79 surfside window replacement - Fiberglass RV
Old 06-06-2017, 08:33 PM   #1
Trailer: Triple E Surfside
Just about to reinstall polished windows back into the openings. Original construction used 7\8 wood screws through exterior frame, FG, and 3\4 inch plywood. Worked well where the plywood did not rot.
Has anyone used an alternative method like 1 inch SS machine screws with nylon locking nut. Machine screws would be more work but bombproof.
Thx
David D is offline   Reply With Quote
Old 06-11-2017, 11:11 PM   #2
Thx
I went with 1 inch ss screws into 3\4 plywood backing. Also applied a sealant to edge of plywood in case of moisture penetration. Hung window with several screws to line up existing holes in FG and window. Once aligned predrilled remaining holes before applying poly butyl tape to back of window casing. Then remove window and apply poly butyl tape then put window back in place and screw all screws down. Snugged the screws down until poly butyl tape oozed out. Then trim excess tape. Click image for larger version
ID:	107208Click image for larger version
surfside
replacement window glazing for rear window on 1975 scamp Josh Wink Problem Solving | Owners Helping Owners 6 07-15-2016 04:05 AM
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Cog wheel replacement? Surfside hudman Modifications, Alterations and Updates 11 05-19-2015 05:48 PM
Inverter plastic switch thingamajig replacement - Surfside Shelley Problem Solving | Owners Helping Owners 1 07-09-2013 06:40 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
