Trillium Hehr window drip strip. - Page 2 - Fiberglass RV
Old 04-29-2015, 03:25 PM   #21
David Tilston's Avatar
Top windows? I have pulled all the windows off one of my Trilliums. Pull them out from the bottom.
Old 04-29-2015, 07:41 PM   #22
Carol H's Avatar
If Butyl tape was originally used to seal the window frame you may find you need to run a knife around the frame to get it to lift off.
Old 05-01-2015, 09:14 AM   #23
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
If your windows are the same as mine [ 1977 surfside ] the windows only come out from one end there is a small flange that will not let it come out the other way . It is helpful to have two people because it has to be at the perfect angle to slip it out . Also on mine the channel for the stripping is crimped at both ends and needs to be opened up to slide out the strip . When installing the new strips it is helpful to dip them in soapy water for lubrication . Good luck Bob
Bob in Mb is offline   Reply With Quote
Old 05-01-2015, 10:16 PM   #24
Kelly H's Avatar
Trailer: '75 Trillium 1300
^ That's pretty much how mine are too.
I was able to get the bottom two panes out with relative ease. To get the top panes out, I had to crank them all the way open and stand in the middle of the window with the balls of my feet on frame to yank the top panes out. Suckers were stubborn. I'm going to try to pull out that interior vertical seal out tomorrow before I buff them. I've had some very, very heavy oxidation and putting in the aluminum so I've been using a wire brush on the drill to buff them out. I'm planning to polish them up tomorrow and work on the reinstall.
Kelly H is offline   Reply With Quote
Old 05-03-2015, 11:33 PM   #25
Trailer: 1975 Trillium 1300
Slightly off topic. Can I pull the screens out of my trillium without having to remove the whole window? They need to be repaired.
Lilly The Trilly - 1975 Trillium 1300
PrettylilTrilly is offline   Reply With Quote
Old 05-04-2015, 07:58 AM   #26
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
Most screens are spring loaded at the top and to remove - lift the screen up until it clears the bottom channel . The side channels may slide sideways to clear the screen frame or on some , one side may be spring loaded as well in which case the screen is pushed sideways to clear the channel . Hope this helps .
Old 09-03-2016, 06:40 PM   #27
Roy in TO's Avatar
[QUOTE=Doug in Alberta;455477I tried removing the top pane but could not lift it off hinges. If I can only achieve strip swap by taking window apart, please let me down slowly as my windows have already been resealed with new butyl and ply. Thanks![/QUOTE]
Given it's been a few years since this post, I'll let you down slowly.
I'm doing mine now and felt it best to post the answer in this thread
Originally Posted by Ian G. View Post
It will be much easier if you remove the upper window, Just remove the 4 screws as I mentioned iwhen you initially posted. You should not have to remove the entire window, just the upper window.
Sorry Ian,
The side window on a Trillium has to come out to safely remove the top jalousie pane. Even with the window out, I had to undo the 4 screws on the header to lift it up high enough to pull the pane out.
The key difference is that the header is attached at a downward angle on the Trill windows - I looked at my boler and it is @ 90 degrees. The angle is what makes it difficult.
Here are some shots of mine with the pieces held together by hand.
The first one is with the top pane out.
The second with the top pane in lookin from the inside.
Old 09-03-2016, 06:51 PM   #28
The best way to remove the brittle top rubber seal is to heat it up, it will turn soft and flexible and will be easily removed..
trillium
1974 Trillium Exterior Window Strip Krysti Peck Problem Solving | Owners Helping Owners 12 09-07-2013 06:52 AM
rear window weather strip, inside vs outside..? Spencer Problem Solving | Owners Helping Owners 1 06-02-2013 12:48 PM
Cheapest Place to Buy Front Window seal with locking strip idiotsniff Problem Solving | Owners Helping Owners 58 07-10-2012 02:36 PM
Hehr window screen parts. DanPatWork Problem Solving | Owners Helping Owners 1 01-09-2008 05:37 AM
Trillium Exterior Window Strip Krysti Peck Problem Solving | Owners Helping Owners 4 05-13-2007 06:32 PM
» Trailer Showcase
Dog House
Gord13
Lilly
Antonia
