Scamp city water tube - how to remove? - Fiberglass RV
Old 01-11-2019, 01:41 PM   #1
Trailer: 1978 Acorn Scamp Camper
I need to remove and clean the city water tube in my 1980 Scamp. Does anyone know how to loosen the side that attaches to the external hose outlet? Do you unscrew the black part? Does the silver part unscrew? All the other tube connections have been really easy to get off.
Thanks for any help.
MelanieW is offline   Reply With Quote
Old 01-11-2019, 09:18 PM   #2
floyd's Avatar
I say, cut the that silver collar then use a razorknife to cut the hose and get a new piece of nylon reinforced Tygon tubing at your local hardware store.
Install it using an ordinary hose clamp.
Old 01-12-2019, 09:09 AM   #3
Dennis mn's Avatar
Minnesota
Agreed. That’s the way I would tackle it!
2021 Nissan Pro 4X. 2020 Scamp 19’ Deluxe.
Dennis mn is offline   Reply With Quote
Old 01-12-2019, 09:27 AM   #4
Paul O.'s Avatar
Second second, I would not bother cleaning the hose, I would also replace it. (hose clamps come in all sizes...)
Old 01-12-2019, 09:44 AM   #5
I agree that replacing a few feet of hose is a no-brainer.. but what I dont know is what that hex shaped thing is... you called it a "external hose outlet" but is that the old style fill port or a city water connection? So I dont know if its a threaded connection or something else. In the worst case you can replace the "external hose outlet" also, but without knowing more (or seeing more photos), I would cut the hose and carefully use a dremel to cut the ring off without cutting any deeper than the ring (it appears to be a crimp ring). Once you do that you might be able to see if its a threaded connection, barbed, etc and go from there. Chances are a new hose and hose clamp will work fine but if its on the pressurized side lets talk more.
Old 01-16-2019, 09:43 AM   #6
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
Blowing up the picture shows two hex fittings, one on the city water hookup, and one on the hose side, use two wrenches ( the correct size is preferred to an adjustable) and loosen the fitting, remove it, replace the hose, (personally I would change the fitting as well if you can get one handily) and re-install.
On metal to metal connections like that I usually use 2-3 turns of white plumbers tape to ensure a good seal
joe
Belly bands and city water and the water drain plugs Cheyanna83 Problem Solving | Owners Helping Owners 0 05-25-2015 07:24 PM
Fresh Water Tube Mold melissab Plumbing | Systems and Fixtures 5 06-15-2011 06:35 AM
Loose Dometic refrigerator water drain tube on Bigfoot 08, 21RB GeorgeR Problem Solving | Owners Helping Owners 4 06-08-2009 02:58 PM
Water Tank fill valve from City water line! Michael Pupeza Problem Solving | Owners Helping Owners 6 06-20-2008 04:10 PM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
