Where to start trillium repair - Fiberglass RV
Old 09-12-2016, 10:24 PM   #1
Trailer: Trillium
Saskatchewan
My back window has started to leak. There is a little water between the wall and the insolite and we are supposed to go below freezing tonight. My entire trillium needs to be renovated. So where do I start? Should i try to pop out the window and reinstall it before the snow flies, or should I just put a tarp over it and wait until spring when I can replace the belly band, buff down the exterior and get it all repainted?
PatriciaSK is offline   Reply With Quote
Old 09-13-2016, 07:47 AM   #2
Roy in TO's Avatar
With 8 posts, I assume you are new to all of this.
If so, I would start with the tarp. That will give you the winter to read up on all the other projects here on FGRV.
Window leak could be just the butyl, the vinyl seals or it could be the wood that holds the frame in place. ... but you did mention belly band.
I've been around here for a decade and just started my first jalousie window job. It was much bigger than I imagined. I'm still learning. What surprised me was the jalousie window panes can be adjusted.
Old 09-13-2016, 09:31 AM   #3
FRED SMAILES's Avatar
Trailer: 13 ft Boler
I lived in SK for a long time,, know isn't the time to tear it apart if it is to sit outside.
As Roy said tarp it till spring. I would scrape back the ensolite where it is leaking and dry it out though.
Good luck with your new2u tril!
Fred
Old 09-14-2016, 10:19 AM   #4
Trailer: 1976 Trillium
HI, I need some guidance on replacing the wood frame on one of my side windows of my 1976 Trillium. The window leaks and the wood is all rotten. Any tips?
thanks C
CBeech is offline   Reply With Quote
Old 09-14-2016, 11:10 AM   #5
David Tilston's Avatar
thanks C
There are several threads on this:
http://www.fiberglassrv.com/forums/f...ead-65342.html
The real challenge is getting the Ensolite separated from the wood window frame. A real sharp putty knife is a good start. I have found that wet / rotten wood separates from the Ensolite much easier then dry / sound wood.
Old 09-14-2016, 07:49 PM   #6
Carl V's Avatar
You can also look up my renovation thread. I resealed all the windows on my trailer and took many pictures.
http://www.fiberglassrv.com/forums/f...0-a-71346.html
Old 09-19-2016, 07:46 AM   #7
Thanks for the pictures, it gives me a better idea of what to expect. C
trillium
Awning repair, or start new? Sheryl M Problem Solving | Owners Helping Owners 10 05-03-2013 03:25 PM
79 Trillium 4500 Where do I start!? Scott H Problem Solving | Owners Helping Owners 22 10-13-2009 09:39 PM
Time to start waxing those trailers Legacy Posts Care and Feeding of Molded Fiberglass Trailers 19 03-18-2003 09:08 AM
Heres the start of the restoration Legacy Posts Modifications, Alterations and Updates 6 02-21-2003 02:24 PM
IF YOU GOTTA GO, START EARLY Legacy Posts Jokes, Stories & Tall Tales 1 11-25-2002 06:35 AM
