Serial numbers on a Trillium - Page 4 - Fiberglass RV
Old 03-28-2013, 07:37 PM   #61
David Tilston's Avatar
Good idea Francesca.
Randy B:...45-1100483...'78: Front Gaucho
Randy B:...45-1100661...'78: Front Gaucho
Chris:.......45-1100711...'78: Front Gaucho
Francesca:45-1100758...'78: Front Gaucho
Scot M:....45-1100893...'78: Front Gaucho
Randy B:...45-1100914...'79: Front Gaucho
David T:....45-1101043...'78: Front Gaucho
Unknown:..45-1121172...'79: Front Dinette (assumed)
Reid:........45-1101273...'79: Front Gaucho (almost dinette)
Roy:.........45-1111339...'79: Front Gaucho (almost dinette)
Randy B:...45-1131567...'80: Front Full Bath
Noreen:....45-1121733...'81: Front Dinette
David T:...13-609..........'73?: Front Gaucho
Glenn:......13-1102981....'??: Front Gaucho
Reid:........13 1104528...'78: Front Gaucho
Randy B:...13-1104633...'76: Front Gaucho
Randy B:...13-1105016...'76: Front Gaucho
David T: ..13-1105688...'77: Front 1/4 Bath
Spanke: ...13-2205863...'78: Front Gaucho
Brett: ......13-1106227...'79: Front full bath
Randy:......13-1116743...'80: Front Gaucho (almost dinette)
Old 03-28-2013, 07:56 PM   #62
Originally Posted by David Tilston View Post
The updated list. I hope Randy B has his front gaucho 1300 SN wrong, because it messes up the serial number scheme. Also I suspect that his 1979 4500 may be a 1978.
David...
Checked the serial numbers and they are all correct..When I tagged them in Alabama due to all of them coming from out of state I had to have a police officer come out and verify the serial numbers before they would issue a tag..Alabama "does not" require a title on these (due to age I guess)and "will not" issue and new Title when you register it, all you get is a Tag Registration reciept.....All I have to go by are the stickers and titles and I'm lucky because I have the titles on all of them...I've since stamped the serial numbers on the tongue of each one because the stickers on the closet doors are impossible to remove and re-install on the new doors.I went and checked the sticker on the closet on them and there are no dates listed anywhere that I can see to verify the years...I tried to take photo's of the door stickers but the flash washes everything out and you can't read it ..might work better tomorrow in the daylight...If there something else I can do to help let me know and I'll try to help the best I can....THANKS RANDY
Old 03-28-2013, 08:03 PM   #63
Randy, I had the same problem with the camera flash. I found it helped if the sticker was not straight on to the camera.
Dumb question, what does the door window of, 45-1100914...'79: Front Gaucho, look like. It seems that only the 1978 year had opening windows in the door, but I could be wrong.
It may be that there is more to the 1300 serial numbers then we think. I look forward to more data.
Old 03-28-2013, 08:14 PM   #64
That one does not have a window in the door..Send me your e-mail address and i'll e-mail you the pictures I took of the door stickers on the 4500 and 1300... the 1300 that had the A/C on top i'll have to wait till tomorrow on it...Thanks Randy
Old 03-28-2013, 08:19 PM   #65
Roy in TO's Avatar
Originally Posted by Francesca Knowles View Post
Which "missing" digit did you reinsert in your number? (in case it turns out to be important).
'Twas a 3
Actually, since yours is a 79, I am assuming that your gaucho is an "almost dinette" which it seems they gave different numbers to.
I think you are right. It would be a very easy mod to add a table. Change the cushions would be the expensive part. Also had the 4" rear bumber with no gray or black tanks. good for storing poles.
Old 03-28-2013, 09:06 PM   #66
What I really like about the factory install of the front dinette is the fibreglass back splash they add to the front. Unlike the rear dinette, this back splash is not part of the mould for the seats It is a separate piece. It supports the table, without having to screw through the shell of the trailer. Tom Young does not have this piece on his front dinette Trilliums. Instead he uses a large tubular pedestal leg.
I totally agree with you about the 4" bumper. I see it on lots of Trilliums. Perfect for the poles used with the awning. Unfortunately the bumper on my 4500 is no longer good for that. When I put the rear hitch receiver in, it took up too much of the cross section to fit all the poles now, bummer.
Old 03-28-2013, 10:45 PM   #67
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
Dave,
Thought I would chime in with the serial numbers on our two Trilliums. The 1978
1300 is 13 1104528 and the 1979 4500 is 45 1101273. They are both Front Gaucho models.
As it has been noted the 1979 4500 model has the foot space that allows easy conversion to a front dinette which I have almost completed and will post pics when I'm done.
Reid
Reid Larsen is offline   Reply With Quote
Old 03-29-2013, 12:07 AM   #68
Originally Posted by Reid Larsen View Post
Dave,
Reid
Thanks Reid, I have added your trailers to the last list.
Kinda looks like either the serial numbers are not sequential, or there are trailers with incorrect years. Like my Cantaloupe. How it is registered as a 1977, is beyond me.
Old 03-29-2013, 11:54 AM   #69
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
That's the beauty of what you're doing, David- it may be that we haven't discovered the real pattern yet.
As the volume of SN's grows, something entirely different from our assumptions might emerge!
