Scamp '13- needs complete rebuild - Fiberglass RV
Old 10-09-2016, 10:54 PM   #1
Trailer: '13 Scamp
Alaska
Scamp '13- total rebuild
Bought trailer knowing it was in bad shape. I learned how terrible it was once I got it home and started gutting it. Maybe worst I've seen. As you can see, all of the wood is now gone and not much of the wood to shell glass structure remained. The few threads that remained pulled off by hand. Sadly, the ensolite might need to go due to mold and the fact that we want it primarily for winter camping in Alaska. About to start refinishing the trailer before reconnecting the shell to the trailer. Will post more as I progress.
Andrew AK is offline   Reply With Quote
Old 10-10-2016, 07:28 AM   #2
Jon in AZ's Avatar
You do have a project on your hands! You seem up for it, and I am grateful when I see a neglected trailer brought back to life. Hope you'll post lots of pictures and details as you go.
Best wishes!
Old 10-10-2016, 12:15 PM   #3
Trailer: NotYet
Ohio
Scamp 13 Total Rebuild
I have a question.
Have you rebuilt other Egg Campers?
The reason I am asking is to gain knowledge about rebuilding Egg Campers, ... before I go at one myself.
I am a follower of the 5 P program.
Prior Planning Produces Peek Performance
Poor Planning Produces Poor Performance
I am looking to see if someone who has rebuilt an egg camper has replaced the plywood floor with marine board.
Marine board is used in shipbuilding due to it excellent waterproof characteristics.
Thank you for your time.
apfixer is offline   Reply With Quote
Old 10-10-2016, 04:57 PM   #4
Trailer: Trail Cruiser
I would definitely go with marine plywood (I'm from the coast). Also it helps to coat the underside with a truck boxliner polymer product especially if you travel a lot on gravel roads. Good luck with your project!
Mike_L is offline   Reply With Quote
Old 11-17-2016, 02:32 PM   #5
Trailer: '13 Scamp
Alaska
UPDATES
A little over a month into the rebuild process. Most of the time has been spent planning, building a rather costly ("spendy" for you Minnesohtins) cache of supplies and new tools, and a total gutting.
-Lifted shell off trailer with a 2x4 frame build (see images).
-Complete trailer derusting, Bondo, minor welding, priming, painting
-Surface prep for fiberglass work and install of all of the wood.
-Saved old wood for tracing new wood sections (using AC because marine is ~$100 or more a sheet in Anchorage).
Most recent accomplishment has been rebuilding the tabbing on the wheel wells- gaps which were previously filled with creative uses of galvanized sheet metal, silicone, unknown cheap caulking, and scrap OSB.
Images included showing new tabbing- used poly resin with 1.5oz CSM with sandwiched layers of 1708 biaxial cloth (5 layers to get thickness).
Old 11-17-2016, 09:19 PM   #6
Looks like a big project!
Old 11-20-2016, 08:46 AM   #7
kdhanso's Avatar
Andrew,
Thanks for sharing your project photos. I don't think there's a "t" in Minnesoh n. At least there isn't one when I say it.
Ken
Ken
kdhanso is offline   Reply With Quote
Old 09-28-2017, 11:20 PM   #8
Trailer: '13 Scamp
Alaska
Updates
Realized it's almost one year later, and after a year of skiing, fishing, and traveling, the trailer is getting ready to emerge from its year in the garage. Here are some pics of its progression.
Hope to post a finished pic before Thanksgiving.
IMG_20170809_221109.jpg   14570625_10101369284744394_7324176696461523908_o.jpg
Old 09-28-2017, 11:27 PM   #9
Trailer: '13 Scamp
Alaska
Getting there
More picsClick image for larger version
Old 10-04-2017, 08:29 PM   #10
Buggeee's Avatar
Trailer: Playpac
OH
This last picture with you in the ventilator looking out the window made me laugh because it reminded me of Breaking Bad.
This trailer is going to have a lot of fun with you on your adventures. Its looking good. Very thorough rebuild here.. it's going to be better than when it left the factory.
Buggeee is offline   Reply With Quote
Old 10-04-2017, 08:45 PM   #11
Trailer: 1987 Casita 16
Illinois
The pictures look like you are opting for glued wood to hold on the overhead cabinets. Are you going with no external rivets? How are you insulating for winters?
EricAllyn is offline   Reply With Quote
Old 10-04-2017, 11:50 PM   #12
Trailer: '13 Scamp
Alaska
Only planned rivets are at the closet and the already existing rivets on the drip cover over the door. Might end up having a few on an exhaust fan and vent cover, but only if I get lazy.
Reflectix, marine carpet, and warm sleeping bags to make it through 6 months of an Alaskan winter.
The interior is almost finished-will post more once I get back in there.
Old 10-05-2017, 03:32 AM   #13
Buggeee's Avatar
Trailer: Playpac
OH
Originally Posted by EricAllyn View Post
The pictures look like you are opting for glued wood to hold on the overhead cabinets. Are you going with no external rivets? ...
It's not glue, in an earlier post he mentions that he's using fiberglass and resin to mount the tabs. That should be stronger than rivets and no perforations in the shell.
Old 10-05-2017, 05:04 AM   #14
Missouri
your rebuild
Andrew very impressive I don't suppose you are counting your time in this but many congratulations to you!!
great job
bob
Old 10-05-2017, 11:03 AM   #15
Trailer: '13 Scamp
Alaska
Ended up finding some cheap marine epoxy to do the tabbing rather than using poly resin due to odors in the shared garage from the poly and the amount of surface prep I had to do on previous poly resin work.
With the epoxy resin I got to skip the days of sweating in a tyvek space suit, grinding old glue and leftover ensolite residue. Which was nice.
Old 02-06-2018, 12:02 PM   #16
Trailer: '13 Scamp
Alaska
Updates
Trailer is usable!
Had it out in some below zero F temps and all was well. The weap holes in the small side windows had some pretty impressive icicles, but we stayed warm and dry inside. A lot of tweaks occurred as we tried to figure out what will work on the distorted shell shape/door gap. (Notably the "step" below the door entry). We really liked the way the backsplash and exhaust fan worked out, so included a pic of that. Will update more once we do some more finishes on the interior. This week has been all electrical work.
1978 Boler Complete Restoration / Rebuild slavandheather Modifications, Alterations and Updates 250 08-16-2020 12:40 PM
Burro 1985 17ft complete rebuild joetraveler Hi, I am.... 1 12-16-2015 06:50 AM
Complete set of Scamp Cushions Frederick L. Simson Classified Archives 1 09-06-2006 12:23 PM
Complete Rig: 2003 16' Scamp Travel Trailer and 2000 Dodge Caravan lhayes Classified Archives 0 02-13-2006 05:17 PM
