1986 UHAUL axle bearings - Fiberglass RV
Old 08-09-2015, 01:36 PM   #1
Trailer: uhaul
Idaho
I have a 1986 uhaul 13 ft. and I would like to know if the axle bearings are serviceable... Some one told me they are a sealed unit??? Thanks
katie123 is offline   Reply With Quote
Old 08-09-2015, 05:22 PM   #2
Trailer: UHaul CT13
Iowa
Harold,
I'm no expert, but the folks on the U-Haul Facebook site say pretty emphatically that they are NOT serviceable. But apparently also give very long life just the same. There is information on that site on alternative hubs that can be substituted, should yours go bad... or if you wanted a spare along on a long trip??
Definitely worth joining both here and "over there". Different format between the two sites, for sure, but lots of help to be had from both.
Gary
Old 08-09-2015, 07:13 PM   #3
They are sealed units, not serviceable. Only thing you can do is jack up a wheel, (don't jack on the axle) and check for any play, roughness, or noise, when turning the wheel. Should be none of that. There has been only one known bearing failure in the whole Facebook group, and that failure may have been caused by some kind of abnormal damage. All kinds of good info in the files section of the Facebook group, and info from the members.
Old 08-09-2015, 07:27 PM   #4
Pam Garlow's Avatar
Trailer: U-Haul 1985
Oh, yeah those sealed bearings just keep on rolling!!
Just check them like Bob says. Thanks to my UH, I have yet to get any bearing grease under my nails.
Pam Garlow is offline   Reply With Quote
Old 08-09-2015, 10:36 PM   #5
floyd's Avatar
In case you aren't following all the threads, your hubs are supposedly Chevrolet Citation rear hubs Circa 1980, In case you ever need to replace one. Of course take your old one to the parts store with you to verify what I have said.
Old 12-29-2015, 03:41 AM   #6
Trailer: uhaul clone
Illinois
I HAVE A SET OF HUBS IF YOUR INTERESTED
rrod48@gmail.com
rrod48 is offline   Reply With Quote
axle, uhaul
Changing Axle Bearings on a '74 Ventura Dave Ventura Towing, Hitching, Axles and Running Gear 13 07-01-2013 11:04 PM
pre-trip check: axle/wheels/bearings/tires Tom Byron Care and Feeding of Molded Fiberglass Trailers 1 08-06-2010 02:13 PM
Re-greasing UHaul CT Bearings KarenW Problem Solving | Owners Helping Owners 3 07-07-2010 09:17 PM
do i need to pack axle bearings on scamp '13 Dan Vang Care and Feeding of Molded Fiberglass Trailers 3 08-28-2009 09:59 AM
Re-greasing UHaul CT Bearings Chad S Towing, Hitching, Axles and Running Gear 0 01-01-1970 12:00 AM
