Trying to remove fridge from boler - Fiberglass RV
Old 09-11-2016, 05:05 PM   #1
Yellow Boler's Avatar
I am trying to remove an original fridge from boler. However they used bolts with a rounded head on top so there is nothing on top to grab onto. When I turn the nut on the bottom the top just turns and there is nothing to grab on to. How do I get these bolts out so I can remove the fridge? Does anyone have any experience with this?
Yellow Boler is offline   Reply With Quote
Old 09-11-2016, 05:43 PM   #2
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
If you can't get a visegrip plier on it, you could try tightening the nuts from underneath until the bolt breaks. (last resort)
Or, if you have a dremmel tool, you could try cutting a slot in the bolt head so you can use a flat blade screwdriver.
Or, if you have a grinder, you could grind off the bolt heads, or if access is easier from below, grind/cut off the nuts.
Good luck!
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
Old 09-13-2016, 09:13 AM   #3
Trailer: Scamp 16
Ohio
You can also use center punch and drill them flush.
cmartin748 is offline   Reply With Quote
boler, fridge
Trying to install new LED tail lights on Boler 1973 Boler Newbie Towing, Hitching, Axles and Running Gear 15 09-13-2013 03:16 PM
Trying to light the gas on my fridge-Help ROIDON L Problem Solving | Owners Helping Owners 9 07-08-2010 10:34 AM
Fridge not working... Is it worth trying to fix it? Rob Carmody Problem Solving | Owners Helping Owners 6 09-06-2008 03:08 PM
How do you remove that darn fridge al gilliland Problem Solving | Owners Helping Owners 4 12-12-2006 08:13 AM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
