM   #10
5th Wheel's Avatar
Trailer: SCAMP
Illinois
https://photos.app.goo.gl/VHGSqiU5znXahtqZA
Old 12-23-2018, 12:08 AM   #11
For you and all F 150 owners check on a recall. Many thousands of them have been recalled due to a fire hazard. This is just a FYI since so many drive and pull their trailers with a F 150.
Jann Todd is offline   Reply With Quote
Old 12-23-2018, 02:42 AM   #12
Borrego Dave's Avatar
The recent recall is for a cable problem to engine block heaters.
Nissan Frontier quad cab V6 4x4 short bed and Scamp 19 John_M_1 Towing, Hitching, Axles and Running Gear 39 04-09-2024 08:45 AM
Frontier short bed 5er hitch installation Fran L Problem Solving | Owners Helping Owners 4 08-13-2012 06:27 PM
2 Scamps forsale Starting at $150.00 Kevin K Classified Archives 11 04-09-2009 11:41 PM
Will Nissan Frontier Short Bed tow 5th wheel Scamp?? Betty L. Towing, Hitching, Axles and Running Gear 6 02-03-2007 05:22 PM
