U-Haul Exterior Center Seam Seal - Fiberglass RV
Old 05-10-2013, 12:12 AM   #1
Perk's Avatar
Trailer: Formerly U-Haul
I have purchase replacement seal material for the exterior center seam rib for my VT. I wish to replace the existing darkened, sunbaked, brittle seal material. I know I will need to use a adhesive to hold the new seal material and wish to know what others have used. Here is a picture of the rear of my VT and the center rib seam seal. I believe you will be able to see how it has darkened.
Perk is offline   Reply With Quote
Old 05-10-2013, 05:04 AM   #2
Thomas G.'s Avatar
Perk, I used butyl caulking sold for gutters.
Old 05-12-2013, 01:09 AM   #3
Perk's Avatar
Tom,
Do you use the butyl on the ends only or do you use along the entire ridge?
Also did you clean up the ridge "really well" before you put the new seal on the ridge.
Thanks for your insight.
Old 05-12-2013, 06:25 AM   #4
Thomas G.'s Avatar
Originally Posted by Perk View Post
Tom,
I cleaned the entire ridge thoroughly to make sure the caulk would stick. I squirted caulk down into the center of the trim as I pushed it on, trying to minimize the amount squeezed out. The ends are the trickiest part. When I did mine, the ends wanted to curl off. I'd suggest bending the metal spine to "train" it to lie flat at the ends before it is actually glued into place. I also taped the ends down until the caulk had cured.
Old 05-05-2016, 08:41 AM   #5
Trailer: Burro
Idaho
Hi Thomas, I'm researching sealing the center seam of my 1999 Burro. Would you mind letting me know how has that butyl caulk held up over the last few years?
jwjenn is offline   Reply With Quote
u-haul
Still Looking for Center seal for U Haul. J.S.Lahm Problem Solving | Owners Helping Owners 5 01-10-2012 10:01 AM
Resealing my center seam ROIDON L Care and Feeding of Molded Fiberglass Trailers 5 04-10-2011 02:11 PM
Burro center seam ThomasE Problem Solving | Owners Helping Owners 6 01-29-2010 11:08 AM
Compact Jr Exterior Seam Tape Sharyl Allender Care and Feeding of Molded Fiberglass Trailers 2 07-16-2009 12:00 AM
Need source for exterior metal seam on '73 Love Bug Christopher Singer Care and Feeding of Molded Fiberglass Trailers 5 06-02-2009 11:55 AM