Francesca
Old 03-29-2013, 02:25 PM   #70
Roy in TO's Avatar
Are there any other clues in the Cantaloupe? Dates on fridges, stoves furnaces etc?
Old 03-29-2013, 03:41 PM   #71
Trailer: 1974 Trillium 1300
By the Numbers
Got out of hibernation and tromped thru the lingering snow to seek out the serial numbers.
13-2202178
Issue number 47545
Love this one! Tire inflation 28 lbs!!!
indigodave is offline   Reply With Quote
Old 03-30-2013, 03:16 PM   #72
Noreen Bradshaw's Avatar
Trailer: Trillium
Here's another 13' Trillium to add to the list.
This was my first Trill. When I got the 4500 I gave this one to my Daughter. I finally got over to her place to take these pictures.
There is a long story of how this camper got registered as a '79 which I do not believe it is. I think it is a much earlier year.
It has a front gauncho and no kitchen window. The window in the door does not open. It has an ice box.
Noreen Bradshaw is offline   Reply With Quote
Old 03-30-2013, 05:09 PM   #73
Thanks, Dave and Noreen. Your serial numbers have been added.
Noreen, I would say it's a 1976. The logo and door lock changed in 1977.
Dave, I am guessing, but is your tralier a front gaucho?
Noreen:.....45-1121733...'81: Front Dinette
David T:....13-609..........'73?: Front Gaucho
indigodave:13-2202178...'74: ????? What is your floor plan Dave?
Glenn:.......13-1102981....'??: Front Gaucho
Reid:.........13 1104528...'78: Front Gaucho
Randy B:....13-1104633...'76: Front Gaucho
Randy B:....13-1105016...'76: Front Gaucho
Noreen:......13-1105085...'79? Front Gaucho
David T: ....13-1105688...'77: Front 1/4 Bath
Spanke: ....13-2205863...'78: Front Gaucho
Brett: .......13-1106227...'79: Front full bath
Randy:.......13-1116743...'80: Front Gaucho (almost dinette)
Old 03-31-2013, 08:55 AM   #74
Martins HeirCon's Avatar
Trailer: Trillium 1300
Georgia
Looky what I found!
While stripping decals and removing front rack, I came across this label with a build date of Feb. '75. Has anyone else seen this decal?
Martins HeirCon is offline   Reply With Quote
Old 03-31-2013, 03:46 PM   #75
Yes Dave, I have the front gaucho model.
Old 04-01-2013, 06:30 PM   #76
My Conversation with Tom Young
OK, I just spent almost two hours on the phone with Tom Young of TrilliumRV.com. He filled me in on the model number code. The first two digits refer to the exterior, and the interior color.
1 = Antique White
2 = Green
3 = Orange, (Gold)
The Third digit was not used until later years. It was for the floor plan, but he was not positive of the codes.
So, The Cantaloupe would be 13-2300609, if it was numbered the same as the later Trilliums.
I will post other details of the conversation in a new thread.
Old 04-01-2013, 07:36 PM   #77
1 = Antique White
2 = Green
3 = Orange, (Gold)
I don't get it...can you decode a number into its parts as an example?
Francesca
Old 04-01-2013, 08:54 PM   #78
How about 4:
220 The first two means a green exterior the second two means a green interior the zero is meaningless in this year. (I hope Spanke's trailer is painted)
111 The first one means white exterior, the second one means white interior, I am guessing, but I am going to say the third one is for front gaucho, (almost dinette)
112 The first one means white exterior, the second one means white interior, also guessing, the two means front dinette.
113 The first one means white exterior, the second one means white interior, guessing again, the three means Bath
Old 04-01-2013, 09:35 PM   #79
Trailer: Trillium
Thanks, David. I am finding this thread very interesting.
I have learned more in the last year about my Trilliums from this site and from you than in all the previous years since I bought my little 13 footer in '98. The more I know the better I am able to take care of my camper and the safer I am able to keep it.
Old 04-01-2013, 10:56 PM   #80
I hope trilliumdon doesn't mind, but I found this in his trilliumdon's Trailer :: Trillium 13' Trailer
Serial Number: 13-2203887
Stove: Brown ZFJ-002-LY?
Ice Box: 71-IS
The Curent List:
NEW COLOURCODE
Black = Antique White (for Francesca)
Green = Green
Orange = Orange
Blue = Front Gaucho
Red = Front Dinette
Purple = Front Bath
LucilleL:....45-1100902...'78: Front Gaucho
David T:....13-23000*609'73?: Front Gaucho *23000 = imaginary
indigodave:13-2202178...'74: Front Gaucho
Glenn:.......13-1102981....'75: Front Gaucho (Feb '75)
trilliumdon:.13-2203889...'72? Front Gaucho
trillium
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
uhaul serial numbers and tracking andrew78 General Chat 6 11-12-2019 01:38 PM
Trillium 1300 Serial Number Rick Mooyman Problem Solving | Owners Helping Owners 8 04-30-2015 05:22 PM
Possible trillium--no title, no serial # jenbooks Care and Feeding of Molded Fiberglass Trailers 42 04-23-2012 04:20 PM
production numbers Perry Mac Donald General Chat 3 05-12-2010 07:13 PM
numbers BAMA & Pachyderm Posse Forum Admin, News & Announcements 1 02-15-2007 11:01 PM
