05-25-2016, 10:27 AM
SOLD: Bigfoot 25B25RQ Travel Trailer $22,000
2005 Bigfoot 25B25RQ Travel Trailer set up for absolutely trouble free towing and dry camping. Located in Gray Creek BC but can deliver to the Idaho area if needed.
Price is $22,000US or $27,300 Canadian
This trailer was originally sold in Washington state and has the Washington Inspection decal attached to the trailer. The trailer is currently plated for BC and comes with full BC registration documentation.
This trailer has the full premium Bigfoot features. See below.
Owner Upgraded/installed features are as follows:
Brand new upgraded 225/75/15 10 ply Radial Tires with Chrome Spoke Wheels,
Hensley Arrow hitch, absolutely no sway!
New 16ft awning material last season
New Adco Trailer cover last season
White 16' Sun screen material for extra groove in awning roller
Greaseable spring pins and bronze bushings,
HDTV with Winegard Traveller automatic satellite system and Shaw Direct dish,
Xantrex Pro 1800W Inverter and Transfer switch and remote control panel,
Upgraded DC Power Converter with 45amp Battery Charger and Charge Wizard,
New AM/FM radio, CD, DVD Player combo
100w solar panel and 25amp Controller with battery temperature sensor
Temperature controlled Battery and Inverter cooling fans
2 group 31 AGM Lifeline batteries
Thermostatic Fantastic Fans in Bathroom and Bedroom
Custom made white vinyl skirting for complete trailer.
White vinyl wheel covers
X-Chock wheel chocks
Note: Propane tanks are full but are outdated and need to be replaced. (Give you a credit of $100 per tank)
Wheel bearings have been checked and repacked. Brakes have been checked and adjusted and are about 70% remaining. Drums are excellent. Spring pins and hitch bars have been greased.
Some spare parts are included such as:
new brake linings, wheel bearings and seals
You’re completely ready to hookup and go across country if you wish!
If you need a list of the usual features of this trailer you can find it on the Bigfoot website or read on . . . .
Lightweight Two Piece Fiberglass Exterior Shell with 1 1/2" High Density EPS Insulation (R8), Radius Corner Compartment Doors, Radius Corner Entry Door (c/w Deadbolt Lock and Gas Strut), Thermal skylight in bath and living areas.
Radius Corner, mirror reflective, dual pane, Safety Glass Windows (c/w Screens),
twin 3500lb axles with electric Brakes, and Break Away Switch . . . . ,
Molded Fiberglass Rock guard (c/w Gas Struts),
Molded Fiberglass, Propane Tank Cover, Washable Vinyl Wall Paneling, Marine Quality Fabric Headliner, Face Framed Double Screwed Oak Styled Cabinets, Spring Filled Foam Mattress, Day/Night Shades, Venetian Blind in Galley, Electronic Ignition Ducted Forced Air Furnace, Fluorescent Light in Galley and main dining area, 12-Volt Range hood, Monitor Panel, Double Sink, Cutting Board, Single Lever Faucet, Dual 30 lb. Propane Tanks, 2-Way Dometic 6 cu. ft. Refrigerator, Electrical 120-VAC/30-Amp Service,, Porch/Hitch and Roadside Lights, City Water Hookup, 12-Volt Demand Water Pump System, Molded Fiberglass Shower Enclosure, Water Heater By-Pass System, RV Anti-Freeze Pickup System, RV Toilet, Enclosed Heated & Insulated Holding Tanks, Electronic Ignition Hot Water Heater (6 Gallon), MVSS 302 Fire Rated Automotive Fabric, Smoke & Carbon Monoxide Detector, Propane Detector, Fire Extinguisher, AC Roof - 11,000 BTU, Battery Disconnect (Electronic), Dometic Microwave Oven, Oven (c/w 3 Burner Cook Top & Bi-fold Cover), Roof Rack and heavy duty Ladder, Self Storing 16' Awning, Skylight (c/w Pleated Shade), Stabilizer Jacks (Front & Rear), Stereo AM/FM – CD and DVD player, Water Heater – LP, Auto Change Over Propane Regulator, Exterior Shower (c/w Winterizing Valves), Spare Tire and Carrier, Magazine Rack in bedroom folds down for TV stand, Bathroom Vanity with storage and large medicine cabinet.
There may be more, but come and see the trailer. . . you won’t be disappointed!
06-01-2016, 04:20 PM
Trailer: 1988 Bigfoot Deluxe B19 19 ft / 2007 Nissan Frontier V6 NISMO 4x4
That's a gorgeous trailer - what do you tow it with?
06-01-2016, 09:31 PM
Hi there. .
Thanks, it is a great trailer. . .
We have towed this trailer with a Ford F350 which is a bit of overkill but we also loaded the truck up with goodies as well. . . Hobie cat, Inflatable, Outboard motor, genset, trail bike, etc etc. . . it gets heavy after a while. In my opinion, this trailer can be managed with an F150 if the truck is not loaded too much.
Dave from BC
06-03-2016, 05:52 PM
Sold Sold Sold!
Our favourite trailer just got sold. I'm glad and I'm sad. I know I'll never get another trailer as good as the Bigfoot.
Thanks to Fibreglassrv.com
Dave from BC
08-06-2016, 02:24 PM
Trailer: 2020 25 RQ
Can this ad be removed.???? The trailer is sold right?
08-08-2016, 10:10 PM
As the post above yours says - YES the trailer is sold.
The for sale posts are not removed as they are good for reference when pricing trailers values.
