1978 surfside waterpump - Fiberglass RV
Old 11-30-2016, 06:43 PM   #1
Trailer: 1978 surfside triple e
BC
First time hooking up a 12 volt pump.
Seems fairly straight forward but I do not want to lose the ability to use the hand pump in the event of total loss of power.
So the plan is to attach the water feed hose from the pump to the existing hand pump. My question is can I hook it directly to the pump and still be able to pump manually if need be or do I need to put in a directional valve where I can switch it from feeding water via the pump or directly from the holding tank.
Any input appreciated.
And yes I will be upgrading the hoses.
Erik F is offline   Reply With Quote
Old 12-30-2016, 09:43 AM   #2
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
You would be best to install either a directional valve or a simple on -off valve in each line . Without a positive isolation when using the manual pump you will likely lose suction through the electric pump.
Bob in Mb is offline   Reply With Quote
Old 12-30-2016, 01:12 PM   #3
BC
Thanks that is the plan. Planning on having a directional "Y" valve on the hose exiting the tank and then a shut off valve on the line feeding the pump and the line feeding the manual handpump. The valve to the handpump will stay closed unless I lose power and need to use it. Then I can close the valve to the 12 volt and maintain suction. But not sure if I should put the valve before or after the 12 volt, (probably before).
If it works, great. If not I will buy an electrical pump to replace the manual I now have.
surfside
1978 Surfside Jaclyn W Care and Feeding of Molded Fiberglass Trailers 80 12-13-2015 10:16 PM
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
84 fiberstream Waterpump/water heater question Cyndivg11 Plumbing | Systems and Fixtures 8 05-14-2012 10:38 AM
BC | 1978 Surfside for sale Marinab Classified Archives 3 05-08-2012 06:00 PM
Surfside 1978 tires - where to buy? Mel R Problem Solving | Owners Helping Owners 5 08-06-2008 02:22 PM
» Trailer Showcase
MyBoler
artx
Casita
Sheryl
