towing a scamp 5th wheel - Fiberglass RV
Old 01-14-2019, 08:56 PM   #1
Trailer: scamp
hi yall! i currently drive a 2015 ford f150. I found a 1994 scamp 5th wheel that I'm really interested in. does anyone know if there will be enough truck bed clearance? the owner said they picked it up with an f350....trying to get measurements from owner... but does anyone have this combo? know if itll work? Thank you!
nayhomee is offline   Reply With Quote
Old 01-14-2019, 09:15 PM   #2
A crucial measurement is the height of the trailer coupler from the ground. This measurement varies depending on the trailer axle. The trailer and axle can be modified if necessary. Since it was towed with an F250, the trailer might even require lowering. You should be able to make this work.
Old 01-15-2019, 06:41 AM   #3
Trailer: Boler 13 ft / Casita FD
Years ago I almost bought one and this was the main reason I didn't buy...Well that and I didn't really like how you had to lay-down to make the bed...
Old 01-15-2019, 07:32 AM   #4
Jon in AZ's Avatar
I’ve seen people tow these things at crazy angles, so I wouldn’t assume that just because it “worked” with an F350 means it will be right with yours.
Does it have the OEM standard suspension, the OEM 3” raised suspension, or something else modified by a previous owner?
If it has either stock suspension a call to Scamp will tell you what bedrail heights will work. If it’s been modified, you’ll want to know the actual height of the loft with the trailer sitting level on level ground.
As said though, even if it doesn’t fit your truck, that can be fixed with a new axle, which it may well need anyway given the age. Torsion axles have a typical lifespan of around 20 years. If the price and condition are otherwise right...
Old 01-15-2019, 09:03 AM   #5
Paul O.'s Avatar
That vintage, 1994, most probably does not have the 3" spacer in the axle mount. If it does, it should work. In any case, I would go back and measure the height from the ground to the lower edge of the shell below the loft. Measure your truck as well. When connected to the truck you should try to have 6" to 8" between the truck bed sides and that lower edge of the shell. Scamp uses the Reese ball mount, the height of which is adjustable.
I hope it works out for you, they tow really well. I do have to agree with Floyd, making the bed in the loft is a pain in the back side (literally). It gets easier with practice.
Old 01-18-2019, 01:29 PM   #6
ArthurBNH's Avatar
Trailer: 2005 Scamp 5th Wheel
New Hampshire
Scamp 5th wheel
If you could post a picture of it we might be able to tell if it has been raised.
If the axle is good adding spacers is not all that difficult or expensive if needed.
I have a 2005 and love how it towes.
FYI is you need a Scamp 5th wheel hitch I have one for half price
ArthurBNH is offline   Reply With Quote
Scamp 19' fifth wheel towing -- Scamp hitch vs. converted 5th wheel Stendec Towing, Hitching, Axles and Running Gear 17 11-12-2020 09:13 AM
Towing Scamp 5th Wheel Sally P. Towing, Hitching, Axles and Running Gear 28 09-03-2015 09:29 PM
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 02:04 AM
Anyone towing 5th wheel with Chevy Crew, 1/2 ton? Renee Problem Solving | Owners Helping Owners 1 03-04-2007 07:00 PM
